Question about Dryers
Whirlpool dryer dryer will not come on when push button is pressed just makes a ticking noise is the ticking noise from the timer? could be a door switch issue...
  • Anonymous Mar 18, 2014
    when it's windy outside, and dryer is off, flapper doors makes too much noise
  • Dryers Master
  • 3,361 Answers
Ticking is from timer.
Check the door switch and the thermal fuse located on the exhaust vent.
Posted on Feb 21, 2009
Dryer doesn't start
Actually, it's probably the switch under the button meeting its demise.
Jan 14, 2018 | Whirlpool Dryers
Dryer drum want turn
I am hoping the problem is the belt. One way to tell is to put your ear to the machine and start it, and see if you can hear the mortor whirring. You should. If so, the machine should be needing a new belt. Most belts last about 5 years. If there is no noise of the motor, you may have either a defective door swirtch ( they are cheap plastic) or you may have an electrical issue.
Be blessed.
Jun 15, 2013 | Kenmore Dryers
My dryer is only making a ticking noise
one of the common reasons for that is the door latch, make sure it is not loose and or broken. post the model number for more info
Nov 24, 2017 | Whirlpool Dryers
Kenmore dryer makes the ticking noise but when we push the button to start the dryer it wont start. What should we look at?
Please check your Thermo fuse
and ticking noise should not be there unless the dryer is on which means that your timer is acting up
Oct 30, 2010 | Dryers
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
Dry want start
you will nead a nother person to help you make this test.first open the dryer door,next put the timer on timed cycle.with your right hand hold in the door switch,next have someone push the start button and at the same time take your left hand and turn the tub clockwise.if it starts than you have a bad moter.the age of the dryer will determin wether it is worth fixing.
Jan 23, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool LEQ8000JQ - My timer ticks but the dryer will not run when start button is push.
More specifically, the timer can be heard running, starts and stops when door is closed/opened, so not likely to be the timer. You have a problem at the motor. A wire off a terminal, the switch on the motor, or the motor itself.
Nov 29, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Timer ticks, but dryer does not run
Sounds like door switch. Open door and push on door switch. you should here a clicking noise. If you can open the top of the dryer. put the 2 wires together of the door switch. Make sure it is unplugged when doing this. Make sure you use electrical tape when you put it together. Temp fix. Get a new switch
Oct 23, 2009 | Kenmore 62602 Electric Dryer
Dryer won't start
There is a good chance it's the 'thermal fuse'
Aug 07, 2009 | Whirlpool LEQ9858P Electric Dryer
Our Kenmore clothes dryer is not starting.
its sounds like you have a broken belt or a bad door swith open the door rotate the drum manually if it feels verry easy to turn that means your belt is broken if not you can check the wires then replace the door switck thanks from gilles
Mar 15, 2009 | Kenmore 84052 Dryer
Dryers Logo
179 people viewed this question
Top Dryers Experts
