Question about Sega Video Game Consoles & Games
My dreamcast power wont come on
I press the power button on the console and the power on light flashes instead of staying on.the disc is also not rotating
Take it apart and push button down inside machine if it works your button is messed up. just happened to me on one i picked up if thats not the problem i dont i know but at least wanted to tell you what happined with mine
Posted on May 05, 2013
    Scholar:
  • 32 Answers
Be sure to check that your power outlet is supplying enough power by plugging in another game console or even something like a DVD player into the same outlet.
Also try finding another power cable and try that.
Cables can be worn out through time and cable failure can be common.
Dreamcast power cables are a standard type and can be found on other machines like boom boxs, DVD players or simply sold as generic replcament power cables.
If your outlet works fine for other machines and the Dreamcast continues this problem with other power cables then it is safe to assume that the power unit in the dreamcast is damaged somehow.
In most cases this would warrent a replacment.
Used Dreamcasts are cheap and not hard to find.
I do not suggest salvaging another power unit from another machine as this can be harder than its worth overall.
Posted on May 08, 2009
Dreamcast cuts out after or during the startup screen, stops displaying audio and video. If a disk is inside, it doesn't shows no signs of even being on aside from the power LED and the fan. The system...
This is probably the most ridiculous thread I've ever read in regards to the most common fault of the Sega Dreamcast. The issue is not with the laser - if it was unable to read the disc, it wouldn't read the disc.
The issue is actually with the pins that connect to the motherboard. They corrode and burn out over time. This can be fixed by cleaning with a high percentage alcohol.
Make sure you have unplugged and turned off the console for a couple of hours beforehand.
And before you open it up, press the on button to check for any remaining power.
Instructions are here http://www.mmmonkey.co.uk/dreamcast-random-reset-and-common-fixes/
Sep 17, 2011 | Sega Dreamcast Console
I was given a sega dreamcast everything works but when it says install disc i put the disc on the wheel close the door and the cd wont stay on the wheel
If I recall the Sega Dreamcast wheel is a clasp type wheel. You need to push the disk down onto the wheel and you will hear it secure itself onto the wheel. Then close the wheel and you should be good to go. Don't just place it on the wheel... push it down until you here that little clicking sound and it should stay on the wheel.
Aug 10, 2011 | Sega Dreamcast Console
MY WII BALANCE BOARD IS CHARGED BUT THE BLUE LIGHT WONT STAY ON.
  1. Insert a Wii Balance Board compatible game disc in the Wii console.
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the syncronization is complete.
click here to download repair guide if u want
Dec 15, 2010 | Nintendo Wii Fit - Balance Board + Game...
When I install some disks into the machine, instead of loading the disk, I get a screen that says Play,File,Music and Settings and don't know why.... Other of my disk load fine!! Can you help me??
yea it's either the disc is not a disc of the country u are in or the disc may be damaged... also.. u can't install disc onto a sega dreamcast... if' it's backup games that u are playing u will need a boot disc... u can google it.. it's commonly called dreamcast boot disc and the image file is free on the net...
Sep 23, 2010 | Sega Dreamcast Console
Bought 2nd hand wii fit, have just loaded disc and replaced batteries in board but power light not staying on board, flashes for about 30 seconds and then switches off. Does it need to be synchronised with...
    Hope this helps
    Try these steps!
  7. The blue light will stop blinking and stay on steady once the synchronization is complete.
please leave a good rating and testimonial if you appreciate my help. THNX
Mar 27, 2010 | Nintendo Wii Fit for Wii
Dreamcast "please insert disc"
I noticed you said and I quote "a copy of an original game in chinese" you did say chinese right? Is it possible that the system you have may be a PAL system if so that means it's not a USA Region console meaning it won't play Region 1 USA games just PAL
Jul 01, 2017 | Sega Dreamcast Console
Power
    Try these steps!
Sep 09, 2008 | Nintendo Wii Fit for Wii
The Power doesnt't go on
sounds like the power supply on the dreamcast is gone. or on its way out the door.
also could be the mainboard but further testing would be needed.
Aug 11, 2008 | Sega Dreamcast Console
Sega Dreamcast console problem
First off, NEVER store a game console on top of a subwoofer. It is like a giant magnet, and electronic devices do not handle magnetics. I don't think i've ever heard of a VGA box, Sega brand or not, killing a console. Millions use aftermarket AV cables and adaptors on all consoles without problem. I think it likely died from being on top of the sub. Relocate it and you should be fine. Running it for a few hours isnt likely either unless you had the vents entirely blocked.
To the guest who's drive isnt spinning, I would say your drive motor has burnt out. This doesn't indicate a defect in Dreamcasts, per se, it just means bad luck or excessive dust which killed it. Either buy a different Dreamcast or see if you can find a drive replacement.
Hope this helps.
Feb 28, 2008 | Sega Dreamcast Console
Dreamcast Loading problem
you can get disks relayered at game stores.
there was a long period where this happened to me.
some games worked for a while, some didnt.
its the dreamcast.
you might wanna get anew power cable or just clear out the dust because that is the main problem with the dreamcast.
try playing with the console upside down
it sounds crazy but it worked for me.
Dec 18, 2007 | Sega Dreamcast Console
Video Game Consoles & Games Logo
1,011 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Josh Whitehead
Josh Whitehead
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
