Are you sure its smoke not steam? Most common problem is the heater core leaking. Look for moisture on the floor boards first. If it is wet then you have a heater core problem
Testimonial: "Thanks to Jose truj772! you were spot on. just took a bit for the answer to come to be true! thanks again for the awesome advice!!!"
No moisture on the fllor board and all fluid levels are normal.
Might be some debris burning on the blower motor resistor. If you pull the resistor, which should be below the dash next to the blower itself, check for burns on it or even a leaf that may have blown through the ducting. It should be a four prong connector if memory serves me right. You could also have a problem with the blower itself
My heater core suddenly blew today! thanks for all your help. much appreciated.
No problem. Good luck on your heater core replacement!
