Question about Breadman TR2200C Ultimate Bread Maker
Bread pan pops out during kneading, hard to remove after baking
I have used my new machine twice. Both times the bread pan pops out during kneading. I re-seat the pan and everything runs smoothly. Once the bread is done baking and I try to remove the bread pan I can't pull it out. I have tried bending the side clips and ultimately (with a lot of force) I just end up yanking the thing out. I am worried I am going to break the machine. Is this normal? The manual says I should be able to easily remove the pan. Is there something I am supposed to do before removing the bread pan?
  • Anonymous Feb 24, 2009
    I ahve had the same problem but only with certain types of bread recipes. Usually the heavyier ryes. I also bent the side clips and seem to have found a reasonable position that is not too far up to make removal work OK. Trial and error, just like the breads!
  • Anonymous Mar 08, 2009
    I have had my Breadman Ultimate TR2200C for about 5 years and use it 1-2 times/week. Recently, the pan starts popping out during kneading and keeps popping out frequently. I practically have to stand and hold the pan in now. Can the clips be replaced or will I just have to figure out how to bend them?
I have Breadman Ultimate for over 12 years now. I make bread 2-3 times a week for the past 10 years. I found that the bread pan popping out only happens when the motor shaft and the kneading paddle are not tightly engaged. I find this problem in the following two scenarios: 1. The bread pan was not pushed down all the way as described by cassie_hobbs and tlcquiltnut. 2. Debris filled up the motor-shaft bowl underneath the bread pan to prevent a tight engagement of the motor shaft and the kneading paddle. These debris are generated during the kneading process; part of the ingredients is pushed out of the shallow horizontal pan and accumulated underneath. To avoid the problem, I have to periodically remove debris from the shaft bowl and make sure the pan pushed all the way down. To reduce the debris, I made a simple cover for the bread pan by cutting an old aluminum baking dish. I always remove the cover after the kneading cycle to prevent the rising dough from reaching the bottom of the cover. Hope this helps. Wendy
Posted on Apr 15, 2009
Recently my bread pan started twisting out of the metal clips especially on the right side. I pulled out on the clips which caused the pan to pop up entirely during kneading. I thought this would increase the tension holding the pan in, but it just made the problem worse. So, I pushed the clips inward toward the baking chamber walls. It seems to have solved the problem of the pan twisting out of the clips and jumping up. It's stayed in place so far for 2 loaves.
Posted on Mar 17, 2010
  • 66 Answers
Another possible reason for this problem could be the same one we had with our machine . The shaft in the bottom of the pan was seizing up. It finally stopped completely last week when my wife was attempting to make bread. Fortunately we have another machine (actually 2), so we transferred the dough mixture to it and I proceeded to start hunting for a new pan. Took a bit of hunting, but I found that brand new pans can be ordered fron Fox Parts Store at foxpartstore.com or you can call them at 1-800-738-0245. the new pan is only $14.95 and free shipping!
Posted on Oct 07, 2010
This happened to me once on a very dense bread. I have discovered that when you put the pan in, there will be a second click. I have not had a problem since.
Posted on Mar 01, 2009
    New Friend:
  • 3 Answers
Another possibility is that the two prongs that couple the motor in the base with the rotor in the baking pan can slightly bend when kneading heavy breads. This slant can create a force that pushes the pan upward while kneading. This is the same principle as rotating a vertically mounted screw causes it moving up or down. A simple solution is to use pliers to slightly bend the prongs in the direction of rotation to make them exactly perpendicular to the rotation plane. The prongs should be visible when the baking pan is removed. There is a well in the center of the base and inside that well there is an S shaped blade mounted on the spindle of the motor, which the ends of the S bent at 90 degrees upward. Those two ends push the two arms of the rotor in the baking pan. You should first determine the direction of the rotation by starting the machine (it is clockwise in my machine), and then grab each upward end of the S-blade with pliers and bend it slightly in the SAME direction as the assembly rotates.
