Question about Fellowes P600C-2 Shredder
Fellowes P600-2 doesn't do a thing in foward will work in reverse
Motor will go in rerverse but red light comes in foward shred and will not go
I wish the manual said to clean the sensors. I had the whole thing apart. Cleaned her real good. Put it back together. Still a red light indicating a paper jam. I read this post, really helpful! Cleaned the sensors. We are back up and running!
Dec 03, 2013 | Fellowes Powershred 420 Shredder
My 1978 firebird want reverse it goes foward in all gears including nuetral what could be the cause of this and how can i repair?
It moves in neutral or just rolls freely?
You can check your fluid level. If its low, add to it. Does the shifter/linkage seem to click into the correct gears?
Other than that could be internal things like a sticking valve in the valce body, work reverse input clutch, bands, etc..Things that will require the transmission to be removed and taken apart.
Sep 02, 2011 | Pontiac Firebird Cars & Trucks
When plugged in and turned on, both the red and green light come on and it does not work forward or in reverse
I own a Fellowes PS 60 shredder.
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Mar 27, 2011 | Fellowes Powershred PS-60 Shredder
My fellows jbo1 jamed and then stopped running is there a reset buton?
Chances are it's over heated.
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds. Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled. See oiling instructions below.
From fellow's website: http://www.fellowes.com/fellowes/site/support/support_troubleshooting.aspx#jammed
Dec 15, 2010 | Fellowes Office Equipment & Supplies
Won't shred
you have to replace the main power switch
Mar 31, 2009 | Fellowes Manufacturing FEL36055 Powershred...
Fellowes powershred 320
seems to be an issue with the paper feed sensors i suggest you call Fellowes customer service. 1-800-945-4545
Mar 09, 2008 | Fellowes Powershred 420 Shredder
Fellowes P600C-2 Shredder Logo
134 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
