Question about Cyberhome CH-DVD 300 DVD Player
I got the ch-DVD 300 no power anymore, I opened and I saw the fuse blown out,where can I get a new one? it says T2AL-250V and measures 3/4 of inch.
  • Anonymous Mar 03, 2009
    its only on standby mode,how to fix it,plz expert guide me its urgent
This is not a good solution but it is one I have used for extreme situations.
Take a single strand from an old cheap lamp cord and solder it across the ends of the fuse. This will create a new fuse of approx. 1 amp. I made a safe cross country flight in a private plane by making a temporary fuse when a new one wasn't available.
Posted on Mar 29, 2009
CH-DVR 1600ZU. Why did it stop working?
The 2A/250V fuse can 'look OK' but still be defective. The CR2032 cell could have expired.
Feb 09, 2016 | Televison & Video
My CyberHome CH-DVD 300 Player Not working CD, Only Disply "CyberHome DVD appear in Screen". I am in Near Tambaram. Please send Nearst Service centre Contact No. and Address.
Not reading anymore DVD movies disc or CD musics disc.The DVD laser eye head reader it is dead.Can't be repair must be replaced,not worth it well cost the same price as a new DVD player unit,if repair by a tech and have to buy parts for it.Basic DVD player unit are very cheap these day.U can buy a new one just a basic DVD player only will cost u like $40.
Aug 22, 2011 | Cyberhome CH-DVD 300 DVD Player
I have a JVC DR-MX1SEK dvd combi recorder. It was working well when I was searching for another problem when I removed the plug from the mains socket and a blue flash came out of the recorder. I removed...
Not sure if you have resolved this but that fuse is widely available. It is a 20mm x 5mm 2 amp slow blow glass fuse. It is perfectly possible that your replacement was correct but that a separate fault in the machine is causing the fuse to blow. Remember, fuses are designed to protect things (either the machine or you) and to blow if a fault causes more current than is safe.
Jan 05, 2011 | JVC Televison & Video
Completely dead is their a fuse
Yes it does have a fuse. This will require you to remove the 8 screws from the metal housing. Then remove the housing. The fuse is located toward the back of the unit on the right hand side when looking down. It is a small 1amp, 250 V fast acting fuse, which can be found at Radio Shack if it is blown.
That said, there is no guarentee that this will fix your issue. I replaced the blown fuse and the unit still does not work. You maybe lucky and that solve the problem.
Jan 06, 2009 | Cyberhome CH-DVD 300 DVD Player
Dvd player
i can tell you somthing that i used to do temporaly, take a couple strands from a wire any kind dosnt matter, like an old extention cord or sumtin, take like three strands 4 bigger gage an rap it around the fuse prongs an it will reconect the pos to the neg it works ive done it with a high powered stereo.
but make sure its unpluged... hope it works
Oct 01, 2008 | Memorex MVD2042 DVD Player
No Power.Model # DP02CD
First check the power supply for bulging capacitors,and burned componants,these units stay on,even thogh you power the unit off,,unplug when not using
Replacec-10,and c-11 filter caps
Mar 14, 2008 | Cyberhome CH-DVD 300 DVD Player
No Power... need a new fuse.
While wiping off the dvd vhs player it went out. Said it did not recognize the tv anymore. My son put it on his tv and got a half screenof the movie. just took out the fuse t2al 250v. what is my problem?
Sep 11, 2007 | Cyberhome CH-DVD 300 DVD Player
No Power at all. Fuse T2AL is blown up
Thanks to Bogbrush (what a name!) above for the hint to check R5107 when the STRG6653 explodes, indeed it was open circuit. I replaced that with a non-SM component since that's what I had to hand, replaced the fuse (2AT), replaced the STRG6653 and replaced the mains rectifier since this looked to have suffered even though cold checks implied it was OK. Then rewarded with a fully working DR-MH200. I had already gone through the power supply replacing any capacitors which had gone high E.S.R, several had. The 27uF 35V capacitor in the primary circuit of most JVC DVD recorders is particularly prone to failure.
Mar 04, 2007 | JVC DRMH20 DVD Recorder
Cyberhome CH-DVD 300 DVD Player Logo
361 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
