Question about Samsung HLR5067WX 50" Rear Projection HDTV
Tv turns itself off after a minute are so, then in a minute are so it turns itself back on most of the time, but i believe the light fan goes off also even with the battery powered surge protector. The remote are buttons on the side of the tv don't respond. Sombody please help me!!!
  • 2 more comments
  • deli4u Feb 22, 2009
    My picture comes on for about 30 seconds then it turns off and comes back on every minute or so.
  • Anonymous Feb 23, 2009
    The T.V just shuts off after like ten minutes, i can power it back on but it happens every few days, im not sure if it's a timer or what, but it powers off then i switch it back on, and in the like 2 min it turns off, and we play this on and off game until it stays on
  • elainewallac Apr 20, 2009
  • astron35 May 05, 2009
    I have the same issue but it is intermittent and then no problems for hours, sometimes days.
I had this problem a few years ago. The service technician replaced the bulb which he said was over-heating, and that fixed it.
Posted on Mar 14, 2009
TV turns itself off after about 5 minutes (green light remains on). I can turn off the TV and turn it back on immediately, however, the TV turns itself back off after a few minutes. It started turning off...
Check and make sure your fans are working and there is sufficiant cooling to the back of the set. Sounds like it is overheating and going into protection mode.
May 04, 2011 | Mitsubishi WS-65513 65" Rear Projection...
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
My magnavox 50" DLP 50ML815D/17 will turn on and broadcast fine, but after about 30-40 minutes of viewing it will turn itself off & a red light comes on. If you feel the tv close to the bulb area it is...
Yes there is a Fan that keeps Lamp cool if it stops running Lamp will shut off it is designed that way to keep lamp cool also if Fans are OK it means Lamp is going out Call Mats 1-800-628-1118 for lamp
Sep 19, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
My HL-S4266W Samsung projection tv shut off by itself and all lights were blinking. The TV would turn back on but turn itself off after a few minutes. I replaced the bulb but this did not fix the problem....
Actually7 there's a possibility that your ballast is the one causing the problem, the thing is that with samsung tvs what goes bad most of the time, besides the lamp, are the ballast and the colorwheel, in this case my hopes are on the ballast, but if you want to be more sure discountdashmerchantdotcom
Jul 14, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
I have a similar problem with the Sony 60" wega SXRD rear projection TV. The green light blinks on the power/display LED and the picture comes on for a few seconds and then the screen goes black . Then the...
I believe 4 blinks is fan error. You can take back off and watch fans in particular the fan for the lamp (this one goes out the most) The TV has a sensor so it knows if the fan turns.You can take a pencil and use it to spin fan sometimes that will jump start it (not a permanent fix just a test). You can try cleaning dust off fan and replugging the connector on the wires coming from fan.Might fix it if not fan will need replacement.
Apr 27, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
BLUE SCREEN THEN SHUTS OFF
cause: tuner i believe will cause tv to not find channels turn blue and turn itself off
Aug 18, 2008 | Sony KP-51WS500 51" Rear Projection...
I had the same problem and it costs 200.00 dollors for the lamp that bad
Aug 15, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Samsung HLR5067WX 50" Rear Projection HDTV Logo
213 people viewed this question
Henry  Thomas
Henry Thomas
