Question about Whirlpool GU2400XTP Built-in Dishwasher
Well into the wash cycle, the START/RESUME light begins blinking. When I push the button, the entire cycle starts over again. Not exactly saving me any water ETC. Help?
  • 188 Answers
Are you sure the cycle is starting from the beginning? It sounds like the latch strike is not engaging the door switch enough. Try gently bending the latch downward but not too far so it doesn't hit the door when you close it. If that doesn't work it could be the door switch , the console assembly or the electronic control.
Posted on Feb 22, 2009
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Tough scrub plus button blinking
I have the dishwasher working again. Now I have a problem because while checking things out I took out the pump sump support bracket part w10300599 and I don't know where to put it back in. Does anyone have a picture of this installed?
Sep 12, 2012 | Maytag Jetclean Plus MDB6769AW Built In...
I have a gsd5610 and my drying button is blinking.the unit will not start
Someone opened your DW during last washing cycle. The Machine paused but no-one pushed the button to resume the cycle. It's still waiting for you to tell it to finish last cycle. Press your PAUSE/Cancel button 'til the light goes off. Then use your machine as you normally would.
Hope this info was helpful to you. Good Luck! :-)
Jan 31, 2010 | GE 24 in. GSD5930 Built-in Dishwasher
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore 15912 Built-in Dishwasher
Control panel lights blinking
I have the same dishwasher with the same problem, try pushing the delay/resume button, then the drain/off button. When the lights go off start your wash cycle.
Sep 17, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Which dishwashere auto resume wash cycle when door is closed?
All the tall tub dishwashers made by Whirlpool (inc. Kenmore and Kithcenaid) must have the start button pressed after adding a dish. If the start button control light is blinking, you must press start. On those models with buttons on the top of the door you must, in addition, close the door within aprox 5 seconds after pushing start. Hope this helps. Ken
May 01, 2009 | KitchenAid Dishwashers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Blinking clean light
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 21, 2009 | Kenmore 24 in. 16293 Built-in Dishwasher
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
