Question about Kenmore 46462 Front Load Washer
Code F06 during drain cycle. Any solutions?
  • Anonymous Mar 15, 2014
    moded ghw9150pw1
  • 15,935 Answers
The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 – is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
Kenmore Front Load Washer won't complete cycle F06
Have you cleaned your machine lately? They make an in wash boost- it gets rid of the extra suds built up inside the machine that you cant see but your machine detects it and causes faults such as that. Also, there is a small wire on the control board that may need replaced if it keeps kicking the error code.
Apr 07, 2016 | Kenmore Elite 45986 Front Load Washer
I am greeting a flashing code of F06 as in goes into spin cycle and it stops running.
The F06 code will indicate a drive motor tachometer error.This means the control is unable to properly detect motor speed and the machine will shut down. If the failure occurs during high-speed spin, the door will unlock after 3 minutes.
The error code F06 is likely a loose connection in the harness between the motor and the (MCU) or between the (MCU) and the (CCU). It could also be the tachometer circuit in the motor or an intermittent internal component connection within the (MCU). Since the (CCU) has already been replaced, the failure is likely a loose harness connection or the (MCU). I recommend calling a service technician to check the connection.
Hope this helps.
Shane
Apr 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My duet ht front loading whirlpool washer goes through a complete cycle then during the spin and drain ( the last cycle) it displays a f6 notice and will not complete the cycle, you cant get the wet...
Hi
Thanks for using FixYa. Error F06 in your washer indicates that the control is unable to properly detect the motor speed and so the washer shuts down. This usually occurs during high speed spin and the door will be unlocked after 3 minutes. To resolve this issue you’ll have to check the wire harness connections between the Driver motor and the Motor control unit (MCU). If that is fine then check the connection between the MCU & central control unit (CCU), replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Machine stops mid cycle with F06 error
Hi
Thanks for using FixYa. Error F06 in your whirlpool duet indicates that the control is unable to properly detect the motor speed and so the washer shuts down. This usually occurs during high speed spin and the door will be unlocked after 3 minutes. To resolve this issue you’ll have to check the wire harness connections between the Driver motor and the Motor control unit (MCU). If that is fine then check the connection between the MCU & central control unit (CCU), replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Code 06
In the manual for a Kenmore washer the instruction for an F06 code (electrical problem) is :
Select PAUSE/CANCEL twice to cancel the cycle. Select DRAIN/SPIN if there is excessive water in the washer. Re-select cycle and press START.
After that, you might try unplugging then plugging it in again.
Jun 06, 2010 | Kenmore 23822 Top Load Washer
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Error code
Copy and paste link for list of error codes and solutions. Is machine drum turning at all during cycle , or any problems draining water? Please reply on FIXYA with better description of your machines fault in order to pinpint problem. Regards.
http://www.repair-help.com/kb/index.php?article=544
Jun 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
W/pool awm8143 not finishing cycle fault F06 flashing on display
I had this same problem, an intermittent F06 fault.  The F06 code means a tachometer fault.  After some fault-finding, I did manage to fix it.  If this error code happens to you and you know a bit about electronics, try taking apart the timer and looking for dry joints between the main board and the perpendicularly-mounted microprocessor board. Over time vibration can cause the soldered joints between the two boards to crack and fail intermittently. 10 minutes to disassemble plus 2 minutes with a soldering iron could save you a $400 repair bill.
The service manual is available for download on the web if you google hard enough.  If you have a CRO available, the tacho waveform should be a nicely-formed sine wave with a frequency proportional to the RPM.
Mar 29, 2008 | Whirlpool AWM8143 Front Load Washer
F 06 whirlpool duet washer
mcu is responsible for the f06 fault code
Mar 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 46462 Front Load Washer Logo
Sal De
fordexpert
Robert Rankin
