Question about HP LaserJet 3330 All-In-One Printer
I have a HP Laserjet 3330 prints just fine but won't copy. It lights up will start to scan then stay on one side and lock up. I took it to a repair man he said that the ratchet is broke. What does that mean? And can it be fixed? And how could this have happened?
  • Anonymous Mar 06, 2009
    I have the same problem as above, the scanner bulb keeps to the left and wont reset. I have opened the unit but cant see anything obvious that is broken.. Some one said that you can buy the scanner bit separately but is it worth it, I'm going to sell it on ebay as spares..
    An expert whose answer gotĀ voted for 100 times.
  • 121 Answers
Ok, The scanners on these things rely on "seeing" if you will, the end of there travel across the glass. If they can't "see" where they are supposed to stop they try to keep going, reaching the end and causing the noise you describe. The noise is the toothed belt slipping on the pulley that drives it. There is no Ratchet.
Try this:
Should be two pieces of glass the big one and a smaller strip to the left.
Remove the strip I'm pretty sure it is one screw and a latch that slides to one side to remove.
Clean the glass.
Get the scanner assm. over to the opening. pretend to copy or by hand with power off.
Gently wipe the scanner bulbs and use a Qtip to clean the mirrors below as best you can.
At the end of the scanner assm. (Front of Machine) you will see a piece of glass kind of pointing at you. It looks like it shouldn't be there. Clean this it is the "EYEBALL"
this has worked for me.
Hope it Helps
Posted on Mar 11, 2009
HP LaserJet 3330 will not print multiple copies
Does this happen only with some documents/software? I have a different HP printer (a LaserJet) that does the same thing only with PDFs printed from another program. (This happens with PaperPort and browsers using the Adobe Reader plug-in, for example.) If I open Adobe Reader and then open the document in question, I can print multiple copies correctly.
I hope this helps.
Jun 14, 2012 | HP LaserJet 3330 All-In-One Printer
HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
HP 3330 Scanner is very slow
PDF files are notoriously slow to print. You might invest in more printer memory.
Jan 16, 2009 | HP LaserJet 3330 All-In-One Printer
HP Laserjet 3330 with Windows Vista
no you cannot print on both sides have to give the prints 2 first the paper will print on 1 side then insert the same paper in the printer and give the remaining printout and it will print on the back side of the same you can do it manually but the automatic printing on both side facility is not in HP Laserjet 3330 printers.
Sep 29, 2008 | HP LaserJet 3330 All-In-One Printer
HP LaserJet 3330 All-In-One Printer Logo
93 people viewed this question
Ben Johnson
