Question about Toshiba Satellite Pro L300-EZ1501 Notebook
Screen stays black on startup of toshiba satellite L300
Worked fine the last 2 months, this time all the front lights come on but the screen stays black. wasn't dropped, bumped, etc. tried a few light hits, plugged in power cord, turned off and on a few times, and moved screen back and forth rapidly many times- nothing!
  • amanda_aitch Apr 24, 2009
    on start up the screen does the option of regular start up etc...but once selected screen loads as blank and only mouse is visible...
    can anyone help?
  • 17 Answers
Have you tried either switching between external and internal monitor usally Fn + F5 on toshiba or try plugging a monitor into the back and see if it displays.
if you get a display on the external monitor then its probably a screen or inverter fault if you donot get a display to an external screen then it is likley t be the graphics on the board itself.
hope this helps
Posted on Feb 22, 2009
Why Toshiba Satellite A665 Laptop won't start?
Have you tried pressing space bar (maybe its in hibernation mode) ?
or try holding power button for a few seconds (10) then turn it back on.
as a last resort you could try take the battery out, disconnect it from the power adapter, hold down the power button for 30 seconds and then place the battery back in and the power adapter and try powering it on?
Aug 26, 2014 | Toshiba Satellite A665-S6088 16 Notebook...
Toshiba Satellite l300 1ap windows 7
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Oct 15, 2012 | Toshiba Satellite Pro L300 (L300-EZ1502)...
I got a new Toshiba satellite L300 notebook and turned it on today. But there's a starting up beep but the screen remained black. even when i connected the laptop to another screen, the screen still...
Take it to the purchasing party and get a refund or a repair if you just bought it. If it has a warranty by all means get it back to get it repaired. If you bought it from a private party always turn it on before you take it to see if it works first. Also you may want to try restarting and waiting a bit to pick up the screen sometimes they are really slow starters depending on what is has loading at the startup. I feel for you friend. John
Jan 30, 2011 | Toshiba Satellite Pro L300 Notebook
Toshiba L300 screen flickers and backlight
Maybe is the backlight power cable cut. Try with the laptop in power on mode oppening VERY SLOWLY the screen to see if at a certain potition it works fine. Open it all the way up sometimes to check it. If thre is a potition that it works, it's the cable as I mentioned.
Stelios
Feb 20, 2010 | Toshiba Satellite Pro L300 Notebook
Tohiba l300 completely blank screen
If the screen is always blank, even on startup , before loading Windows, than this is probably an hardware fault.
Try unplugging the laptop and removing the battery at the same time, wait 5 minutes, then put the laptop together. This will drain power and reset the laptop.
If that does not work, and you get no pictuer under any circumstance , then there is a fault.
If the screen is black with no light , then it is either a faulty inverter or a problem on mainboard.
If the screen is all lit, but is blank with no signal, then it is often because of a bad LCD ribbon cable , but can be again the video chipset on the motherboard.
Try connecting to an external monitor, if it works then problem is restricted to LCD/inverter and ribbon cable, if it does not work on external monitor is usually a bad video chipset on motherboard.
May 06, 2009 | Toshiba Satellite Pro L300 Notebook
Screen stays black
Startup while tapping the F8 key,this should open the startup options screen,Select start up in VGA mode,If that works,then you need to update the video drivers
Jan 07, 2009 | Toshiba Satellite L305D-S5895 Notebook
Open Questions:
Toshiba Satellite Pro L300-EZ1501 Notebook Logo
883 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