Posted on Feb 16, 2014
  • Wojtek Sokolowski
    Wojtek Sokolowski Feb 16, 2014
Why the tub disengage during knead cycle
This may help solve your problem:
Bread pan removal:
I am assuming you have the type of bread machine that has
the little metal spring clips inside the oven compartment. Before inserting the pan always check on the
bottom of the pan (underneath) to see how the impeller "T" is aligned and turn
it with your fingers or turn the paddle with your fingers so the "T" will fit
into the gaps of the impeller in the bottom of the oven. Once you have aligned them then place the
pan in the oven and "pop" push the pan in place so the spring clips grab the
matching clips on the sides of the pan.
Also look to see if your pan has the word "front" stenciled in the lip
edge of the pan. If so, be sure that edge is towards the front of
the machine. If your pan still won't pop into place when you
push down your spring clips may need to be gently pulled out because they can
become "slack" over time. Take the pan
out and reach in and pull each spring clip up until you start to feel it bend a
little and bend them out. Pop your pan into place and if the clips don's start
to grab your pan repeat the process of bending the clips out and repeat that
until they do. Summary:
1)
make sure if your pan is marked "front" that it is aligned
properly
2)
make sure the paddle and the T underneath the pan aren't in
conflict with the matching drive impeller in the bottom of the oven. Just turn the paddle so they are opposite of
each other and can engage
3)
Restore the "springiness" to your clips by bending them out
with your fingers. Be careful though because the spring edges are fine edges so
get underneath them when you pull up
For bread machine parts, good used bread machines etc. visit
breadmachineshelp.com
Jul 01, 2013 | Kitchen Appliances - Others
Bread pan comes loose and bangs around during kneading cycle--how to fix?
Hello....I wrote this for those with bread pan problems....be sure to read the part about how to restore the "spring" of your bread pan clips...
Bread pan removal:
I am assuming you have the type of bread machine that has the little metal spring clips inside the oven compartment. Before inserting the pan always check on the bottom of the pan (underneath) to see how the impeller "T" is aligned and turn it with your fingers or turne the paddle with your fingers so the "T" will fit into the gaps of the impeller in the bottom of the oven. Once you have aligned them then place the pan in the oven and "pop" push the pan in place so the spring clips grab the matching clips on the sides of the pan. Also look to see if your pan has the word "front" stenciled in the lip edge of the pan. If so, be sure that edge is towards the front of the machine. If your pan still won't pop into place when you push down your spring clips may need to be gently pulled out because they can become "slack" over time. Take the pan out and reach in and pull each spring clip up until you start to feel it bend a little and bend them out. Pop your pan into place and if the clips don's start to grab your pan repeat the process of bending the clips out and repeat that until they do. Summary:
1) make sure if your pan is marked "front" that it is aligned properly
2) make sure the paddle and the T underneath the pan aren't in conflict with the matching drive impeller in the bottom of the oven. Just turn the paddle so they are opposite of each other and can engage
3) Restore the "springiness" to your clips by bending them out with your fingers. Be careful though because the spring edges are fine edges so get underneath them when you pull up
For bread machine parts, good used bread machines etc. visit breadmachineshelp.com
Apr 01, 2013 | Breadman Tr2500bc Ultimate Plus 2-pound...
The pan on my Wel-bilt ABM3100 "jumps" out of the seating during the kneading cycle. I can hold it in place (for 33 minutes...) and it works just fine. Pretty sure there's a better way.
I had the same problem. I soaked the inside and underside of the pan (where it connects) with vinegar for 40 min. then scrubbed area with toothbrush. where it connects. I also scrubbed the part that holds the pan in unit with vinegar and toothbrush. It works properly now. It just needed "descaling" so to speak. Good luck!
If that doesn't work, call the mfg. for advice.
Aug 28, 2017 | Welbilt Bread Maker Machine Pan Abm3100...
Why did the kneading paddle on my 1148X bread machine quit working. This happened the third time it was used. It did the initial mixing and resting. When it started the kneading process again, the blade...
