I cannot turn on my AV 2260 EY1. Nothing happens. I have the power pluggd into the wall socket, but the laptop won't respond. We used to operate it without the battery and plugged into the wall. We did that for months without a problem. Now, with or without the battery in, I cannot get it to start.
More than likely the power supply has gone bad. If you or a friend has a Volt meter you could test to see if electricity is getting from the wall to end of the cord (USE CAUTION TO NOT ZAP YOURSELF). In general the first thing to stop working on a laptop is the battery, and the second the power supply cord. That is my guess. How do you fix the power supply cord... buy a new one. I tried to fix one once, ended up all bad.
SOURCE: my laptop's battery cannot charge
Check your battery if it is not dead, remove the battery and find a soft button near to a level indicator... pressing it will check if it lights less than one-half or none at all then the battery is dead... In that case, you need to change it with a new one.
Hope this Fixya the problem...
SOURCE: battery problem...
Sounds like an hardware problem. The battery charger does not depend from the operative system, and is working even when the computer is turned off and connected to power socket. Leave your laptop off and connected to power overnight. If the battery charge is still zero then you probably need to get a new or tested-second-hand battery.
hope this helps
