Question about Hayward Navigator Pool Cleaner
Navigator hose cntinues to twist
I have otally disassembled and cleaned the gear box. It appears to run smoothly with air pressure and when manually turned. Beaings were replaced due to breakage of plastic bearing carriage.
  • flowersdad Mar 01, 2009
    i have same problem and nicenelson
  • 25 Answers
I would recommend replacing the gearbox. That's what controls the turning so, if it's not turning correctly, that's the cause. It could also be the hoses. You could change the order of the hoses and that might help.
www.cpo2go.com
Posted on Dec 03, 2010
Turbo refuses to supply power when accelerating. Manual gear changing necessary to attain top (6th) gear.
The car goes in "limp home" mode:
After scanning the Engine Control Module (ECM) with a VAG or similar diagnostic tool you will find this: Fault code: P1557-Turbo Boost pressure control exceeded
1. Engine stopped and ignition switch off. Check all pneumatic connections and hoses between turbocharger actuator = pressure unit for boost-pressure control, boost-pressure control solenoid valve, vacuum reservoir, EGR control solenoid valve, intake-manifold flap solenoid valve, EGR valve with throttle - part of intake manifold. Also the vacuum connection between tandem pump and brake booster. If you find something wrong replace parts. If not go to step 2.
2. Extract the hose of the turbocharger actuator = pressure unit for boost-pressure control part of turbocharger. Instead of the original hose you must place another 1 meter long hose with the same inside diameter, and then you check to inspire yourself the air from the other one extremity of this hose. The mechanical connecting rod of the turbocharger actuator must have a smooth and whole motion. If you can do that with your mouth, then you must replace the boost-pressure control solenoid valve. If you can not reach this with your mouth, then you go to step 3.
3. This is the most difficult work. The problem is that the soot particles deposits inside the turbocharger plugging the variable nozzle geometry mechanism = adjustable vanes of the turbine. If the turbocharger actuator is not able to adjust the turbine vanes the charge air pressure increase too much and ECU (engine control unit) go in "limp mode" = engine protection software. As a result the "limp home" mode engine still running until you turn the engine off (ignition switch off) and back on when the "limp mode" is deactivated, but the fault still remain in ECU memory!
4. You must be able to extract the turbo from the engine and then to disassemble the turbocharger, clean inside adjustable vanes mechanism and refit all.
May 24, 2011 | Volkswagen Passat Cars & Trucks
My navigator works well until it reaches the deep end at the upward curve and will basically stop at that point....if i manually push it it resumes its course but gets stuck again at the upward curve. it...
I would first check the water flow with your water flow gauge. If it is too high, you can use a restrictor plate that may help you get your correct coverage back. If it is too low, that means its a problem with your pump, not the cleaner. Check your shoes and wings. If they are worn, it could cause the pool cleaner to not be able to climb properly. If it has always had this problem, it could be that your hose is too short and it cannot reach all points of the pool effectively. You can buy additional hose sections if this seems to be the problem. A few more things to try: check and clean your rear screen, make sure that your cone gear is free and rotates smoothly in all directions, and check your gear box to make sure that it doesn't need to be repaired or replaces.
May 23, 2011 | Hayward Navigator Pool Cleaner
Hose getting twisted
It could be a steering error that is causing it to tangle the hose. Try these suggestions first. Check and clean the rear screen. Make sure that you cone gear is free and rotates smoothly. Also check your turbine and spindle gear assembly. You will also want to try readjusting your return lines to redirect your cleaner. A common problem with these pool cleaners is that the return lines are directing them to circle, causing the hose to tangle. Finally, make sure that you are storing the hose in a NON-coiled position. If you coil the hose, it will cause it to be permanently bent and interrupt movement. If you have done this, lay the hose out flat in the sun for a few hours to help mold it to the original pattern.
Apr 29, 2011 | Hayward Navigator Pool Cleaner
New pool cleaner , pool hose just keeps twisting up have laid in sun, but as soon as connected back up it twists
Is the pool cleaners hose actually twisting in the pool or before you put it in? If it is twisting outside of the pool, it might still straighten out when you put it in the water. It it is twisting in the water, you might need to add some additional hose lengths to help it operate smoothly.
