Question about Sony KP-53XBR45 53" Rear Projection Television
By the blinking led means I have a bad ik video path
How do I repair this issue? In need of help. Thanks ahead of time.
2 Suggested Answers
  • 3 Answers
SOURCE: Sony KP-41T65 41 in. Rear Projection Television
Bad Picture tube
Posted on Dec 26, 2008
KV-32s66 Flashing stby timer LED- no pic no sound
check for any short circuit on the board.
Oct 07, 2008 | Sony KV-32S66 32" TV
I am repairing a sony TV KV-32FQ70E. The led blinks 5 times, stops and blinks again. Please tel me what means.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly, (G2 voltage).
Check the tube emmision, it may be too low to track, causing that error.
Hope that helps
Dec 14, 2010 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
Tv is slow to power on and dull screen image, then shuts off and a steady green blinking light in front.. i've had past issues with this tv, but this is a new one..
sounds like the jugle chip IC301 video path is defective,short to ground IK video path is defective,....you can get parts at Mats Electronics #1--800-628-1118
Feb 16, 2010 | Sony KDF46E2000 46" Projection HDTV
Sony Bravia KDL-52XBR9 wont turn back on red led flashes unless I uplug and plug back in. Did firmware upgrade to newest aa0143pn, still happening.
There is a error in TV.Count how many times blinking the red light.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight GA_googleFillSlot("TL-IMU-Article"); blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board. GA_googleCreateDomIframe('google_ads_div_TL-IMU-Article' ,'TL-IMU-Article');
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" boards
Nov 16, 2009 | Sony BRAVIA KDL-52XBR6 LCD TV
Sony mod# KV-34HS420 - won't come on - red led blinks 7 times...
how many times does the light blink it is very important you mention it so that i can be able to help you.if it is blinking continously then that means your jungle ic301 the ik video path is defected have a tech look on your set for repairs,good luck
Jul 12, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony 50 Wega LCD flashing red light
Hi
How many times is the red light flashing? The number of times the red led blinks means---
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
  • No blinks(Unit is dead) - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony KV - 36XBR400 36" keeps going to standby - blinks red x5
5 blinks is an IK balance problem. it means your picture tube is not drawing the correct current on 1 of the 3 cathodes (IK). there is a good chance the tube is bad. if you reported it while under warranty you should call the warranty company and pursue it.
Jan 12, 2009 | Sony KV-36XBR400 36" TV
Picture and sound cuts off ,greem stb light keeps blinking TV turns on after 30 secs shuts off after 30 secs comes back on. Continious loop
How many blinks do you get? Depending on the amount of blinks you can figure out what the issue is.
If it blinks 6 times you can get the fix at
No power RED Standby LED flashes 6 times/KDF55XS955, KDF60XS955, KDFE55A20, KDFE60A20
They have other fixes for E60A20
http://www.agoraquest.com/viewtopic.php?topic=31806&forum=70&keyword2=electronics
Dec 28, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
WONT TURN ON
If you know how to trouble shoot solid state electronics and know how the curcuits work, then Im sure you can handle this repair. But my friend a tv set is not a place for a handy man to be experimenting around inside of, as there is alot of high voltage inside this set even when its turned off! Its best if you do not know all of the safty issues to seek out a pro to assist you in this repair. It could be a bad solder connection, or a bad filter capacitor that supplys the B+ to the video chip. Without looking at a schematic and tracing the circuit, its all a guess. There are no real user replacable parts inside this set. Good Luck PS please do not forget to rate this thread.
Nov 25, 2006 | Sony KP-61HS20 TV
Televison & Video Logo
97 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
