Question about Linksys (NH1005) 5x10/100 Mbps Networking Hub
Slow internet. Can an older model Linksys NH 1005 cause the internet to be slow if phone company has installed new fiber optic connections to my house? Hub runs from router to computers. Problem is new. I want to know if the hub can be the problem before I replace it.
  • 71 Answers
Your hub can support more that fiber optic puts out. Problem might be a slow computer. Run a internet speed test see what it gets through hub and then straight to the computer bypassing the hub. If possible. If there is a big difference either way what ever is slower is most likley the issue.
Posted on Mar 15, 2009
How do I set netflix on my blueray to a different internet provider
Unless your situation is different from most of us, you only have one Internet Service Provider (ISP). That could be Comcast, Time Warner Cable, Verizon or another provider. Generally speaking, every home/apartment has only one provider feeding Internet to that location. If you have a separate detached home, you may have a choice of who will install Internet service in your house, but if you live in an apartment, you may have to use the provider that the rental company allows to provide service.
Either way, once you have Internet service, you must use that provider for Netflix until you switch to another provider. I personally just switched from Time Warner Cable to a local company offering gigabit fiber optic Internet service. I had the fiber optic cable installers leave the coaxial cables that Time Warner ran through my house, but those cables are no longer connected to Time Warner's system.
Feb 12, 2015 | Computers & Internet
Tip
My Internet connection so slow?
<p>The type of Internet connection you use is the most important factor in determining your connection speed. The three most common ways to connect to the Internet from home are dial-up, DSL, and cable. If you have a choice, cable is usually the fastest, but both DSL and cable are faster than dial-up. <br /> <p>Many Internet providers also offer Fiber Optic Service (FiOS), which connects to the Internet using light over an optical network. In your home, you still connect your computer through copper wiring. The advantage of FiOS is that it can provide higher speeds than traditional copper wire connections such as DSL or cable. Some Internet providers offer multiple options, depending on the area you are in. More populated areas are more likely to have FiOS available. Check with your phone company or Internet provider for more information.<br /> <p>If you use a dial-up connection, there are a couple of good ways to optimize your Internet speed. First, use the fastest modem you can. The fastest modem you can use will send and receive information at a rate of 56 kilobits per second (Kbps). You won't get a full 56 Kbps speed most of the time, but with a good phone line, you should approach at least 45-50 Kbps. <br /> <p>Second, make sure that your phone line is in good condition. If the telephone wiring in your home or business is old or deteriorating, you might be picking up stray signals or cross talk from other phone lines. These problems will slow your Internet connection because the modem will have to send the same information over and over until it's transmitted without interruption. Check your telephone wires to be sure they aren't damaged, frayed, or twisted around power or other telephone cables. If you notice crackling in your phones, you might want to contact your phone provider to have them check the lines inside and outside your home to make sure they are in good condition.<br />
on Dec 03, 2010 | Computers & Internet
Fariya dialer setting for linksys wrt320n
I don't know about Fariya's service in Karachi--it's some sort of fiber-optic broadband service.
Anyway, with your linksys, you can't "dial-in"--given the US, "dialing-in" instead implies old analog internet service (certainly not fiber optic service)--and, a far more primitive type of modem--connected to relatively simple legacy "twisted-pair" conventional telephone cables.
The above should apply for a TPLink router, as well--thus, don't get rid of your linksys for that reason--it should work in the same manner. (The companies are just competitors--offering similar products.)
What you likely mean instead of "dialing in" is inputting the correct username and password, etc. You were here--your service (as an internet service provider--ISP) appears to function. Your router likely works well.
Instead, it likely has to do browsing to the correct site and inputting a correct username and password. (Perhaps, you must configure your account for movie streaming beforehand.)
I tried navigation to the .pk site--no function. Some info about the site says it's dead. (Perhaps I was blocked.) Try to search (google.com, bing.com, etc.) for the correct site(s) you need, instead. (Maybe the url (the web address) was changed.) Navigate your ISP's site for info, too--perhaps first.
Mar 24, 2014 | Linksys GIGABIT WLAN ROUTER WRT320N...
Cook book for Russell Hobbs slow cooker model 13482
You need to get in contact with the company by phone or use the internet maybe you can copy something off the internet.
Dec 30, 2012 | Crock Pots & Slow Cookers
Very slow in browsing
> very slow in browsing
Brand-name of computer?
Model-number of computer?
Operating System?
Which web-browser (Chrome? Firefox? Safari? Internet Explorer 9?)
What type of Internet connection (office network, dial-up modem, DSL from your telephone-company, fibre-optic from your telephone-company, cable-modem from your cable-modem company)?
What speed does your ISP (Internet Service Provider) promise? (1.5Mbits/second, 5.0 Mbits/second, 100 Mbits/second)
How much RAM in your computer?
Which CPU (AMD? Intel? Pentium 4?)
Which web-sites are "slow" ('www.microsoft.com' should be *FAST* and the web-site for your local state/provincial government should also be *FAST*) ?
Your location (India? USA? Iceland?)
What other software is using the Internet? Bit Torrent? BearShare? MSN Messenger?
Is your anti-virus software up-to-date?
When's the most-recent "full" virus-scan?
Are you "sharing" your Internet connection with other "wired" and/or "wireless" devices (Xbox? iPod Touch?)? Are those devices "actively" using the Internet?
Sep 24, 2010 | Computers & Internet
I have a Linksys 2 wire router. My DSL connection
it could be a lot of things giving you trouble
fisrt check if your connection is droping from the isp
if so contact isp
second check lights on modem such as power dsl and internet
3rd think of a modem remplacement
Jan 15, 2010 | 2wire (1000-400108-001) Router
Fiber-optic networking
Apply load balancing of the NIC interface, else put in a switch to interconnect all the computers. That should give equal speeds to all the PC's.....sodeep
Apr 06, 2009 | Computers & Internet
Router not connecting
The problem here is that the WRT54GS is an old model, so naturally the installation CD is also old. This is especially a problem if you are running Vista. I ran into the same problem when I was installing my wireless card; my computer would detect it on boot up, but when I installed the drivers from the CD, it said the card wasn't plugged in.
The solution would be to download the lastest installation and driver files from the LinkSys website and use those instead of the installation CD that came with it. You may have to hunt for it, as some companies would rather push new products than update older ones, but since the router is still on the market, they should have the updated drivers and installation files.
Feb 11, 2009 | Linksys Wireless-G WRT54GS Router...
Slow slow slow
well in this case back up all ur data in a storage media and perform a formatting process and install a new OS again i recommend u Windows in this case
Dec 28, 2008 | HP Computers & Internet
Linksys (NH1005) 5x10/100 Mbps Networking Hub Logo
289 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
