Question about Whirlpool ET1FHTXM Top Freezer Refrigerator
Freezer has snow
Side by side freezer started getting ice/snow everywhere
BIKER T
  • 909 Answers
SOURCE: Freezer is producing"snow" and freezer burning everything
AFTER A DEFROST,HAVE A GOOD LOOK AT THE DOOR RUBBER. IT MUST BE 100% SEALED FOR A FREEZER. (SHOULD ALSO HEAR A SLIGHT VACUME WHEN DOOR IS SHUT WHEN UP NTO TEMP).ALSO MAKE SURE MOTOR IS SWITCHING OFF AT +/- 20C (TEMP).IF ALLOWED TO RUN CONTINUOUSLY TEMP WILL PULL DOWN TO CREATE EXCESS FROST.
Posted on Jul 20, 2007
duby1990
  • 370 Answers
SOURCE: ice forming in freezer refrigerator not getting cold
Replace your heater and thermostat behind the back wall of the freezer. the air will not flow from the freezer to the fridge because of all the forming ice. Also replace the defrost timer. take your model number into a local parts store and they can get you the parts. This is very common!!!!! But pretty easy to do.
Posted on Nov 20, 2008
aasc
  • 1606 Answers
SOURCE: I have a 3 year old GE side by side that isn't cold.
Sounds like a defrost problem or an evaporator fan problem . I would suggest you have a professional check it for you to find the problem and then do the repair yourself . If the fan isn't working , probably a main control board problem and not the actual fan ,which is costly . Also , possible thermistor problem which takes experience to diagnose . Buying parts without knowing which is bad can be realy costly on GE refrigerators .
Posted on Jul 14, 2009
projdoc
  • 2237 Answers
SOURCE: Ice despencer opening keeps freezing and wont dispence
you have a bad door seal. replacement is better than repair. warm moist air is getting in and the condensation is freezing.
Posted on Nov 13, 2009
SOURCE: it's snowing in my freezer!
do you ahve the answer for the above problem, and can it be fixed? If so how?
Posted on Dec 26, 2009
My gsl25jfxblb GE side by side ice maker won't stop making ice. It overflows out of the bin and fills the shelf below with ice. Then when we open the freezer door to remove some food, ice spills...
no idea yet but many years back we had one that froze my wifes feet at 5:30 am when she opened the freezer to get ice for coffee and the freezer was full of water .
Mar 20, 2015 | GE Refrigerators
How do I defrost my frozen freezer?
the defrost circuitry is not defrosting the unit due to a defectice defrost heater,thermostat or adc control,shut it off and let it defrost manually or use a hand held hair dryer to assist in the manual defrost,then remove the inside back wall cover in the freezer in there you will find the defrost heater and thermostat,have towels handy as when you manually defrost it you will have a lot of drainage and the catch pan in the back that catches this water will most likely overflow
Jan 31, 2013 | Maytag MBB2256G Bottom Freezer...
Hi fridge was not staying cold so i looked at the coils in the freezer and they were cover with snow(ice), I melted the snow and ice and it worked good for almost 2 weeks then started getting warm again...
Its definatly a defrost problem. The reason it stopped cooling is because there was no air circulation do to the ice build up. For the most part the part you'll need t replace is called an adaptive defrost control, the part number for it is 12002104. This part is located in the refrigerator side of the machine, above the heading so you'll be taking the hole top down to put it in. Take your time and it won't be hard.
Nov 10, 2010 | Maytag MSD2756G Side by Side Refrigerator
Started leaking water out the freezer door and ice was melting last nite... bad timing we just got a snow storm here in NC last nite. Seems to be running but food is defrosting. Its a GE Side by Side about...
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jan 30, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Nov 13, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
SNOW FORMING IN FREEZER
Could be a number of things. Is the fan running in the freezer section, are the door gaskets sealing completely, even on the bottom of the doors? Could be a defrost issure where the thermotat is allowing it to over heat during defrost and the the cooling cycle starts after defrost and forms the ice an snow from the moisture in the unit.
Dec 30, 2017 | GE Profile 21.6 cu. ft. Side-by-Side...
It's snowing in my freezer!
it's not the filter. is there frost on the inside lower back of the freezer. or is it around the edge of the door are your ice cubes fuzzy can you here the fan running in the freezer
Jun 27, 2009 | KitchenAid Superba Architect KSCS25INSS...
Snows inside freezeer compartment of side by side
You actually have 2 problems here.
One the ice maker shutoff is defective. REPAIR is to replace the ice maker.
Two (snow) is a loose door seal, Outside air entering the freezer.
Feb 20, 2009 | Kenmore Refrigerators
Ice forming in freezer refrigerator not getting cold
Nov 20, 2008 | Whirlpool GS6NBEXR Side by Side...
Jul 07, 2007 | Whirlpool ED2FHEXN Side by Side...
Whirlpool ET1FHTXM Top Freezer Refrigerator Logo
74 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
