Question about NEC LT 260K Multimedia Projector
NEC LT260 has White specs on Screen
I haven't used my projector for a little while and now there are white specs (like stars) mainly in the centre of the screen. I've tried cleaning the lenses but it hasn't made any difference.
Any ideas what the problem is?
Thanks
  • nige_morgan Apr 20, 2009
    Finally got around to taking the projector apart and tried using a dust remover to clear the problem but this hasn't worked. It looks like the chip itself will need to be replaced. I've taken it out and can clearly see a problem on the mirror surface, it looks like a thumb print albeit I know it's not as it is a sealed unit and as such I cannot get to it to try and fix it.
    Looks like I'll be ditching the projector unless I can source another chip at a reasonble price. Anybody know where I could source the part?
    Thanks
I had the same problem. It is specks of dust on the DMD chip that the lens focuses on.
If you take it apart you can see a long telescopic lens that points at a small chip. This chip contains all the micro mirrors that produce the image.
Fortunately this sensitive item has a glass cover. Unfortunately it can be contaminated with dust. I just squirted a jet of air from a camera lens blower brush to remove the specks of dust. Problem solved.
Here is a link to a dismantling guide: http://www.flickr.com/photos/todbot/81868083/in/set-1749030/
(If you get any dark shadows at the edge of the screen then the light tunnel between bulb and colour wheel has partially collapsed.)
Posted on Mar 15, 2009
There is video clip onYOUTUBE, how to replace the DMD chip. it is a very helpful guide video i think. just search that video by (http://www.youtube.com/watch?feature=endscreen&v=uJpGvrz3yR4&NR=1
) this hyperlink.
Posted on Aug 17, 2012
SOURCE: NEC LT260 PROJECTOR NOISE
To open this projector, you need to undo six screws at the underside of the case. That means you have to turn the projector upsidedown.
Pls note that one of these scews is a little hidden under the carrying handle.
After removing the screws, return the projector to it's normal 'up-side' up, standing position.
Remove the bulb cover srews and remove the bulb cover.
Lift up the top cover carefully starting from the front then all together.
The cooling fan is mounted very near the bulb assembly.
Carefully check the fan blades for any obtacles, wires or even a broken fan blade, that could be causing the noise.
Baba Anji.
Posted on Dec 30, 2007
ginko
  • 19396 Answers
SOURCE: security code for Nec lt260 multimedia projector
The menu and logo password are the only ones you can reset by yourself, if you lose your master password you must contact NEC to get the release code.
See page 113 on the manual :
NOTE: Do not forget your keyword. However, if you forget your keyword, NEC or your dealer will provide you with your Release Code.
After you call NEC and get the code do the following:
1. Press and hold the POWER button for a minimum of two seconds.
The projector will be turned on and display a message to the effect that
the projector is security-protected.
2. Select [Projector Options] → [Security] from the menu and press hte ENTER
button.
The Release Code input screen will be displayed as well as your Request
Code (24 alphanumeric characters).
3. Enter your Release Code in the Release Code Input screen.
The projector will turn on.
* If the projector is turned on by entering the Release Code, your Security
will be disabled.
find contact page from here or call the retailer:
NEC Global
Here is also the remote
Posted on Sep 10, 2008
ginko
  • 19396 Answers
button.
will be disabled.
NEC Global
SOURCE: nec lt260
Clean optocoupler under pcb 4554B on color disc wheel.
Dusty on this part make not good sincronice with dlp panel.Good luck.
Posted on Oct 02, 2008
  • 13 Answers
SOURCE: projector says out of range
The native resolution on the 6100 is 800x600. I have had it recognize 640x480 and 1024x768 though. Check your computer to make sure the resolution is 800x600. Also set the refresh rate at 60htz, if the refresh is too high it can give out of range errors.
Posted on Jan 28, 2009
I have a NEC projector in my class but projects white spots on the screen which are multiplying day by day. Has anybody solved this problem ???
1,white spots appeared on screen,means the DMD is broken,you need a new DMD.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD, motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 07, 2014 | NEC NP200 Projector
Vertical hazy lines are all that can be seen on my LT260 (nec)
make sure the lcd cables are secure in the main board. if that doesn't fix it the polarizers may be burnt.
May 11, 2010 | InFocus Proxima DP6155 Multimedia...
Security code for Nec lt260 multimedia projector
button.
will be disabled.
NEC Global
Sep 10, 2008 | NEC LT 260K Multimedia Projector
button.
will be disabled.
NEC Global
Sep 10, 2008 | NEC LT20 Multimedia Projector
Security code for nec lt 260
The procedure is the same for LT220, LT240 and LT260.
Here is the user manual
LT260/LT240/LT220 User’s Manual
Sep 09, 2008 | NEC LT 260K Multimedia Projector
Lt260 projecto
From user manual :
"In case you forget your passcode, follow the steps below to delete it.
1. Select the Advanced menu from the Basic/Custom menu. The Passcode
entry screen will be displayed.
2. Press the SELECT (up) button four times and then press the ENTER
button.
The "Warning Passcode!!" message will be displayed.
3. Press the SELECT (down) button four times and then press the ENTER
button.
4. Press the SELECT (right) button four times and then press the ENTER
button.
The "Delete Passcode / Are you sure?" message will be displayed.
Use the SELECT or button to select "Yes" and press the ENTER
button. Your passcode has been deleted."
Aug 05, 2008 | NEC LT 260K Multimedia Projector
Nec lt260
Jun 28, 2008 | NEC LT 260K Multimedia Projector
Baba Anji.
Dec 18, 2007 | NEC LT 260K Multimedia Projector
NEC LT 260K Multimedia Projector Logo
690 people viewed this question
Top NEC Office Equipment & Supplies Experts
Electro Med Services...
Greg Cann
Greg Cann
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
