Question about Sony Ericsson Walkman W810i Cellular Phone
W810i Camera, KEY & key pad lights not working
This is now the secound time i have had a problem with my camera button not working,the secound time has additional problems in that the right key does not work and also the key pad lights have stopped working also.
W810 lcd light not comeing
Posted on Nov 09, 2010
How can I stop the little yellow pad lock from flashing on my screen. I can not get in to menu or mode
Hi there remove the memory card and try to reset the camera from the menu option. If the menu key does not work then press self time button 4 sec to 6 sec for resetting the camera. Now let me know are you done the resetting or not. Thanks.
Feb 22, 2011 | Pentax Optio S5z Digital Camera
Camera button not working
andyirwin80 hello,
By default, the camera button in the W810i isn't the most successful one.
It usually requires a stronger press inside, until Camera Mode is on.
I'd suggest sending the handset to a certified lab if it is still under warranty.
If not, take the back cover off after having turned your phone off. Remove the battery.
Unscrew the little screws at each side, and divide the two panels.
On the panel with the camera button, please make sure the button is located above the pad that should be pressed and that there are no interruptions.
Then, put everything back on, and check if the button works properly.
Sep 06, 2008 | Sony Ericsson Walkman W810i Cellular Phone
W810i key pad problem
take the phone and have the keyboard service or replaced if that does not work then you can try a reflash of the phone to see if that also correct the issues.
Jul 18, 2008 | Sony Ericsson Walkman W810i Cellular Phone
key pad clean and or keypad replaced tested ok
Dec 09, 2007 | Sony Ericsson K750i Cellular Phone
W810i joypad and walkman key not workin
Its a common issue with sony handsets .open the phone  remove the touch pad and clean it  properly .
 if still it does not work  replace ur joystick 4rm sony carecenter.
 regarding network problem reinsall sim then try .
Oct 05, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Settings affected
The functions available from the arrow pad, which are Self-Timer (arrow left key), Exposure Compensation for adjusting brightness (arrow up key), Macro and Super Macro Modes for close up photos (arrow right key) will all be reset using the RESET arrow pad button. Also, the quality/resolution will be set back to the default of HQ, but settings such as the language, the date and time, sleep time settings are not changed by using the reset button. These settings need to be manually selected through the menus in order to reset or change them.
Aug 31, 2005 | Olympus D-545 Zoom Digital Camera
Settings affected
The functions available from the arrow pad, which are Self-Timer (arrow left key), Exposure Compensation for adjusting brightness (arrow up key), Macro and Super Macro Modes for close up photos (arrow right key) will all be reset using the RESET arrow pad button. Also, the quality/resolution will be set back to the default of HQ, but settings such as the language, the date and time, sleep time setting and video out to either NTSC or PAL are settings which are not changed by using the reset button. These settings need to be manually selected through the menus in order to reset or change them.
Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
Settings affected
The functions accessed from the arrow pad—Self-Timer (arrow left key), Exposure Compensation for adjusting brightness (up arrow key), Macro and Super Macro Modes for close-up photos (right arrow key)—will all be reset using the RESET arrow pad button. Also, the quality/resolution will be set back to the default of HQ. Settings such as language, date and time, and sleep time settings are not changed by using the reset button. These settings need to be manually selected through the menus in order to reset or change them.
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Settings affected
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Sony Ericsson Walkman W810i Cellular Phone Logo
383 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
