Question about Poulan P3314 14" Gas Chain Saw 2.0 Cuin 33CC 2 Cycl
How do you get new fuel line into the gas tank of poulan chain saw?
  • 3 Answers
FIrst off be sure you have the correct size line. Poulan uses several sizes of fuel line. If you got the wrong one, you won't get it to go in. The best way is to cut the tip of the fuel line at an angle. If you warm the fuel line before inserting it, it will go in easier. Once you get it forced in a little ways, you can reach in with a pair of needle nose pliers and pull on the fuel line while pushing it in from the outside. If you bought the line from a Poulan dealer, then instructions would be included along with the end being precut at a long angle to assist with installation.
Posted on Feb 25, 2009
Poulan chain saw model #2025 - fuel lines dry rotted and disintegrated. There are 3 fuel lines: l from gas tank and 2 from primer button but only 2 fuel ports on the carb. What goes where and how?
You should have 2 to the tank, the one with filter coming from tank goes to nipple on right side of carb, the nipple on left side by primer bulb goes to primer bulb and other from primer bulb back to tank as return line, how it should work is when you push primer bulb it pulls fuel from tank through carb and back to tank on return line so watch in tank orleave one line out that you think is return line and see if gas comes out when you prime, but remember it goes through the carb first before it goes back to tank, had a pic but too big to put on site sorry, 2StrokeJim
Oct 11, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
How to connect the fuel lines for Poulan Model # 1950 Chain Saw
The following link should be very helpful:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
A link to a Poulan model 1950 Type 7 follows (may not be your saw, there are 7 different Types and 2 Woodsharks (LE))
http://www.ordertree.com/modelinfo/PWE/1950-Gas-Saw-Type-7/75.1950-Gas-Saw-Type-7.1.59.1.html
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jul 22, 2010 | Poulan 14" Chainsaw
ON a Poulan 220 Pro all of the fuel lines are
Your fuel lines are routed like the schematic below. I suggest you replace the filter, all hoses (2 different sizes), and the purge button (bleeder).
Let us start with the bleeder. The 2 hoses that connect to the bleeder are different sizes (Important). If the nipples are the same size connect a hose temporarily to one of them and place the free end in a small container of mix (please be careful with open gasoline and as soon as it is no longer needed put it out of harms way.). Squeeze the bulb if it blows bubbles that is the return side, it gets the large hose and attaches to a fitting on the tank. If it appears nothing happens but when released fuel is drawn into the bleeder it requires a short section of small hose and attaches to one of the carburetor fittings.
A second small hose goes through the tank and connects to the carburetor just like the video including the filter. It feeds the carburetor like it has since before bleeders were installed. I am not certain which carburetor fitting connects to the tank or the primer, please leave them long enough to swap until the saw is running. Logic says the upper most fitting (air bleed) goes to the primer but that is not always true. The Poulan drawing is deceptive it appears the filtered line feeds the bleeder it does not!!!
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Fuel components and part numbers are listed but are on different illustrations. They are also beneficial with disassembly/reassembly.
A link to a Poulan "PP220 Gas Saw Type 5 follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP220-Gas-Chain-Saw-Type-5/75.PP220-Gas-Chain-Saw-Type-5.1.59.1.html
If your saw is not a Type 5 you can find the correct IPL here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
Lou
May 06, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Fuel line routing
A typical fuel system and a couple of suggestions follow:
An example of an IPL for a "2055 Gas Chain Saw Type 7" follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2055-Gas-Chain-Saw-Type-7/75.2055-Gas-Chain-Saw-Type-7.1.59.1.html
If not your saw, yours can be found here:
Poulan.com
I am reasonably sure the upper most carburetor connection (it bleeds any air in the carburetor, air rises) goes to the primer. Leave the hoses long enough to swap them and try it. They can be shortened once you verify the correct routing. Good Luck. HTH
Lou
Feb 24, 2010 | Poulan Pro Chain Saw 46cc 20"
Replace gas line poulan-4000 chain saw
Typical fuel system:
9803f93.gif Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly. HTH
Lou
Nov 07, 2009 | Poulan Pro Chain Saw 46cc 20"
Fuel lines have rotted off. need to replace then
Mr Tittle;
It isn't good but it's all there is.
What little fuel system system detail there is can be found here:
Poulan.com
If it is a 2375 WildThing find 2375LE Gas Saw Type ?. The last digit of your serial number should be a -1 or -2, the type.
  • The filtered hose from the fuel tank connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as the bulb reinflates).
  • The pressure side of the primer returns any excess fuel to the tank as it is depressed.
HTH
Lou
Oct 24, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
How do I install fuel lines on a poulan chain saw model 1950?From carburator to primer,from primer to fuel tank,two connections on each.
The smaller line comes from the fuel filter in the tank to the nipple on the side of the carb with the cover w/ 1large screw in the center, the other small line goes from the other nipple on the carb to the primer bulb, the larger line goes from the other nipple on the primer bulb back to the tank, and only gets pushed in about 1/2-3/4" into the tank. Hope this helps.
Feb 26, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan #2550 farmhand saw, Put a new carburetor on saw still not getting gas to carb?
Try emptying the fuel tank, and with small flashlight inspect the fuel line and the sump pick-up screen inside the tank. You may be able to gently retrieve it with a stiff wire hook. See if the hose is cracked/broken of if the screen is clogged. If all is well, be sure there are no kinks in the entire fuel line.
Hope this helps
Feb 23, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan P3314 14" Gas Chain Saw 2.0 Cuin 33CC 2 Cycl Logo
395 people viewed this question
Top Poulan Tools & Hardware - Others Experts
Bill Boyd
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a Poulan Tool and Hardware - Other Expert? Answer questions, earn points and help others
