Question about Kenmore 53532 / 53534 Side by Side Refrigerator
Refrigerator not cooling
I have a Kenmore side by side that is not cooling. the model # 106.53532300. What could it be? Smelled a warm electical smell a couple days ago. Stopped cooling yesterday. I hear a clicking sound, like when your stove is on and it clicks for the temp. Help!
    Problem Solver:
  • 6 Answers
Clicking sound is most likey the overload on the compressor. You could have one of 2 problems,The compressor relay and start capacitor may be defective therefore not sending the correct power to start it up properly, this is a common part that burns out on any refrigertor. Worst case scenerio... It may also be a bad compressor. If the compressor mechanically seizes up it will try to start and draw high amperage.
The only way to test which one is the problem is buy using a compressot test kit or you can try your luck and change the start relay and capacitor which will run you about 40-60 bucks give or take.
Posted on Feb 22, 2009
  • 410 Answers
The most likely problem will be the start relay for the compressor. the clicking noise is the compressor trying to start and then the relay cycles back off. the part number is 8201786 and can be purchased from any loal appliance parts house thru sears.com or any othe online parts source. the kit comes with good instructions so you should be able to repair yourself.
it would be a good idea to unplug the refrig until you get it repaired to prevent possible compressor damage. thanks peyton..
Smell ammonia and refrigerator got warm,no sign of leaks
bad cooling unit if you cannot replace bring to a dealer or replace unit
Jun 19, 2014 | Dometic RM2852 Refrigerator
Kenmore model 105.53534300 side by side refridgerator not cooling
Relays are located on the left side of the compressor. How long ago did you smell the burning smell? Are you 100% sure the compressor is running? If it is, nothing is wrong with the relays. Although sometimes it is hard to tell if the compressor is running. By morning temps will be higher than tonight if compressor isnt running. If it isnt running, relays must be changed. I will post shortly on how to change the relays.
Dec 23, 2007 | Kenmore 53542 / 53544 Side by Side...
My bottom freezer refrig. Kenmore 596.72214200 - suddenly smelled weird burning smell from back of frig., hear occasional clicking sounds. Everything seems to be working. Smell seems to happen when...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 31, 2011 | Whirlpool Refrigerators
Not getting cold
if both the freezer and fridge are warm most likely the compressor isn't running and i'd have to say you could have a bad start device on the compressor,but you didn't send the model number or that much info so this is just a guess.you might hear a clicking sound every couple of minutes or you could have smelled something burningthat would be the start device,you can unplug it,remove the back bottom panel,pop off the start device and shake it,if you hear parts rattling around it's bad or you can check it with a meter,common problem
Apr 09, 2011 | Kenmore Side by Side Refrigerator
I have a Kenmore side by side fridge Model 51562101. We just noticed a burning type of smell coming from under the freezer side. My wire thinks the smell is more like a chemical smell. The fridge is...
Your compressor just went bad...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 15, 2011 | Kenmore 62832 / 62834 / 62839 Bottom...
I have a Roper side by side refridge-freezer. We smelled an electrical smell last night. Today the freezer/icemaker thawed out and the refridge also did not cool. I have pulled the back off and checked...
Refrigerator
heatman101
Jan 04, 2011 | Roper Refrigerators
I have 3 central ac units for my house. 1 for the upstairs and 1 for the west side of house and 1 for the east side of house. just had a very cold night and the east side of house vents smelled like...
To make sure that there is not a problem with your blower test it on cool. if it runs good. then start the heater on auto and it should be okay. but still supervise the operation for about 5 mins. if you still smell something burning . then call an AC Technician for help.
Albert Saavedra
AC Technician
Fort Worth/Dallas TX
773-627-8766
Dec 28, 2010 | Heating & Cooling
Freezer is all deforsted. Fridge is 5 years old. We smelled a burning smell 2 nights ago and now everything is defrosted. We couldnt tell where the smell was coming from in our house. Motor is running....
If the evaporator (freezer) fan and the condensor (bottom rear) fan are both running but you have no cooling at all, the odor you smelled was probably the compressor start relay/overload device. It would be in your best interest to have a professional service technician look at it. Proper repair could mean the difference between a $60 part, or a $300 compressor. Prices are for the part only.
Dec 23, 2009 | Refrigerators
Model 106.53632300 couple of days ago smelled something (burned electrical type smell). Now both fridge and freezer not cooling. Cooling fan in back on bottom is running.
you may have a fried start or run cap and hopefully not a spendy board like everything runs on these days....bad caps(capacitors) will cause compressor not to start and run but arent needed for fans to kick on ....
Jun 28, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore model 525321 overheat problem
hi thanks for the question after your husband replaced relay & overload if the compressor started & kept on running but no cooling you have a bad compressor
Sep 13, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 53532 / 53534 Side by Side Refrigerator Logo
220 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
