Question about Kenmore Elite HE4 Electric Dryer
Dry will not heat
The heating element will not come on
  • Kenmore Master
  • 19,396 Answers
The machine must be repaired, most of the repairs below require a technician.
Check thermal fuse at the back and ensure that the door is closing well.
Check if the fan is working , if it is not working test and eventually replace fan assembly.
If the fan is ok check if the heating element is working, eventually test it with a multimeter.
Test also the thermostat and eventually have a look at the door latch.
If the machine still does not get hot , and all tested part are fine, then replace the control assembly.
If you need a technician ring the number listed on the owners manual.
You can also find parts and diagrams for your model entering model number here.
Posted on Feb 21, 2009
Temperature sensore probelm
make this test and fix it. God bless you
Heater
This is the most common reason why your dishwasher is not drying. To check this remove the toe kick, remove one wire from heating element and check ohm reading. Compare the reading to the tech sheet or service manual. If it has no continuity at all replace the element. Make sure the element is getting power. To do this connect voltmeter to each lead of the heating element then select a dry cycle you should have 120 volts if not the problem is in the control. If it does have power and does not heat up replace the element. The heating element is easy to replace
Timer/ Control
This is not as common as the heater but can fail. To check this select a dry cycle and check to see if the heating element has power if it does not replace the control If the element does have power and does not heat up replace heating element.
Jul 24, 2013 | Dishwashers
Water not heating
Heater
This is the most common reason why your dishwasher is not drying. To check this remove the toe kick, remove one wire from heating element and check ohm reading. Compare the reading to the tech sheet or service manual. If it has no continuity at all replace the element. Make sure the element is getting power. To do this connect voltmeter to each lead of the heating element then select a dry cycle you should have 120 volts if not the problem is in the control. If it does have power and does not heat up replace the element. The heating elements is easy to replace9f39612d-286d-4ab9-9ae7-61bc229b8105.gif.
Timer/ Control
This is not as common as the heater but can fail. To check this select a dry cycle and check to see if the heating element has power if it does not replace the control . If the element does have power and does not heat up replace heating elements
May 23, 2013 | Dishwashers
Dishes won't dry. Is heating element the likely problem. Is it replaceable
What temp is your water? You may need to set your water heater up a notch. Try running the dishwasher on the "sani rinse" since this heats to 160 and see if they are drier. Is your heating element working? During the dry cycle with the heat dry on I would open the door and put my hand next to the element to see if it seemed hot. Maybe it isn't working. Also did you put Jet Dry in the dispenser?and also if the setting is adjustable you can dial it up a notch or two. I also like the Jet Dry Turbo. It makes my dishes dry completly, even plastics and this is on the no heat dry.
If there is no heat, then the heating element may be bad. You can get the part, and view diagram at partselect website.
May 18, 2010 | Whirlpool 24 in. DU920PW Built-In...
Drying problems
Check the front control panel for a AIR DRY / HEAT DRY switch. Perhaps the switch is in the AIR DRY position. If so and you really want to HEAT DRY your dishes, set the switch for HEAT DRY.
Second, it is not a bad thing to let your dishes AIR DRY. It saves money! Just open the Dish Washer door after the last rinse cycle has finished and let the dishes AIR DRY manually. In a hour or so they can usually be put away.
You can also check for the heating element.Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thank you!
May 14, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Not drying. is there a safe way to test the heating element?
Hello there
Here is a detailed list of things to check to ensure that the element is your problem cause there could be a couple of different things also click on the blue items
If the dry cycle has a problem, check these: Heating element Drying fan Thermostat Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it. Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
Best regards mike
Apr 12, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher cycle runs: tablet is not dissovlved, dishes dirty
Heating element
Drying fan
Thermostat
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat.
Aug 29, 2009 | Frigidaire Dishwashers
Heating element not working
normally on a kitchenaid dishwasher the diagnostics cycle is activated by pressing heated dry - sani rinse - heated dry - sani rinse - heated dry - sani rinse - heated dry and this will energize the heating element but the only way to check is to see if you are geting voltage out of the board or by checking the resistance of the elment should usaly be around 16 ohm's
Mar 25, 2009 | KitchenAid Dishwashers
Indesit DI620UK Dishwasher fault
Heating element
Drying fan
Thermostat
Jul 19, 2008 | Dishwashers
Wet dishes
Heating element
Drying fan
Thermostat
Jul 19, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
Dishwasher not drying
Same problem here. I read the manual very carefully. "OptiDry", "ExtraDry", "EcoDry", "condensation drying" -- lots of fancy words to cover the simple fact -- they DO NOT DRY the dishes. There is no heating element. I wish they would just state this up-front. Air drying the dishes for 24 hours after each wash is not workable for most users...
Nov 12, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Kenmore Elite HE4 Electric Dryer Logo
75 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
