Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
F50 error code and Whirlpool Cabrio
My Whirlpool Cabrio is flashing F50 (F then 50) when it gets to a spin cycle. I have tried unplugging it to reset any codes/memory but it simply reappears. I have the same problem with an 18 month old Cabrio. The tub fills part way then when it gets to the spin cycle it will not spin up, and then flashes error code F50.
My wife called the Whirlpool authorized repair folks and a few days later he showed up and did a few diagnostic tests. He concluded that it was a bad rps switch. His repair extimate was over $600. I declined and decided to order the parts he said needed replacing. After replacing them I still get the F50 code. I now believe the repair tech misdiagnosed the problem. I believe the real problem is a bad electronic control board. This Whirlpool model must have a serious design flaw or they are using cheap electronic components.
  • samayala4 Mar 14, 2009
    I have resolved my problem. I downloaded the repair manual for this model and went through a very detailed diagnostic procedure as described in the manual. At the end of that process I determined that the problem was the motor control circuit. I contacted Whirlpool again and they agreed to send out a repair tech to repair the machine at no additioanl cost to me. The tech showed up the following week, replaced the motor control board in about 15 minutes. If the initial Whirlpool authorized repair tech had done his job properly I would not have had to go through this ordeal. Plus he charged my $70 for a bad diagnosis.
  • 240 Answers
This code would indicate rps sensor at motor. whirlpools are very bad with electronics and control boards. New rps sensor requires new harness as well.
Posted on Mar 14, 2009
My Cabrio top loader keeps giving me the error cods F 50. I have tried to reset it,uplug it,and still get the same error code.
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
ERROR MESSAGE F50
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%^&*(
Jun 14, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My Whirlpool Cabrio WTW6400SW2 has a F50 error. I
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$%^&
May 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool cabrio washer, is flashing F then 50. It will start back for a second then stop and start flashing that again. What can I do? WTW6300SW
The F50 error code is a stalled motor error.There is a part called a "Rotor Position Sensor" that sees the motor running.This error will display if it does not see motor movement during a cycle.You want to make sure that the spin basket turn freely.Turn the basket by hand and it should turn freely.If it does not turn freely then it could cause the F50 error.If the basket turns freely then the problem is most likely the main control or the Rotor Position Sensor has failed.I recommend having a technician to
check this problem.
Apr 11, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio F50 Error
Most likely the RPS sensor or the control board. Originally they had trouble with the RPS sensors.
Aug 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F50 Error Code on Whirlpool Cabrio Washer
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&&&
Aug 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F 50 code after just having faulty circuit board replaced
May 02, 2009 | Washing Machines
Whirlpool cabrio washer keeps flashing code F50
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$$$
Jan 16, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Nov 07, 2008 | Whirlpool WTW6600SW Top Load
JUST SPOKE WITH WHIRLPOOL ABOUT THE F-50 CODE. THEY SAID THAT THEY ARE AWARE OF THE PROBLEM AND THEY ARE PAYING TO FIX IT. ALSO THE CONTROLL BOARD AND THE RPS SENSOR MUST BE REPLACED TO FIX THE PROBLEM. THE OWNER MUST CALL WHIRLPOOL, NOT THE TECH, TO GET THEM TO PAY FOR IT. HOPE THIS HELPS.
Feb 08, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
3,179 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