Hi, If this is the third time using it, it could be defective. Return it for service. If not under warranty, try a few things. 1) Make sure the pan is inserted in the machine correctly. 2) Make sure that the paddle is not sticking, or the sealed bearing on the bottom of the bread pan is not broken or frozen. (Take pan out and see if you can turn the paddle freely by hand). Or finally, the belt may be loose and slipping, especially when it takes more power to knead the dough the second time. Good luck...Hank
Jun 12, 2010 | Toastmaster 1148X FastBake Bread Maker
The bread machine will not knead m I have made sure it is connected right and even started over with a new batch, it makes the nosie like it is trying to work but will not knead.
Hi, A few things may cause this problem. Make sure the bread pan is inserted correctly in the machine. If ok, then take the bread pan out of the machine and see if you can turn the paddle by hand. It should turn nice and smooth, If it sticks or does not move then the sealed bearing that the paddle spins on has failed. If that's okay then keep the pan out of the machine and start a kneading cycle. Look through the lid window and see if the motor shaft is turning smoothly. If no then the belt is loose, broken, or has fallen off the pulley.. Good luck Hank
Jun 04, 2010 | West Bend 41077 Just For Dinner¿...
Panasonic SD-250 not mixing. Pan was submerged in water.
Hello LT,
There is a sealed bearing and shaft on the bottom of the bread pan that the paddle sits on. Submerging the whole pan in water may have caused water to seep into the bearing on the bottom of the pan, or the whole pan might be worn. Slight resistant in 2 places on 360 degree is not bad. Let everything dry out and we will try a few things. First, put the paddle in the empty pan and place it in the machine. Start a kneading cycle and look trough the lid to see if the paddle is spinning freely and with smooth motion 360 degrees. Watch it until you are sure it will run freely for the entire cycle. If it does not run freely, stop the machine and take the pan out. Now start the kneading cycle again with the pan out and look at the motor shaft at the bottom of the machine to see it it is running freely. If it is running freely, then the problem is with the pan, and the pan needs replacement. If the motor shaft is not turning freely, then the belt is slipping in the machine and needs to be replaced. If everything runs smoothly check the kneading time to make sure your mix has enough time to knead correctly. Hank
Nov 14, 2009 | Panasonic Kitchen Appliances - Others
Bread pan pops out during the kneading 2 cycle
I had a similar problem after using the same machine for several years. It worked well for years and then popped off the shaft whenever I had a rather stilll dough. To solve the problem I bent the clips on each side of the bread pan that hold the pan into the machine up and toward the center of the machine. I did not use any tools to do the bending. It solved the problem. The pan no longer jumps up out of the clips and off of the shaft.
Jun 02, 2009 | Breadman TR2200C Ultimate Bread Maker
TR440 Breadman won't begin kneading once "start" button is pushed
Hi Mindy.......it takes 30 minutes to PREHEAT this silly machine for wheat bread. I thought I did something wrong, too........I stopped it twice after it preheated for about 15 minutes. I did not want to waste anything so I let it stay in the machine.....I just went to check the machine and it started after 30 minutes of preheating.
I wish they would mention this in the book!!!
Julie from TX
Jan 11, 2009 | Breadman TR875 Bread Maker
Me too! I have to bend the two metal pieces on the sides out before every use - they are pretty flexible, you won't break them. Just bend out and they hold the pan in for a use or two. Not an elegant solution, I admit, but it works.
Dec 31, 2008 | Breadman TR2200C Ultimate Bread Maker
Bread pan jumps off of its fastener clips.
I have the answer to the TR2500BC pan popping off the base!! My husband and I made a loaf for testing the jump off. Ah HAH! I set the pan in, ok. felt it was down all the way. When it started to knead the ball and stop to reverse...it popped off. We looked at the side hook on top. ok. It popped off again. It was when my husband made sure the two tabs on the under side of the pan was in the opposit direction of the two buds in the base. at that point you MUST set the pan down with force until you get that distinctive click, click. Rock the pan front to back a bit as you push down. It has worked every time since I started that process. I make two loafs of bread a week with no problem of it hopping off. ENJOY.
Oct 09, 2006 | Breadman TR2500BC Bread Maker
Breadman TR2200C Ultimate Bread Maker Logo
2,069 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
