But it truns on all the times good
It depends on how fast you are going when you come to a stop.
If you are above 45 mph it could be the torque converter not releasing. If you are under 40mph it could be a faulty idle air control valve or a dirty throttle body. The computer controls idle speed by how much air enters the throttle body thru the control valve.
SOURCE: 1992 olds ciera just shout off
Sounds like a ignition control module failure. Check for spark at a spark plug wire. No spark then suspect module failure. Good spark-- Suspect possible fuel delivery problem. If spark is good then fuel pump may have failed.
SOURCE: The motor on my power antenna for my 92 Olds Ciera
Remove the glove box. Behind it will be the power connector to the power antenna. Disconnect it and problem solved.
SOURCE: Replace thermostat on 1990 cutlass ciera
the easy way to find this is to fallow your bottom raditor hose to the engine where it attaches is called the thermostat housing remove the hose and remove the four bolts then take out the thermostat replace it and re install don't for get your antifreez you will need to replace it do to the loss when you remove the hose
SOURCE: car stalling
sounds like mass air flow sensor on the intake system needs changing. check for vacuum leaks, make sure car has normal tune up done
SOURCE: car is stalling while driving. It also seems to
Have your fuel injectors checked !!.When they start going bad one or more will short out ,then the quad driver in the computer which controls injector pulse will shut down until it cools off a little.Then you can start your car .:)
Welcome to FIxYa.com
You will have to remove fuel tank and once you have access is on top of tank
Regards, Lee Davidian
Thank you for using FixYa,com.
can someone help me with question please
