Question about HP Pavilion dv6000z Notebook
HP Pavilion laptop restarts during welcome screen
The laptop will turn on fine it will run and have a while to enter the BIOS if necessary. Its a HP Pavilion dv6000 laptop. It will go to a black screen where it says
"We apologize for the inconvenience, but windows did not start successfully. A recent hardware or software change might have caused this.
If your computer stopped responding, restarted unexpectedly, or was automatically shut down to protect your files and folders, choose last known good configuartion to revert to the most recent settings that worked.
If a previous startup attempt was interrupted due toa power faiuure or because the power or reset button was pressed, or if you aren't sure what caused the problem, choose start windows normall."
It gives me 5 options
1. Safe mode
2. safe mode with networking
3. safe mode with command prompt
4. last known good configuration (your most recent settings that worked)
5. Start Windows Normally
I've tried each one the first three will show a bunch of text and reset while the last two will just reset the computer.
  • 115 Answers
Do the power drain
step1. Remove battery and ac adapter
step2. Hold on to power switch for 30secs-1mint
step3. Put back the battery and ac adapter
step4. Start the laptop as usual
IT SUD BOOT PERFECTLY
after doing this also if the symptoms are same
i apologise to tell u ...its gonna be Motherboard probs which is common nowadays in Most of the HP LAPTOP
Posted on Feb 25, 2009
After installing windows 7 ultimate with my hp g7-2118nr why does wifi driver cannot install
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"imake sure key scroll Hope this helps.
http://support.microsoft.com/
Jan 03, 2013 | HP Pavilion G7-2118NR Notebook
After installed a new hard drive im getting no bootable device found. what should i do?
the computer is looking for a boot device
make sure there are disk in the drives cd and usb
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys navigate to advanced bios features make sure its set to boot from your hard drive or
you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart this will set the boot order
if still no joy you might have to check the power and data leads connecting from motherboard to you hard drive for secure seatings
hope this helps
Oct 05, 2012 | HP PAVILION DM4-1265DX Laptop Screen 14...
Set up pavilion a1213w
Restart you computer during the boot process you will see on the screen to press a certain key to enter setup usually the F2 or the Delete key
Press and hold that key during the boot up process to enter BIOS the navigate to advanced bios features using the arrows keys press enter change your first boot device to cd press escape then press F10 to save to cmos to restart
hope it helps
Aug 01, 2012 | HP Pavilion a1213w (ED898AA) PC Desktop
Seting time
During the boot process you will see on the screen a certain key to press to enter setup
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date.
Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date
press F10 to save to cmos and restart
hope this helps
Jul 28, 2012 | HP Pavilion dv9208nr Notebook
I have a hp p6203w how do I enter bios
"HP
Pavilion:
Method 1
Enter the BIOS: Press F1 during the blue HP screen for setup.
In the BIOS: Advanced to Peripheral Configuration to Parallel Port Mode. Use ENTER key to open menu and select EPP. Press F10 to save changes and exit.
Method 2
Enter the BIOS: Press F1 during the HP boot-up screen for setup.
In the BIOS: Advanced to I/O Device Configuration to Parallel Port Mode. Use ENTER key to select EPP. Press F10 to save the changes and exit."
source: http://www.easeus.com/disk-copy/faq1.htm
Apr 08, 2011 | Computers & Internet
How do I factory restore my HP Pavilion dv4-2112TU with the recovery menu, safely.
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
Here are a few things you can do or try
Restart the computer. If you are already in Windows, you can do this from the Windows Start menu, go to Turn off computer and click Restart. As the computer restarts, watch for a progress bar at the bottom of the screen. press F8 about once every second. Immediately press F8 before the progress bar reaches the right side of the screen. From the Windows Start-up menu, highlight Safe Mode and press Enter. Wait for your desktop to appear, and then make the necessary repairs (for example, uninstall programs or devices). When the repairs are done, restart the computer, and allow it to boot normally.
Alternate:
From the Windows Start menu, click Run. In the Open field, type MSCONFIG and click Ok. On the BOOT.INI tab, check /SAFEBOOT.
Click Restart when prompted.
or
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
helps don't forget to vote
Feb 28, 2011 | HP 419320-001 - HP Pavilion dv4000 Series...
My boyfriend has a HP Pavilion ZV5000 laptop running Windows XP. Everything loads fine. then he trys to log into his user name, puts in the password... it sais loading your personal settings, then the...
Starting point would be to turn the computer right off including taking out the battery unplug the power supply wait a while and then reconnect power supply and restart holding down the key that allows you to enter the BIOS. Reset the BIOS to default settings and then restart. If this works then reinsert the battery and hopefully this will fix your problem.
Sep 11, 2010 | HP Pavilion zd7000 zx5000 zv5000 presario...
Black screen when i turn my cpu on hp pavilion a520n
Well, in the second (Gege) case you have a bad windows. Repair using a recovery CD (one most likely came with your comp). Whyme, take it in for repair; someones been messing with your BIOS.
Feb 04, 2009 | HP Pavilion dv6000z Notebook
Notebook not displaying a single thing
Can you get into the BIOS?
Restart ,. When the first screen appears, press F10 to enter the BIOS Setup.If you can set to default
Jan 06, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion dv6000z Notebook Logo
225 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