Feb 26, 2011 | Hayward Navigator Pool Cleaner
Navigator gets hung up at curve going up the pool walls. It has plenty of suction, new rubber feet, clean pool filter running at 3000 rpm,turbine is moving freely with no debis, all suction going to...
You have check all of the things that I would usually recommend when these pool cleaners are moving properly. My additional suggestions would be to make sure that your hose is not too short (adding lengths of hose if necessary) and to check for steering failure. Check and clean your rear screen, make sure that your cone gear is operating smoothly in all directions, and clean, repair, and replace (if necessary) your gear box.
Feb 06, 2011 | Hayward Navigator Pool Cleaner
Gets stuck behind the ladder
It could be one of several problems with these pool cleaners: check your water flow and adjust if necessary, check for worn shoes and wings, make sure that you have proper hose length, and check for steering failure. Steering failure can be caused by several things. Make sure the rear screen in clean and free of debris. Make sure your cone gear is free and rotates smoothly. Check your gear box and clean or replace if necessary.
Dec 24, 2010 | Hayward Navigator Pool Cleaner
Navigator Pool Cleaner: When I run my hayward cleaner the hose twists up a...
You have either a bad or stuck gear box or a loose or damaged a frame bearing. The gear box controls turning and the a frame controls propulsion, but one bad bearing will cause the cleaner to move more in one direction, causing the hose to coil. You can hold the cleaner under the water by the top of the hose, and it should turn in all directions within a few minutes. If it doesn't, then it is the gearbox. If it does, then likely a problem with the a frames.
May 16, 2010 | Hayward Navigator Pool Cleaner
Navigator Pool Cleaner: My Hayward pool cleaner just goes in small circles...
Check all of the following. Ones of these issues is probably causing your pool cleaner to go in circles. Let me know if these soultions don't work and I will be glad to offer more solutions, but I a think one of these might solve your problem:
1. You might not have proper water flow. Too much or too little pressure will cause this to happen. Check the pressure with your flow gauge and adjust if necessary.
2. Check for a partial blockage of the navigator throat. If you have a blockage, it could disrupt the movement of your cleaner. Clear blockage if necessary.
3. Check the shoes and wings. Damage or wear to them can disrupt your patterns of cleaning. If you notice that your shoes or wings are worn, replace them to correct the problem.
4. Check to make sure that your hose is not twisted. It should be clear of kinks, twists, and knots. Untangle if necessary. Laying the hose out in the sun will make it more pliable and easier to untangle if you need to do this.
5. Other things that could cause steering issues: check and clean the rear screen, check to see that the cone gear is is free and rotates smoothly, clean/replace/repair gear box, check pod connection, and check turbine and spindle assembly.
Hope this helps! Let me know if you need clarification or additional help!
Navigator only turns one way, twisting up the line
Try one of these soultions. If you try these suggestions and it still doesn't work correctly, let me know and I will offer some different ideas. With this brand of pool cleaners, troubleshooting is usually pretty simple.
1. You might have an improper water flow that is causing your trajectory to falter. To remedy this, check your water flow with a flow gauge and adjust as necessary. If you have too little or too much pressure, you cleaner will not move correctly.
2. Look for a blockage in the navigator throat. If you see one, remove it. A blockage on one side could cause the cleaner to only turn in one direction.
3. Check for worn shoes and wings. Replace if necessary.
4. Check and clean the rear screen.
5. Check to make sure that the gears are clear and they they rotate smoothly in both directions.
6. Clean, repair, or replace the gear box.
7. Check turbine and spindle gear assembly, as well as all connections, and make adjustments as necessary.
May 05, 2010 | Hayward Navigator Pool Cleaner
Hi my navigator only turns to the left and after an hour or so the hose is all twisted up and it cant move
This is probally in the gear box in the top of the unit. Most pool shops will rebuuild the cleaner for you for just the price of the parts or a small shop fee. They can check for any other problems at the same time.
Jul 11, 2009 | Hayward Navigator Pool Cleaner
Hayward Navigator Pool Cleaner Logo
1,277 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Craig Butler
Craig Butler
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
