Question about Kenmore 24 in. 17512 Built-in Dishwasher
Rattling noise in my kenmore dishwasher - Kenmore 24 in. 17512 Built-in Dishwasher
  • 234 Answers
This is probably due to a defective motor. The fan blade will actually become disconnected from the motor armature and will rattle around on the shaft.
It is easiest to replace the whole motor and pump assembly as a unit. They cost about $100.00 or maybe a little more.
It is not hard to replace if you have your machine pulled out from the wall and upside down or on its side.
It is only a few screws and plugs.
Posted on Apr 15, 2009
Kenmore dishwasher making "spitting" or "sputtering" noise during operation
The easiest way to confirm if the arms are blocked is by turning all the arms in the machine to a certain same position and running the machine for a few minutes in its wash cycle. Open the door and see if the arms have moved. If not, check all the holes in the arms for blockages. Sometimes its very difficult to clean them. You may have to poke a pin or something into hole and then shake the obstruction out through the large inlet hole under the spray arm itself.
Dec 23, 2014 | Kenmore Dishwashers
My dishwasher won't drain and there is a rattling noise in the door. I don't know if I should just get a new one as the repairman costs are high. I did start a cyle over and more water went in but...
there is a drain pump system on the machine could be clogged, also if the drain hose is not installed up and over the unit it will cause issues with drainage. as for the rattling noise you probably have either pieces of broken glass rolling around under the basket.if you are a do it your self-er its always fun to explore.if not the cost of repair would be the cost of a new install. don't waste your money.
Jun 14, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
Kenmore elite dishwaher 1646 not cleaning dishes.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
jklfryyr
Jul 06, 2010 | Kenmore 24 in. 16462 / 16464 / 16469...
MY DISHWASHER DOES NOT DRAIN THE WATER OUT AND IS MAKING A RATTLING NOISE.
Pull the pump motor and see if the impeller has come loose or fallen off for the rattling noise.
Also check the drain valve and hoses for crimps or obstructions.
Dec 09, 2009 | Frigidaire Dishwashers
The water pipes rattle violently in the beginning of the cycle.
My Kenmore 16464 dishwasher caused a buzz in the water pipes at the start of the cycle that I thought was just water hammer. It turned out to be a bad water inlet valve on the dishwasher that has water hoses (inlet and outlet) attached plus has an electrical connector. It is located near the front left underneath the tub. I pulled the dishwaher out and replaced it and all is quiet again. - Jim
Nov 13, 2009 | Kenmore 24 in. 16462 / 16464 / 16469...
Top drawer is ok. Bottom drawer makes lots of noise, but finishes the cycle ok
Can you describe the noise:
Water noise,
Mechanical sound noise.
Motor noise
Rattle noise
Jun 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
Kenmore Elite 137889, grinding noise
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the tub.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
The drum bearing is replaced by accessing the bottom side of the washer, and is a not a simple repair.
May 05, 2009 | Kenmore 13789 / 13782 Dishwasher
Vibrating noise
u may have food in pump u see sometimes it dose happen i have pop corn seeds in mine
Dec 16, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore 24 in. 17512 Built-in Dishwasher Logo
348 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
