Question about Panasonic PT-50LCX64 50" Rear Projection Television
Panasonic 50" dlp pt-50LCX64 shuts off blinking amber light
It just shuts off and blinks every so often but is happening more and more also when there is a white background i can see very faint pink and or blue blotches looks good when watching a movie though and ideas or suggestions would be appreciated
thanks in advance nathan
SOURCE: Mitsubishi WD-62525 DLP has no picture
the lamp went out in our wd-62525. I replaced it and cleaned the filter, now it makes a strange noise every few minutes and the picture gets distorted, then it's fine.We have had this set for only 16 months and have had to replace the mother board. What do you think the problem may be?
Posted on Feb 18, 2008
Gurudristi
  • 98 Answers
SOURCE: PowerShot A80 can't take pictures
http://www.fixya.com/support/r1237608-canon_powershot_cameras_pink_black
It seems that this is a problem with some of the canon pwershot series.
Please check out the link above regarding the same.
Please rate this solutions and thanks for using FixYa!
Posted on Mar 08, 2009
  • 108 Answers
SOURCE: pink pixils on light background
When this happens the voltages on some of the circuit boards can be adjusted to claer up this problem. THIS IS NOT some thing a person should do them self, the voltages are dangerous and critical to the operation of the set. "This should only be done by a trained service technician."
Posted on May 26, 2009
Sparko1
  • 167 Answers
SOURCE: Blue streaks and faint blue blotches on screen
The Optical Block / Light Engine is the problem. Very expensive repair / over $1000
Posted on Aug 08, 2009
Testimonial: "Optical block was the problem and has been replaced and TV is like new. Thank you for your response."
SOURCE: Panasonic PT-50LC13 Power Light Blinking Yellow
My Panasonic PT-50LC13 when turned on has a green light for a few seconds you can hear the fans turn on and then you have a yellow/amber light that starts to blink 8 times i have replaced the bulb and the door is closed any ideas?
Posted on Oct 15, 2009
Power button blinks twice orange. What does this mean?
Sounds like the Power Board might have died on you, and its flashing an error.
Nov 29, 2015 | Panasonic PT-50LCX64 50" Rear Projection...
Panasonic PT-52LCX66 blinks green then red lamp light comes on
Replace the lamp cartridge. You can get the replacement DLP lamp from www.tvrepairworld.com and the lamps come with installation instructions
Oct 27, 2012 | Panasonic PT-52LCX66 Projection Television
Panasonic tv turns off by itself model number PT-50LCX64 then the light flashes yellow
Repair/service manual of this model no. has a list of error code by means of led light flashes and its color and the probable caused of the symptoms. Once you've determine the caused, you may decide whether to fix it yourself or hire a professional. If you want the copy, click here.
Jdvillanueva
Sep 29, 2011 | Panasonic PT-50LCX64 50" Rear Projection...
I have a Panasonic PT-50DL54 50" rear projection tv. My tv screen won't come on but the fans will. The power led light flashes green like normal but than starts to flash fast for about a minute than the...
Time to get a new TV. I have similar problem. In my case, the set turns off, LED blinking green for about a minute or 2, then the set will turn on by itself. Something the LED started to blink yellow after blinking green and then shuts off. I can turn it back on. This happens 3 or 4 times in an hour. After that, the TV stays on for as many hours as I want until I shut it off.
And then the problem repeats everytime I turn it on from a cold start.
I have my eyes on the 50 inch Plasma from Panasonic. Bestbuy has one for 999.99.
Jun 14, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Anyone know what 8 blinking orange lights means?
Not good news i am sorry!
8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board
Please rate my help++++Thanks for using Fixya
Apr 16, 2010 | Panasonic PT-50LCX64 50" Rear Projection...
My panasonic pt50lcx64 will not stay on, sometimes wont even turn on, but when it does, it lasts about 5 min then cuts off and the yellow light blinks 2x every 5 sec
Try typing your model tv along with the words "trouble codes" This could be a code 22 or a 2. Sounds like a bad connection or bad component failing such as capacitor or resistor. The tv may be shutting down as protection against what it senses as a power supply failure.
Jan 08, 2010 | Panasonic PT-50LCX64 50" Rear Projection...
Panasonic Power Light Blinks Orange twice
sounds like the lamp driver or ballast is defective. That was a major issue on these model.
Dec 11, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Apr 01, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic pt-50lc13 shutting off
i'm on my 3rd bulb in 5 yrs. i hate this tv. this time my bulb light didn't come on. instead the power light flashed green fast then went to red flashing after. i took out the bulb and it's blown!
Nov 19, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LCX64 50" Rear Projection Television Logo
174 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
