Question about Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel mw511
Help the lights keep on flashing (water temp) hot and cold this happens once the water reaches its level what does this mean ?
    Problem Solver:
  • 14 Answers
Temp sensor is bad or dirty with hard water deposits
Posted on Feb 22, 2009
  • peran82 Mar 12, 2011
    ive got the same problem how do you fix it??
Kenmore 44832 hot water won't stop.
If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve Adefect in the water-inlet valve may mean that it's no longer able toshut off completely when the electricity has been turned off to it. Ifthis occurs, the valve may leak and drip water into the clothes tub. Intime, the water may accumulate substantially. If this happens, you needto replace the valve.
Water-level switch Adefect--or an obstruction--in the water-level switch may mean that itcan't tell the water to shut off. So the machine overflows. This switchsenses the water level in the clothes tub. It's usually a diaphragmdevice with a small, clear tube attached between the switch and thebottom of the washer's outer tub. As the water level in the tubincreases, the pressure on the air in the tube increases. When thepressure reaches a certain level, it activates the switch, shuts offthe water, and signals the timer to begin the agitate cycle. You caneither clear any obstruction in the tube or replace the water-levelswitch.
Aug 03, 2008 | Kenmore 44832 Front Load Washer
Mitsubishi shogun 1998 model 2.8 over heating no leeks water is blowing back into the overflow bottle when hot
How are you sure it is overheating? Temp gauge? Most likely are stuck thermostat, bad fan thermostat switch, bad fan. bad head gasket. Coolant going into overflow when hot is how that system is suppose to work. As it cools, fluid is drawn back into radiator. It it is not really overheating, bad radiator cap can allow coolant into reservoir more than normal.
Dec 31, 2014 | Cars & Trucks
Er3 flashes hot water will not reach set point
Had this happen to me before, if you have hot water from the boiler going in and out of the boiler mate and the temps are not rising within the hot water means more than likely you may need to remove exchanger and clean sediment off element, basically sediment creates a blanket over the heat source causing poor thermal conductivity. Things to check before removing heat exchanger
- outlet temp of boiler water to aquamate -inlet temp of boiler water to aqua mate= 20-30'F if low then bad thermal transfer or poor water movement
-make sure sensor is reading properly
- get boiler temp higher to speed up thermal gain in water heater
Jan 19, 2014 | Amtrol 2704E76 41 Gallon WH-7C BoilerMate...
Mw511
The MW511 are 24volt solenoids.
Jun 10, 2013 | Fisher and Paykel GWL11 Top Load Washer
Cold water intake just tricking
calcium build up clean inlet lines and screens
Jan 20, 2018 | Fisher and Paykel Washing Machines
Fisher and paykel MW511 pride model lights 3, 4 and 8 comming up
That is fault code 49
Here is fault code info.
49.
(00110001) Cold Valve or Cold Valve & Hot Valve Faulty
The Motor Control Module has measured a voltage from the valve diagnostic circuit that
indicates the cold valve or both the cold and hot valve is faulty. The most likely cause is
that the valve harness has not been connected correctly or the valve(s) is open circuit.
Primary Source: Wiring.
Action: Check the valve harnesses are correctly fastened to the valves and
the motor control module or the pins are not bent backwards.
Secondary Source: Water Valves.
Action: Measure the resistance of the cold and hot valve coils.
Tertiary Source: Motor Control module.
Action: Replace the Motor Control module.
Oct 23, 2012 | Fisher and Paykel Washing Machines
Cold water valve?
Replace the inlet valve. This is a common fault easily fixed with a new valve.
Apr 07, 2017 | Fisher and Paykel GWL11 Top Load Washer
F & P MW511 Washing Machine ... Driving me Mad ... Please Help!
Size setting
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size.
The cold water temperature LED identifies 5kg.
The low water level LED identifies 6kg.
The hold spin speed LED identifies 7kg.
If the product has not been setup before all 3 LEDs will be on.
To set the size for 5kg push the wash temp up button then
the power button.
To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button.
This locks the size
into memory. To check the size is set, start a cycle.
Aug 16, 2012 | Fisher and Paykel Fisher & Paykel Washer
Fisher Paykel Smartdrive MW058K stops during cycle and hot and cold water temp lights flash along with progress light
This means that the machine can't get any water or enough to wash with.Check to see taps are on hoses for kinks and filters in water hoses are not blocked.
Jul 24, 2012 | Fisher and Paykel Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
618 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
