Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
Seem the gear is out of socket - KitchenAid KSM90 Ultra Power Series Stand Mixer
  • 4 Answers
Most likely the gear is broken if it sounds like it is skipping. You will have to disassemble the unit to replace the gear.
Posted on Feb 22, 2009
Older, (1950) Hobart A-200 runs in first gear no matter where the shifter is set?
My Hobart had a switch on the side to change Gears... 3 Different Speeds
Apr 11, 2013 | Hobart Food Mixers
My motor doesnt seem to go round freely
Does the beater shaft turn when there is no load? (bowl is empty) Or it will not turn at all?
It sounds like you have a stripped gear. Your mixer has a nylon/plastic gear inside the mixer and that is 99% of the time what goes wrong. You will want to open the mixer up and inspect all of the gears, but most likely you will need to replace the worm gear, part number W10112253.
Here at MendingShed.com we sell Genuine KitchenAid parts and the items can be found on our website.
Here is a link to that gear: http://www.mendingshed.com/kawormgear.html
You may also want to replace the grease and gearbox gasket while you have the mixer opened up.
We also have a service manual posted on our website which will aid in taking the mixer apart and putting it back together properly.
Service Manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Apr 09, 2013 | KitchenAid Food Mixers
How much grease should I pack into a gear box of a food mixer? should all cogs be covered?
pack it full the grease seems to find a way to move a way from the gears after a while so you new grease and pack it in
May 20, 2010 | Hobart D300 Stand Mixer
Beaters will not turn, motor runs....
They seem to have a plastic gear built in as protection for overloading (prob). When the machine counters to much resistance that gear will strip its teeth causing the machine to not be able to turn, that it what seems to be the grinding problem. If it is not the plastic gear then it another gear that is "stripped(of its "teeth") I hope your problem is not a severe, but if your mixer is "locked up" then at least you found the problem...
Hope this helped, if it did (or not) please rate, thank you!
Feb 01, 2010 | KitchenAid KSM150PS Artisan Series Stand...
My 6qt Kitchenaid stand mixer started making a grinding noise and beater bar keeps stopping. When I put it gently with my finger, it begins turning, only to stop again and make that grinding noise. It is...
Jan 12, 2010 | KitchenAid KSM150PS Artisan Series Stand...
First and second gears seem stuck
You most likely broke a keyway on page 14, item 36.
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/57866D624A678E7385256CB0007232DA/$File/F-19357%20(05-95).pdf
The unit is filled with grease, and is not as easy as it may seem. Being that a grease change is likely needed, it's about three hours work for a trained tech.
Jun 25, 2008 | Hobart A200 Stand Mixer
Beater jams
You are going to DESTROY YOUR MIXER by kneading dough with the flat beater. Read the directions. They spell it out in big letters. Only use the dough hook for dough; only use speed 2.
If the mixer generated enough torque to knead dough with the flat beater (it doesn't), it would tear up and overwork the dough. As it is, you're lucky you didn't strip a gear.
Dec 23, 2007 | KitchenAid KP2671 Professional 6 Series...
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
69 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
