Question about Hughes HIRD-E11 DirecTV DTV Receiver
How to connect a PS2 to a TV through a Hughes Direct TV box
My TV doesn't have an audio and video connection outlet for a dvd or other accessory input except for the hughes direct tv box which is connected throught the antenna port, so I want to know if I can run it through the hughes box to the tv and what to press on the remote get it to work ...
    New Friend:
Would a eurovox ex5100pvr work with a satelite dish
Posted on Jun 21, 2010
  • 56 Answers
Unfortunately you cannot run a ps2 or any other device through the receivers. take a look at the tv may have inputs on the front or side of tv where you can use red/white/yellow cabling OR take a look at what type of cabling your tv does support and go from there. hope this helps.
Posted on Apr 05, 2009
Hdmi cables input 1,2,3,4 which input goes to the tuner, direct tv box, blue ray on vizio E550i-AO
The choice is entirely arbitrary. You may connect any accessory to any HDMI input. I recommend you connect the device you use most (probably your direct TV box) to HDMI 1, your second most frequently used device to HDMI 2, and so on, but it's really a question of your own preferences.
Mar 18, 2014 | Vizio E550i-A0
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Oct 17, 2011 | Televison & Video
How to connect dvd to tv.
Good day!!!!
Please try this procedure on how to connect your DVD player to your TV..
Follow this instructions:
1. Check the back of your DVD player. It will have up to three different types of outlet connections enabling it to be linked to the TV. The most ideal is an HDMI connection, which is a thin rectangular outlet marked "HDMI." It provides the highest quality signal to your flat panel TV. If your DVD player doesn't have an HDMI outlet, you can also use a standard RCA outlet. This consists of three round cable jacks labeled with a color coding. The yellow jack is for the video signal while the red and white jacks are for audio signals. Some DVD players may have an S-video outlet as well. It will be a circular jack with a number of holes. While not as effective as the HDMI jack, it provides a clearer picture than the RCA cables.
  • 2. Look at the back of your flat panel TV for a series of "In" jacks corresponding to your DVD player. There may be a number of them under different labels (Input 1, Input 2, HDMI 1, HDMI 2 and Component Video are common). All of them work, however, and all can carry the DVD signal into your TV. Simply select an "In" jack that matches the DVD outlet you have selected and note the precise label.
  • 3. Connect the "In" jack from the TV to the corresponding outlet on the DVD player, using the proper cable (RCA, HDMI or S-Video).
  • 4. Turn on the TV and press the input button to select the jack connected to the DVD player. (The exact label for the input button will vary by model. Some will say "Input," while others will say "TV/Video" or "Signal.") A menu should pop up onscreen giving you a list of jacks in the rear of the set. Select the jack connected to the DVD player. The name of the player brand should appear on your screen.
  • 5. Place a DVD in the player and watch as normal.
  • I hope this procedure will be helpful...Thanks for using fixya..
    Aug 13, 2011 | Panasonic Televison & Video
    Direct TV satellite to TV connection issue
    hi cable from the wall into the box then a cable from the box into the tv or hdmi cable from the box to the tv thanks
    shaun
    Jun 13, 2017 | Toshiba Televison & Video
    At the back of my Pioneer DV-414 DVD Player there are 3 sockets namely (component video out) which are Y (Green), Cb (Blue) and Cr (Red). Can I connect these to my TV which has sockets Red, White and...
    You are describing what are called composite video outputs. Unless your TV has similar green, blue and red input sockets, you should ignore them altogether.Your Pioneer DV-414 has several different ways to link to other pieces of equipment. Depending on the sophistication of your audio/video gear you can have a higher quality video image using the S-video outlets which look something like the PS2 sockets on older computer keyboards and mice. If you don't see this socket on the back of your TV, and you don't see the composite RGB sockets either, then you will have to use the standard red & white outlet for left/right audio and the yellow outlet for video.
    Hope this helps -)
    Nov 30, 2009 | Pioneer DV-414 DVD Player
    Hook up player
    Your TV hopefully supportsw more then one unit connecting to it. if not you will need to use an input on one of your units (direct tv unit or DVD player) for the other unit. Example your direct tv is connected to your TV, on the back of your direct tv unit is a video /audio input. connect your dvd player to that input. on your direct tv remote or menu should be an option to use that input.
    Aug 25, 2009 | GoVideo Go Video DVD/VCR Combo
    Cant hook dvd/vcr to my cable box the manual says I need a extern
    The cable box IS an external tuner.  You should connect the video output (either S video, HDMI, or component video) of the cable box to the video input of the DVD.  Then connect the audio output of the cable box to the audio input of the DVD via stereo RCA cables.  If your tv monitor has multiple inputs (ie: video 1, 2, and 3...) connect the video and audio output of the DVD to your tv monitor using an alternate video input (if cable box goes into your tv thru video 1, connect the DVD to video 2).  If your cable box only has one output, or your tv has only one input, then just connect your cable box to the DVD as above, and connect the DVD to your tv.
    Jun 21, 2009 | Philips Magnavox DVD/VCR Dual Player
    Connection problem with Denon 589 and direct tv
    If the RCA TV has HDMI input connect as follows:
    1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
    2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
    3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
    4. On front of denon press the input mode button to select auto
    If the RCA TV has Component input (Green,Red,Blue) connect as follows:
    5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
    6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
    7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
    8. On front of denon press the input mode button to select aut
    If the RCA TV has Composite input (Yellow) connect as follows:
    9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
    10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
    11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
    Feb 08, 2009 | Denon AVR588 Receiver
    Denon AVR-488 , problems routing cable box through receiver to tv
    If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
    Suggestions:
    1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
    2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
    3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
    Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
    Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
    4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
    4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
    Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
    Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
    Now select the TV/CBL input and turn on the STB. You should have both audio & video.
    Mar 08, 2017 | Electronics - Others
    Trying to hookup ps2 to direct TV.have found a couple solutions that didn't work.
    This is not a problem with the PS2, it is configuration of the Direct TV. Be sure that the port of the TV works. Or if you are trying to connect to your Direct TV box, you it will not work if your connecting to output connection. You can only connect the PS2 to a Video Input.
    Dec 30, 2008 | Video Game Consoles & Games
    Hughes HIRD-E11 DirecTV DTV Receiver Logo
    472 people viewed this question
    Top Hughes Televison & Video Experts
    jason
    Jim London
    Jim London
    Edward Talavera
    Edward Talavera
    Are you a Hughes Televison and Video Expert? Answer questions, earn points and help others
