Question about Kenmore Elite 45986 Front Load Washer
Kenmore HE2 plus 11047532601
I need to replace the bellow on my washer. This is a stackable. How do I change this?
Thanks,
Michele
  • 188 Answers
If it's stackable, you'll want to start by removing the dryer.
Open the door and remove the outer bellow spring around the bellow to release it from the cabinet lip. At this point lean the machine back to give more space between the drum and the cabinet.
Remove the kickplate for easier access and to visually check for leaks later.
At the top/right of the bellows (close to the tub) loosen the bellow to tub clamp and pull out the bellow.
Install the new bellow starting at the top by aligning the marks. Work your way around until bellows is properly seated snug against the tub.
Replace the tub to bellow clamp and tighten it (make sure the bellow stays snug against the tub while tightening the clamp). Once in place, lay the machine back to level and reinstall the front of the bellows to the cabinet with the outer bellow spring clamp.
With towels handy (just in case), let the machine fill and agitate for a few minutes and check for water leaks. If all is well, re-install the kickplate and wash some laundry.
Posted on Feb 22, 2009
Need a diagram for a Kenmore He2
go to www.youtube.com and put what bearing do you want to replace for whasher Front Load
God bless you
Sep 30, 2012 | Kenmore HE2 Plus Front Load Washer
I just replaced the door latch on my kenmore front loader washer model 11047532601 the door locked light doesnt come on and the door locked light isnt coming on all i get is beep beep beep
You have a bad CCU. This is the control board on the top of the unit. Remove the top, three screws on the back. The board clips into the position. You can try to unplug the wires one at a time, the control will probably have to be replaced.
With the model I would be able to better assist you.
Mar 31, 2011 | Kenmore HE2 Plus Front Load Washer
Why does my Kenmore He2 Plus front load washer not start and display an F02 code?
Welcome to FixYa.
The "F2" on your model of washer indicates the machine has detected a fault or obstruction in the drain process.
Chances are the pump itself is being obstructed by debris or some other foreign object as opposed to being faulty, although a faulty pump can`t be ruled out...yet.
Here`s how to check it and clean it...there is also a bellows at the bottom I`ll show you how to check
Oct 19, 2010 | Kenmore HE2 Plus Front Load Washer
How do I go about replacing the door seal (bellows) on my kenmore elite washer?
The following link explains how to access and replace the bellow one:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
A replacement bellow (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites so shop and compare. The first three sites on the list, have helpful exploded view diagrams to assist you with locating and identifying any parts you may need.
NOTE: The manufacturer recommends that you leave the door OPEN between washes to, not only allow the bellow to keep from becoming permanently stretched, but also to allow the wash tub to breath to prevent mold and mildew from forming. This will extend the life of the bellow and minimize any odors in your washer.
If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope this helps you.
Jun 27, 2010 | Kenmore HE2 Plus Front Load Washer
I have a He2 plus model 110.47532601 with bad rear
Hello Rickgall1998,
If t is a rear bearing (no symptoms listed) I doubt at 3 years old the bearing can be bad! I can't help you but if it is the door seal or some other common part perhaps you can find it here;
Kenmore Washing Machine Model 110 47532601 11047532601 110 47532601 Parts
Without some symptoms being listed it is hard to assist you.
Good Luck!
Rich Lilja
May 21, 2017 | Kenmore HE2 Plus Front Load Washer
Change door opening on Kenmore HE2 washer and dryer
yes - there is a hinge kit to do so.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2, Whirpool Duet Sport, water on floor, noise at spin
Found a toddler sock jammed in the water inlet. All of the insight from this site made it possible and saved me a $147 dollars I would of paid Sears!!!!
Apr 09, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 door bellow
he 2 are a little similar to all H E washer ,, it has spring clamps (2) remove and install them same way
Dec 12, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Bellow Replacement
Make sure the drain holes are clear in the bottom of the bellow. Also, make sure the bellow is aligned properly. There should have been an alignment arrow at the 12 o'clock position. Hope this helps.
Aug 05, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
627 people viewed this question
Sal De
fordexpert
Robert Rankin
