Question about IBM I System Board (61H2600) Motherboard
How do I Access BIOS screen in a IBM PII-6862-84U?
And change boot sequence to CD ROM before Hard drive. Test driving from a CD a different OS.
  • 102 Answers
As the computer boots press the DEL key to access BIOS
note: some systems you must press F2 or Esc
In BIOS under the BOOT tab options change the Boot order so that the CD drive is First
Select EXIT and Save Changes to reboot
note: make sure the CD is in the drive BEFORE you reboot!
(it sounds obvious but a lot of people forget)
If the CD is bootable it will start its own boot sequence.
Posted on Feb 22, 2009
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
How to reset all settings to my lenovo a269i mobile thru pc
Is it a think pad ?
Power off your Thinkpad.
Press and hold the "F1" key and turn your Thinkpad on, still holding the "F1" key down.
Release the "F1" key when you hear repeating beeps. Wait for the "IBM BIOS Setup Utility" to load.
Select "Startup" using the arrow keys and press "Enter."
Select "Boot" or "Startup Sequence" and press "Enter."
Select "CD-ROM Drive."
Press the "F6" key repeatedly until "CD-ROM Drive" sits at the top of the list.
Insert your recovery CD into your Thinkpad's CD-ROM drive.
If you have multiple recovery CDs, insert the CD that has "Disc 1" on its label.
Press "F10" to save your changes and exit the BIOS Utility.
Select "Yes" and press "Enter" when the "Setup Confirmation" window appears.
Your laptop will restart. Wait for the Recovery Utility to load.
Select "Restore to Factory Specifications" to erase the contents of your hard drive and reinstall the Windows version and drivers that your Thinkpad originally came with.
Follow the Recovery Utility's onscreen instructions.
When prompted to insert another disc, do so according to the numerical labels on your recovery CDs (e.g., insert "Disc 2" after "Disc 1" and "Disc 3" after "Disc 2").
Your Thinkpad restarts when the restore process finishes. Power off your Thinkpad.
Hold down the "F1" key and power on your laptop to access the "IBM BIOS Setup Utility."
Press "F9."
Select "Setup Defaults" from the menu and press "Enter" so that your Thinkpad no longer boots from the CD-ROM drive.
Press "F10" and select "Yes" to confirm your changes.
Your Thinkpad will restart and load your newly installed operating system.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-61432
ThinkVantage Technologies downloads
Feb 20, 2014 | Computers & Internet
Change boot cd rom bios300
Your IBM 300 series desktop computer is normally set to boot its operating system directly from the installed hard disk drive.
There are some cases where you may want to boot from a different device, such as loading from the floppy drive to install a new operating system.
In order to change the boot order on the IBM computer you need to access the Basic Input Output System (BIOS) menu.
Close any applications that are still running.
Turn off the IBM 300PI computer and then turn it back on again.
Tap the "F1" key when the "Configuration/Setup Utility" prompt appears at the bottom of the screen.
Tap the down arrow key four times to highlight the "Start Options" entry.
Press the Enter key.
Highlight the "Startup Sequence" entry and then press Enter again.
Scroll down and highlight "First Startup Device."
Press Enter. Scroll through the list of available boot order devices.
Highlight the device you want to use, such as "CD Drive" or "Floppy Drive," and press Enter.
Press the "Escape" key twice.
Highlight "Save Settings" and then tap Enter.
Power off the IBM computer and then power it back on.
May 06, 2013 | IBM 300PL (PC 300 PL 733) PC Desktop
How to restore system
im assuming you have the recovery disk
Restart the computer and press the pause/break key on the keyboard.
This key will slow down the boot process and allow you to see the motherboard BIOS access key that you'll need to press in order to access the motherboard BIOS.
Press the respective motherboard access key and check the motherboard BIOS for a boot sequence.
Change the settings in the boot sequence so the primary boot device or the first boot drive is the CD-ROM or DVD-ROM drive.
Insert the system recovery disc into the disc drive.
Restart the computer and allow it to boot up before doing anything.
A black screen should show up with the words Press any key to boot from disc CD/DVD.
Press a key to have the system boot from the recovery disc.
Allow the system to load.
Follow the on-screen instructions on how to install the rest of the operating system.
There are many different settings for you to choose.
If the operating system is just a little out of whack, you can choose to repair it.
The system recovery disc will contain important drivers and software for all the components connected to the computer system.
If you do not have a system restore disc you can search the Internet for drivers and software that are packaged for your specific eMachines model.
Restore the BIOS to their default settings so the hard drive is primary boot sequence.
This is an optional step.
You can leave the CD-ROM drive as the primary boot drive, but it will slow down the startup process by a few seconds.
hope this helps
Sep 30, 2012 | E-Machines W3503 PC Desktop
I have a ibm thinkpad r51 but when i turn it on it will load to somewords and il say media test failure check cable exiting intel boot agent then it will jut stay there
It's trying to boot from a LAN or Network. You want it to boot from your hard drive.
Temporary Fix that you will have to change each time you turn on the laptop:
Notice the screen when you press the power button, at some point it will tell you the keys to hit to get into the Bios or System Setup and the key to hit to Change the Boot Order. Hit the key to Change the Boot Order and select the Hard Drive
Permanent Fix
Notice the screen when it boots up and press the key that allows you to get into the BIOS or System Setup. Tab over to the area that allows you to set the Boot Sequence. Set your Hard Drive as the 1st Boot.
The best boot sequence is:
1. CD/DvD Drive First (Just make sure nothing is in the drive when you boot)
2. Hard Drive 2nd
Apr 21, 2012 | IBM ThinkPad R51 Notebook
How to test a hard drive to check controller cannot load or format mine or from cd and do not have boot disk can you help
What is ur OS and board? Upon starting click on "del" to go to BiOS and go "BOOT" sequence, choose CD ROM as ur 1st boot sequence! Exit w/ save changes! Now ur ready to install a new Windows OS, insert a OS cd and re start ur desktop! upon starting "START CD ROM" click on "enter"! Let ur windows do everything and follow the instructions!
Taaa!
Nov 08, 2010 | Computers & Internet
Can't instal xp
You can try and tap on the F8 key when the computer is booting up and see if an optional boot menu pops up and if it does then select the CD-Rom Drive to boot from the CD, and if not then you will have to go into your BIOS setup and change the boot sequence to boot from the CD-Rom Drive first. Also, if you already have windows on the hard drive and you are using a modified boot screen you might get an error when you try to install XP.
Jun 10, 2010 | IBM (25P3294) Motherboard
IBM T30 2366-FBU, will not boot passed Logo screen
Press all of the function buttons one at a time until you get a response. Not all laptops use the same buttons for Bios and choosing the boot device.
Also, it won't boot from the CD-ROM because the bios boots from the Hard drive first by default. You can change this in the BIOS.
Please rate, Thanks!
Feb 27, 2009 | IBM ThinkPad T30 2366 Notebook
My pc was doing this but now it's doing something different but simular
Try telling it to boot the CD instead of the disk for now, since you need to install from that...or perhaps a newer OS.
Jun 23, 2008 | E-Machines eMachines T3830 PC Desktop
Boot sequence
161 and 163 error means you have to change your CMOS battery. open the laptop, change the cmos battery and you should be able to set the date and time.
after which you can access the bios by pressing F1 upon boot up and change the boot sequence after that
Mar 30, 2008 | IBM ThinkPad 380ED
Computers & Internet Logo
376 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
