Question about Philips 32PF5320 32 in. HD-Ready LCD Television
Philips 32PF5320 LCD TV: ? Tuner failure
Progressively more and more channels are becoming distorted (snowy display and noisy audio) Iniatialy it was a few channels, now it is multiple (channels 15 - 50) Other channels are OK
Is this a tuner problem?
If so, do I need to replace the tuner board (how, where do I buy one) or can it be repaired (see www.tiptoptuner.com)
Any ideas on how to pinpoint diagnosis more accurately?
Thanks so much!
Jan
SOURCE: Philips 32PF7320A black screen
upgrad the firmware in the TV. This problem was resloved by philips with the software fix. you can locate the firmware on philips.com. good luck!
Posted on May 25, 2007
Mrvica
  • 167 Answers
SOURCE: Philips SAA7130 TV Tuner
Driver you have is not compatible! try to down load a newest version!!! and look on sound manager if mute is off
Posted on Jan 24, 2008
  • 30 Answers
SOURCE: Akai leisure 2111 TV
try to check the video section, the diode and the capacitor.also the transistor>
Posted on Feb 02, 2008
Bubbabear64
  • 2794 Answers
SOURCE: can't install TV Tuner Philips SAA7130 for Linux???
There may not be a Linux version of the driver. Only Windows is available
Posted on Jun 11, 2008
SOURCE: jalal_1_1_1@hotmail.com
Tou a pedir o driver Philips SAA7135HL Multimedia Capture Device. o meu endereço e Eniomadeira"yahoo.com.br
Posted on Jul 08, 2008
Sound becomes distorted after changing channel requiring pushing mute button and back to sound again to restore proper sound
Tries tv unplug,replug it back like about an hour.By letting the tv by resetting itself back to the factory setting.Now goto the tv menu goto Audio Setting,go down to do resetting,so resetting the tv Tuner board for resetting sound,setting back to factory setting.This should solved ur sound problems.
Jan 30, 2011 | Vizio M370VT 37 in. LCD TV
Philips 32pf732198 no sound on certain channels
Unplug,replug the tv an hour later.Go to ur tv menu reset the Audio setting.The setting will go back to the factory setting,should work solved ur problems.Not than ur Tuner signal board have problems,must change.
Apr 06, 2010 | Philips 30PF9975 30 in. LCD HDTV
The sound is distorted and overwhelmed by static
Depends what the real problem is.
Is it related to certain sources only - try new or reseated cables,swap it to a different input; single channel - swap to isolate; or certain controls that have become noisy? A shop might be able to get some tuner cleaner into them.
Mar 12, 2010 | Panasonic SA-XR25 Receiver
Channel Scan on my Philips 26" TV only finds the local channels.
Hi.
you should go into your tv's setup menu and go to the tuner settings and make sure it is set to CATV (cable tv) and not Antenna/Air also splitting a cable to many times can cause the signal to weaken and gain a lot of noise/distortion that could be an issue that can only be solved by having the company come to the house and do a test ALSO when your in the tuner menu in under your tv's setup menu try adding a non local channel manualy and then see if the tv will tune to it, if so then you might have to add them manually at the worst... my guess is that it is not set to CATV/cable tv hope this helps and if not i hope someone else can.
May 24, 2009 | Philips 26PF5320 26 in. LCD Television
Philips 32PF5320 LCD TV: No video
Perform the flashlight test and then repost your findings for an answer.
Sep 09, 2017 | Philips 32PF5320 32 in. HD-Ready LCD...
Get Dtv with my 37MF321D
This TV does not have built ATSC/RF Tuner.
I have this same model TV, the analog reception is snowy even with outside aerial. I have to get the Govt, Set box converter and the picture is now perfect! Apply for the Govt Digital TV converter Box and you will enjoy it
Feb 01, 2009 | Philips 37MF321D 37 in. LCD Television
Snowy screen on tv
the 3 or for setting on the vcr is on the back( a switch)
or if the cable box has a channel 3 or 4 setting on the back of the box
but otherwise the tv may need some work on the tuner or need a new tuner
Dec 01, 2008 | Philips CCC130AT 13 in. TV/VCR Combo
Hitachi snowy screen and noisy
you have broken solder connections inside the tuner, you`ll need a tech as it is soldered in and once removed the board inside will have to be re-soldered. An alternative would be to use the AV outputs of your cable box or vcr to the AV input of your tv, this bypasses the tuner circuit, you will of course have to go into the tv`s menu and switch to AV 1 or AV 2 whichever input you use, good luck& Happy Holidays
Nov 29, 2007 | Televison & Video
I have the 13 inch and...
If you get channels 2 to 13 nice and clear but the rest are snowy, it means that the TV is set to the broadcast channels, which means that for the channels above 13 it is tuning in the old-fashioned UHF channels. If the TV is set to the cable mode then it tunes in cable channels above 13. To do this, enter the menu and navigate to the tuner settings, set the tuner to standard cable and then do the autoprogram, and the tuner's memory will be set for your cable system.
Aug 03, 2007 | Emerson EWC1903 19 in. TV/VCR Combo
Philips 32PF5320 32 in. HD-Ready LCD Television Logo
225 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
