Question about Hotpoint HSS25GFP Side by Side Refrigerator
Just changed pur water filter on kenmore elite side by side and now water dispenser drips
  • Anonymous Mar 15, 2014
    Pur water filter installation
  • 410 Answers
This is normal. trapped air from the new filter will cause it to drip until all air has cleared. if you will run about a gallon of water thru the dispenser it should help if not stop the dripping all together. thanks peyton
Posted on Feb 21, 2009
Changed my water filter on my Kenmore refrigerator. Now the water dispenser keeps dripping? The water filter is located at the bottom of the frig.
You have air in the line from the new filter . Run about 1-2 quarts of water thru the dispensor to remove the air in the line .
Jun 13, 2010 | Kenmore 57029 Side by Side Refrigerator
We just replaced the water filter...now dispenser doesn't work.
Looks like water is frozen in the tank .Unplug refrige from wall socket ,leave freezer and food compartment doors open at least 12 hours to melt frozen tank..
Jan 18, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
I have water leaking from the lower left rear side of my Kenmore Elite side-by-side with the ice maker ON.The leaking stops by turning the ice maker off-the water dispenser works fine with the ice maker on...
there are 2 pipes going from the pump at the bottom of your unit ... 1 to the ice maker and the other to the filter for water.
make sure the pip for the ice make is tight in the connector of the valve ... let me know...
Nov 27, 2009 | Kenmore 24.5 cu. ft. Side-by-Side...
Stomach pain drinking from refrigerator water dispenser
Get a charcoal filter from home depot (about 50.00) and install behind refrig or in cabinet . Filter has replaceable cartridges like for charcoal , lime , calcium . Installs in supply line to refridg . Do not recommend the 11.00 filter installed in line , where you replace the whole filter . Get the replaceable cartridge type .
Jul 20, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Water not cold anymore
the tank in the fridge may have a block so only the warm water is coming in and not cycling thru the tank to be chilled? would be my best guess
Jun 18, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice and water dispenser lock light stays on and comes back on quickly after pushing and holding. No water or ice dispensed while light on. Kenmore Elite 23.1 ft side by side refrigerator
I resolved the problem on my Kenmore Elite model 106.55616400 by removing the drip tray, taking out two screws that hold the panel, and disconnecting and reconnecting the wires from the panel to the board. Unplugging the refrigerator did not work.
May 28, 2008 | Kenmore 25.1 Side-By-Side Refrigerator...
I have the opposite problem
You may have air in the system. When you actuate the dispenser it opens an electric valve in back to start the flow of water. When you release the dispenser air in the system expanding will cause the water to continue to flow until the pressure equalizes.
May 21, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Refrig with Filters water and ice dispenser- water is dripping when not in use, no flow when activated
valve needs to be replaced. it is located in the back, just follow the water line to it. to shut off water there is eaither a shutt off behind ref or in the basement. again try to fallow the water line
Oct 22, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
239 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
