Question about Kenmore Kitchen Ranges
Ran auto clean for oven and cleaned stove top, not auto lighting
Model number 79078692405. I Ran auto clean for the oven and cleaned the stove top. Now the only burner on the stove that lights is the power burner( front right). The knobs fit loosely and don't have the black metal insert to make them fight right but I will buy replacements soon. I was sure to remove any soap skum ofrom the ignition points but the other 3 burners still dont light. I even reset the computer by flipping the power for the oven off. What can the problem be?
  • Kenmore Master
  • 3,361 Answers
One. DO not use self clean on ranges unless you want to replace parts.
Two. Replace the thermal overload fuse.
Three. The manual should be in the console head.
Posted on Feb 22, 2009
C970 555821 Kenmore oven
Look for the model number inside the oven door area. The number you posted is incorrect.
Dec 22, 2013 | Kenmore Kitchen Ranges
Cant get oven to turn on. the only thing that works is the stove top n have to light it my self. My electical screen wont turn on which controls my oven
Check and see if the stove is plugged in. I suspect your DSI module has failed.
All these stoves ain't the same nor do they even work on the same principle. I am guessing from the picture you have a DSI system. For a more precise answer always post a mdle number. Most model numbers are posted on the oven frame of the lower drawer.
Here is your DSI service Manual
Dec 21, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I just moved into an apartment that has an older Caloric Prestige oven and range and cannot find the Pilot light--Please help
Hi, The caloric ranges use diferent types of pilot igniters, to avoid any further delays, I suggest geting the model number off the stove usually located under the stove's top, you don't need any tools just lift the range top(like when you are going to clean it) the model number is located usually on a metal plate in between the burners, or if it's not there , it will be inside the oven around the door liner or the oven liner. When you do locate the model, just go to the repair clinic.com website and type in the model number, follow instruction after that. see the following figure it might help in locating the model number: small_13_4.jpg
Apr 13, 2010 | Ovens
How do I get self clean to work on older fridgidare stove
Move the safety lock/lever at the top of the oven door to the right and press the self clean button on the oven control panel, it is an automatic cycle so it will lock the door from opening and then will proceed with the auto clean cycle. Good luck !
Jan 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Touch pad will not unlock after running self clean cycle,
ran the SCC and the oven door unlocked when completed but the touchpad did not. Can;t use over at all, top of stove works fine. None of the bottons for the oven works. still says self clean completed, will not go away, can't use oven at all.
Dec 14, 2009 | KitchenAid KESC307 Electric Kitchen Range
The ovens fail to work after the cleaning cycle - displays says "call service". Now both ovens will not operate and neither do the timers.
Maytag model MER6772BAW was displayying f9-2 and call Authorized
service after cleaning also top door was locked and feature were disabled. I was able to solve the problem by unplugin the stove and waited about ten seconds before re-conecting once up the top door unlocked cleared the f9-2 error by pressing Auto set button and number 9 for Defauts. Perhaps this can help you.
Aug 14, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
Dec 16, 2008 | Frigidaire FEF366EC 30" Freestanding...
Kitchen Ranges Logo
161 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
