Question about Motorola Mobility H680 - Headset - wireless - Bluetooth - black
Headset won't trun off.
After turning the switch on the headset to off, the light continues to flash & the cellphone says the headset is still connected & on. Bizarre!
  • 1 more comment
  • Faye McGee
    Faye McGee Feb 24, 2009
    I have a push button.
  • Faye McGee
    Faye McGee Feb 26, 2009
    I'm sorry. It's not a push button, it's a switch. I was thinking of the button to answer a call.
  • David Shaub May 11, 2010
    Do you have a switch or a push button?
    President:
  • 2,976 Answers
You'll have to hold it in for 3-5 seconds .
Posted on Feb 25, 2009
I have a Sennheiser MM100 Bluetooth headphones that has stopped responding. It will not turn on/off and the LED light is blinking a continuous blue. How do I get it to function again?
Found this online. Hope it helps you out.
Switching the headset on
To switch the headset on:
Press and hold the Play/Pause button for 2 seconds.
An ascending confirmation beep is heard in the headset and the LED indicates the current operating mode. Flashing in blue indicates that the battery charge status is OK; flashing in red indicates a low
battery (see page 6).
The LED flashes several times every second:
The headset is paired to one or several Bluetooth devices and tries to connect to one of these devices.
The LED flashes slowly (once every second):
The headset is paired to one or several Bluetooth devices. However, there is no current connection because the
Bluetooth device is switched off or out of range.
The LED flashes once every 3 seconds:
The headset is paired to one or several Bluetooth devices. However, there is neither an audio transmission nor an active call.
The LED is glowing slowly every 4 seconds:
The headset is paired to one or several Bluetooth devices, a sound file is received via A2DP and played back or
paused.
The LED flashes once every second:
The headset is paired to one or several Bluetooth devices and there is currently an active call.
If you switch on the headset and keep the Play/Pause button pressed for 5 seconds, the headset will go into pairing mode (see ?Pairing the headset? on page 9).
The LED flashes alternatingly in red and blue for up to 60 seconds:
The headset is not yet paired to any Bluetooth device. Pair it as described under ?Pairing the headset? on page 9.
Oct 31, 2012 | Audio Players & Recorders
When trying to pair my plantronics voyager 50 to my iphone, i am attempting to get the blue and red light to flash by pushing the up volume and the call button. but no flashes occur, even after 60 seconds...
  1. Turn on Bluetooth within your phone. Put phone into pairing mode.Put headset into pairing mode - With headset on, press and hold call button and the volume up simultaneously until the headset begins to flash red and blue.
  2. Pick the headset for Plantronics when prompted. Enter "0000" (four zeros)
  3. you should now have a continuous blue light blinking.
  4. Choose "Yes" if your phones asks if you want to bond to the Voyager 510 bluetooth headset.
Good luck from Headsets Direct - 800-914-7996.
Aug 13, 2011 | Plantronics 510 Voyager Headset - PLN-510...
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
My bluetooth /plantronics explorer-210, and it does't connect w/my cellphone ,flashing blue light,that's all,what I to do..,help me
Your headset must be in pairing mode, in order to be discovered by your phone. Whenever it is in pairing mode, its indicator light flashes in red and blue. If it has never been paired before, just by turning it on, it should enter that mode. If it doesn't, it is because it has been paired to ohter phones before. In this case, after turning it on, press and hold the call button until the indicator light flashes red and blue. Then, make your phone's bluetooth application search for new devices. After a while, your headset should appear on-screen. Select it and make the application connect to it. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). You see, the pairing process between any two bluetooth enabled devices should be perfomed just once. All subsequent connections should be achieved by bringing them with each other's reach (with their bluetooth radios turned on, of course). At most, a simple press on the call button should do the job.
Hope you are able to sort your problems out soon.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Regards, Carlos
Oct 10, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Mary.farnerI LOST MY MANUIL! NEED TO TRUN IT OFF AND ON
Turning On: Press the On/Off Button for aprox. 2 sec. Both icons will flash intermediately to indicate the headset is powering up.
Turning Off: Press the On/Off Button. When both icons flash intermediately and then go out, the headset is off.
For a complete guide or to see the full user manual try this site...
http://www.jabra.com/Sites/Jabra/na-us/Headsetsupport/Pages/JabraBT2080.aspx
Aug 16, 2010 | Jabra BT2080 Bluetooth Headset
Head set not pairing with sony erricson k750i
The solution for paring the explorer 240 is found in the bottom of the product page for the embedded link on the User Guide Link. I have also provided the instructions below. I hope this helps
How to Pair Your Phone With Your Headset for the First Time
1 Turn on the Bluetooth feature on your phone.
For most phones, select Settings/Tools > Connections >
Bluetooth > On. See your phone’s user guide for more information.
2 Turn the headset on.
Turn on your headset by sliding the Power Switch toward the microphone. Wait until the indicator light flashes red then blue.
If you don’t see the red then blue flashes, turn the headset off, then turn it on again. Press and hold the Call Control button until you see the red then blue flashes that indicate pairing mode status.
3 Set your Bluetooth phone to ‘discover’ to locate the headset.
This usually involves going to ‘setup’, ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add a device’.
4 Once available headsets are listed, select your headset (for example 2XXPlantronics or 3XXPlantronics). If prompted for a passkey, enter 0000.
When pairing is successful, the indicator on your headset flashes blue. Your phone will also confirm when pairing is complete.
John M
May 06, 2010 | Plantronics Explorer 220 Bluetooth Headset...
I moved from a Blackberry world edition to a Blackberry Tour and now my plantronics explorer 210 bluetooth headset will not pair with the Tour. The Tour does not pick up the headset or my car speaker when...
I was having this exact problem and as soon as I did this it connected. I only had to do up to step 3. I have the same phone and the same headset.
How to Pair Your Headset if it Has Been Previously Paired
With Another Device
1 Turn the headset off.
Slide the power switch off, then wait until the indicator turns red
and then turns off.
Slide the power switch on. After the headset is powered on, press
and hold the call control button until the indicator light continues to
flash red and blue.
3 Use the commands on your phone to locate your headset.
For most phones, select Settings/Tools > Connections > Bluetooth
> Search > 2XXPlantronics. See your phone’s user guide for
more information.
4 When prompted for the passkey, enter 0000.
Pairing is successful when the indicator on your headset flashes
blue. Your headset is now connected and ready to use.
Apr 13, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Get laptop to see ATT V521 bluetooth headset
I think you need to "unpair" the headset from the phone. Try turning off the bluetooth head set, and then deleting the headset from the list bluetooth devices on your cellphone. Then turn the head set back on, and once it discovers that it cannot connect to the cellphone, it will become "discoverable" again.
Jul 25, 2008 | Audio Players & Recorders
Jabra BT125 Bluetooth
First u switch off the Jabra Headset..
then switch ON the Bluetooth in ur Cell.
then search for active devices in your cell..
while searching switch ON the bluetooth Headset.press and hold it continuous until the light is on.
you must hold it for approx 15 sec..
then the jabra wil be displayed in your cellphone....
tats it....add it....
enjoy,,
Nov 28, 2007 | Jabra BT125 Headset
Motorola Mobility H680 - Headset  - wireless - Bluetooth - black Logo
89 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
