Question about Toshiba Satellite A100-S8111TD Notebook
My Toshiba laptop model A215-S4807 will not hold a charge
Even when it is plugged in, it shows that it is losing power. My brother has the same computer so I tried his battery and charger but the same thing happened, the icon said I was losing power. It eventually loses all power and stops working whether it is plugged in or not. Do you know how I might be able to fix this?
  • 1 more comment
  • Anonymous Feb 23, 2009
    i was trying to switch on my laptop last night.....i plug the charger because i thought that the battery run out. Thank i was trying to switch on again.....the light is on but nothing is working!!!???? do you know what i can do??? have no idea what is the problem .....how i can switch on my laptop??
  • Anonymous Feb 25, 2009
    I cannot switch on my laptop toshiba satellite...
  • David Shaub May 11, 2010
    There is a tiny pin sticking up near the hinge. This puts it into sleep or hibernate. If it gets any dirt into it, it won't make contact. Use some canned air and give it a quick shot of air. Don't get any moisture into it.
  • 43 Answers
Hello. It might be a problem with the charging set. If you took another charger and it did not work it is from your mainboard.
Posted on Mar 16, 2009
Rdrhow to find recharge componets on a215-s4807 motherboard?
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Aug 14, 2012 | Toshiba Computers & Internet
Want to restore toshiba a215-s4807 to factory setting
Read the Manual.
Get onlineand got to www.google.com In the google search box type: "ToshibaSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for Manuals and search them for System Recovery, Factory Restore or Factory Settings.
May 16, 2012 | Toshiba Satellite A215-S4807 Notebook
I have a Satellite A215-S4807. The original battery went completely dead (possibly from this problem), so I just went out and got a new one with a 4800mAh, which is slightly higher than the 4000 it came...
There is something wrong with the "recharger" components on the computer's motherboard.
Instead of charging the battery, and then stopping the charging process, it is "draining" your batteries.
Take your Toshiba to the nearest qualified Toshiba service location, to get it fixed.
Aug 26, 2011 | Toshiba Satellite A215-S4807 Notebook
I PLUGGED IN MY LAPTOP ADAPTER AND THE PLUG LIGHT BLINKS BUT DOES NOT POWER UP. THE PLUG ICON ON LAPTOP BLINKS BUT LAPTOP WILL NOT BOOT UP.
You may try this; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, and power ON the NB. If the laptop will not boot by doing this, take it to the nearest repair center to have it check for possible motherboard issue.
Mar 21, 2011 | Toshiba Satellite A215-S4807 Notebook
My Toshiba Satellite A215 S4807 laptop will not go pass the opening "Toshiba" page. I can't even get to the set up menu, can someone please help me. It does not respond to any of the F2, F12,...
try holding f8 key while it booting and it will take u to a boot options screen and select last known good configuration and if everything is alright with harddrive and operating system it should boot to windows
Feb 05, 2011 | Toshiba Satellite A215-S4807 Notebook
I instaled windows vista, but i need driver for video card for toshiba satellite a215-s4807. send me please the web site where i can download driver.
Download the Vista video driver for your model laptop from the Toshiba WEB site from their download page.
For a shortcut to the Toshiba's download page.
Copy and paste this address into your browser's URL address location.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1209157&rpn=PSAA0U&modelFilter=A100-S8111TD&selCategory=3&selFamily=1073768663&selModel=1209157|PSAA0U
Feb 20, 2009 | Toshiba Satellite A215-S4807 Notebook
I have installed Windows XP on my Toshiba labtop A215-S4807...and I can't find the drivers for this labtop on XP. I need it immediately. Thanks,
The best to do is record your model number and go to Toshiba's website for support and search for the drivers there. Hope I Helped!
Jan 27, 2009 | Toshiba Satellite A215-S4807 Notebook
I have a toshiba laptop computer satellite a215-s4807. I cannot get it to power on. The battery went completely dead and I plugged it in to charge. But it will not power on with it plugged into the...
certain laptops rely on a battery being present.
Or a battery that holds charge.
i,d suggest refering to the user manual, or go on-line to the manufacturers website.
the laptop may be in hibernation/sleep mode. or require a hard reset.
visit toshibas support site for further details and faqs ( frequently asked questions )
Mike @ compurepair.
Dec 18, 2008 | Toshiba Satellite A100-S8111TD Notebook
I have a toshiba laptop computer satellite a215-s4807. I cannot get it to power on. The battery went completely dead and I plugged it in to charge. But it will not power on with it plugged into the wall.
have you tried before to reassemble your laptop? if not...dont do that...because it will damage your laptop..if YES....open the laptop...remove the motherboard and replaced the power jack of the motherbaord...be sure that you find same model of the jack....if you find desolder the old jack and solder the new jack and return to assmble you laptop and put the charger and power on...good luck am 100% it will work..because this is my job..if still not work..dont hesitate to contact me..
Dec 15, 2008 | Toshiba Satellite A215-S4807 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
102 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
