Question about Toshiba Satellite R10-S802TD Tablet PC
Satellite R10 Wont turn on
I have a toshiba satellite R10 and the power button keeps flashing and it wont turn on. Tried to remove the battery and then try turning it on, I also tried switching it to a different outlet, but none of these seemed to work. The power button just keeps flashing orange. Can you help?
Thanks!
TBBattery's been dead for a while, but I has always started up and run fine on AC. Tried it today and nothing... the power light flashes yellow but no start up. Tried different outlets, known good power supplies, taken out battery for 30 seconds and replaced. Can a dead battery do that? Don't want to buy a new battery if that's not the problem.
Any suggestions welcome,
Nward
  • nward45 Feb 21, 2009
    Only has one RAM module.
    Removed and replaced RAM
    Didn't work
    No beep, no fan
  • 628 Answers
When you press the power button, does anything happen? Or does the flashing light just continue? If so, you may have a damaged power control section in the computer.
Posted on Feb 21, 2009
    President:
  • 2,110 Answers
Open the back cover and check all connection on the motherboard...
    Brigadier General:
  • 8,619 Answers
Hi
Can you hear any beep sound. If Yes then how many beeps do you hear?? Is the fan running ? A dead/faulty battery can make it behave like this.
  • Rylee Smith
    Rylee Smith Feb 22, 2009
    Take the battery out and clean it then replace it back .You can also try to clean off the heatsink and the CPU fan. This will work for sure.
    Please revert for any clarifications.
    Thanks
    Rylee
  • Toshiba Master
  • 19,396 Answers
Try removing the ram modules and restarting the laptop with only one ram stick.
  • Ginko
    Ginko Feb 21, 2009
    Sorry , I was answerring to first problem.
    A bad battery can even fry a motherboard, but hopefully this is not the case.
    Ensure that the power adapter , then try starting the laptop with no battery inside and the external power adapter only.
    IF that does not work, you can test the ram, as explained before, but it can even be a motehrboard fault.
I just bought new lcd display for my Toshiba Satellite R10 Tablet. The inverter is fine, checked the cables and reconnected. But the screen alternately flashes solid white, red, green and blue on the...
you need to download the proper drivers for the Graphics Card Right click your desktop go to settings go advanced Go to the intel(R) tab and hit Graphics Properties thin pick' either Dual Display Clone or Extended Desktop and Click Apply.
Wierdly the Monitor 2 will Still he greyed out in the settings Tab but the monitor will display Good luck
I'm currently trying to figure out it I Can Rotate the tablet Monitor and keep the other monitor Un-rotated Any ideas?
Oct 19, 2010 | Toshiba Satellite R10-S802TD Tablet PC
My battery will not last upto 50minutes and my applicayions stops
It may be overheating or you are running too many applications. Try shutting some down from the start up menu.
Aug 19, 2009 | Toshiba Satellite R10-S802TD Tablet PC
No sound after clean install
i had the same problem, then i look for toshiba viturle sound wont work so try to install soundmax AC'97, coz R10 used Intel 82801DBM board. just search for intel 82801DBM Drivers
Mar 23, 2009 | Toshiba Satellite R10-S802TD Tablet PC
Clean dust from tablet pc screen
I have an R10 tablet.
I once asked a Toshiba certified technician if I could remove the screen cover and I was told that I am not supposed to do that.
Maybe you shoul take the unit to a Toshiba repair center in your town, or country.
Hope it helps.
Jan 20, 2009 | Toshiba Satellite R15 Tablet PC
clean off the heatsink and CPU fan.
Feb 23, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Problem with my tablet pc
Hi
The Satellite R10-S802TD doesn't have built in bluetooth device, however it's bluetooth compatible. any external bluetooth adapter will work. Toshiba recommends
PA3370U-1BTM Toshiba Bluetooth SD Card V1.2 or
PA3405U-1BTM Toshiba Bluetooth USB adapter as indicated you product's spec sheet.
Please post if you need further assistance.
Good Luck
Feb 06, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Satellite A45 S150
hold it down for 10 sec.
if that doesn't work remove battery and try again
Dec 29, 2007 | Toshiba Satellite R10-S802TD Tablet PC
Display problem in Toshiba Satellite pro L20
did you try the FN and F8 key and try that see if that turns the lcd on. If not write back here and we can figure it out.
Dec 18, 2007 | Toshiba Satellite R10-S802TD Tablet PC
Replacement battery
May I know your location? You can find it in Authorized Toshiba Service Center.
Dec 13, 2007 | Toshiba Satellite R10-S802TD Tablet PC
Toshiba Satellite R10-S802TD Tablet PC Logo
94 people viewed this question
Top Toshiba Tablets & eReaders Experts
micky dee
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
