Question about Kenwood VR-406 Receiver
Can't get sound from speakers on kenwood vr406
Had this problem before. there is some combination of settings that fixes the problem, can't remember it. Speaker wires are good, connections all good. i recall it having to do with manual versus auto setting.
  • james577 Mar 20, 2009
    NO SOUND ON KENWOOD VR 406
    Scholar:
  • 93 Answers
This is a input mode problem, such as a analog or digital source input selection, if you are using a analog source and the receiver is in the digital input selection you will not pass the signal,and vice versa,
Posted on Feb 22, 2009
I have an alpine mrv-f307 4/3/2 channel. I have it hooked up to 2 12in Kenwood subs. Right now standard 2 channel each sub having their own. I heard doing a series hook up and bridging the subs to the amp ...
Bridging an amplifier refers to combining the power of two channels to run one speaker at higher power. If it is wired correctly, your amplifier is running with 4 channels bridged into 2 speakers now.
Mar 11, 2015 | Kenwood Car Audio & Video
I have a 2001 chrysler voyager installed a kenwood stereo and when i raise the volume to where its lound the radio will turn off and on untill i lower the vol
My electronics savvy source says you may be overdriving the amplifier in your Kenwood stereo to an impedance-mismatched set of speakers, meaning that the speakers are impedance mis-matched to the Kenwood stereo, and therefore operate ok (but inefficiently) at low volume, but cut off completely at higher volume.
Fix: match the impedance of your speaker network to the specs on your Kenwood car stereo. Once this is done, you should be able to crank up the volume to the point of permanent hearing loss.
SAFETY CAUTION - sound levels above 85 decibels produce NIHL (noise-induced hearing loss).
http://www.dangerousdecibels.org/education/information-center/faq/
Oct 18, 2011 | Kenwood Car Audio & Video
Hi, My friend (who has a visual impairment) moved house recently, they own a Kenwood KR - V5570, I assisted with re setting up PC etc. I am now baffled with connecting her left and right speakers to this...
If you keep guessing you may succeed in blowing something up.
The cables have RCA connectors or bare wires for a reason.
Get the manual out and read it.
Register and download it for free at retrevo.com
http://www.retrevo.com/support/Kenwood-KR-V5570-Receivers-manual/id/479bh938/t/2/
Don't pay too much attention to the actual colors of speaker wire. Use the colors as reference. Each speaker has a plus and a minus. Connect them to corresponding plus and minus for their respective amplifier outputs.
Jul 04, 2011 | Kenwood KR-V5580
I'm having trouble with sound when i try and install a surround sound system. This is the second system I've had that my lg would not play sound
Firstly you must have the remote typically to set the speakers up or there is a combination of keys to do this but usually some functions cannot be changed without the remote.
Second, the surround sound playback can only be played if the sound that you are listening to has the surround sound track, otherwise you may not hear hardly anything when your device is set to the wrong function.
The speakers must also match the surround sound system otherwise you may not hear anything at all.
Remember: A 5.1 System is 5-speakers,   A 7.1 system is 7 speakers!
The speakers should be marked for which place they belong LF= Left,Front...etc.
Jun 12, 2010 | Audio Players & Recorders
There are many different "listening modes" integrated on my Kenwood VR-7070 6.1 channel receiver. But i only get both front speakers to work when in "mono" mode. Is there an easy fix?
There is not a "fix" for this selection, MONO is basically a single channel output so there is no seperation for various speakers like left or right which is a stereo effect, mono is like a single speaker sound so you are fortunate to have the sound from 2 speakers but they deliver the same sound.
Jun 10, 2010 | Kenwood VR-7070 Receiver
Keeping it on
The User Manual says this is a result of the power being removed while the unit is still on. In order to reset this you need to:
1. Unplug the unit
2. Press and hold the the power key
3 While holding the power key, plug the unit back in.
This clears the units memory so you loose and settings you have set but the unit works again.
Hope this helps.
Oct 19, 2008 | Kenwood VR-406 Receiver
I have a kenwwod AX-7 home theatre systems. the right side top speaker (tweeter) on one side does not work. i'm thinking there is a fualt with the amplifier on the right side.
If the only problem is the tweeter, and the woofer is still working, you do not have a problem in the amplifier. The problem is the speaker. The tweeter is blown or you have a problem in the cross over network in the speaker.
You can always switch the speakers and connect them to the opposite channel. You can do this very easy at the back of the receiver where the speaker wires are at. Put the left speaker wires on the right speaker and the right speaker wires on the left speaker. If the same speaker still has no tweeter you know that the speaker is the problem.
The only way this could be a problem in the amplifier is if you have two different sets of inputs for each speaker, one being the low end for the woofer and the other being the high end for the mid range and tweeter. That would mean you have two sets of speaker wires going to each speaker. Each set of speaker wires would have a positive wire and a negative wire for a total of 4 wires going to each speaker. I don't remember this system being set up that way, but I could be wrong.
I hope this was helpful, you should be able to get the speaker fixed at an authorized Kenwood repair center in your area for a reasonable price. As a guide, my shop only charges $25 for the labor plus the cost of the tweeter to replace a tweeter. Any other shop should be similar. Kenwood does sell replacement drivers for almost all of their speakers.
Jun 21, 2008 | Kenwood Audio Players & Recorders
Kenwood audio equipment
If it was mine i'd want $200-$300 if in mint condition. Try a classified in the local paper or online ads.
Sep 11, 2007 | Kenwood 2 10 " SUBS SUBWOOFERS 500W POWER...
Kenwood VR-406 Receiver Logo
238 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
