Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
WILL NOT CHARGE /CRAFTMAN LT 1000 17.5 OHV
WILL RUN WITH NEW BATTERY, BUT DIES WHEN DISCONNECTED... SON IN LAW JUMPED IT OFF WITH A 12V TRUCK SYSTEM
  • 24 Answers
You can jump off a off truck ,just dont have the truck running the
altnator can be to strong for the diodes in the tractors charging system (rectiforer).
Posted on Feb 23, 2009
  • dr1plain Feb 23, 2009
    Today's rectifiers won"t put out voltage if they are not hooked up to at least 7 volts if your trying to run it off just the alternator and you eng has a electric fuel shut off on the bottom of the carb it wont work .
    I bet its alright I have seen very few rectifiers blown from jumping
I had gone out and bought a new battery for my truck and it still keeps dieing, but even when it dies i still drive my truck until i turn it off and then it wont start back up. is there anything else that...
CHECK BATTERY VOLTAGE WITH TRUCK IDLING.SHOULD BE 13.5 - 14.5 VOLTS. IF NOT ALTERNATOR NOT CHARGING BATTERY.IF ALTERNATOR NOT WORKING TO KEEP BATTERY CHARGE.THE TRUCK WONT RUN RIGHT.YOU PCM,CANT FUNCTION AND CONTROL ALL THE ENGINE CONTROL SYSTEMS.YOUR FUEL SYSTEM , SPARK SYSTEM NOT GOING TO WORK IF BATTERY DONT HAVE POWER AND ALTERNATOR NOT WORKING. CHECK ALTERNATOR POWER FEED WIRE AND VOLTAGE REGULATOR WIRES AND CHECK ALTERNATOR FUSE.MAKE SURE ALTERNATOR GETTING GOOD 12.6 VOLTS FROM BATTERY.MAKE SURE BATTERY FEED WIRE NOT BROKEN.
Jul 23, 2011 | 1994 Chevrolet S-10
My 1993 940 non-turbo just dies when running as if the alternator is bad. However, the alternator has been replaced. It still dies and needs to be jumped. When jumped, it'll run for a bit then die a...
OK the battery in good charge should be at 12.5 volts ( as measured with a voltmeter across the terminals) When the engine is running you should expect the reading to be about 14 volts. Put the lights on ( a load on the battery) and the voltage can go as high as 14.5v. Switch everything off (I mean everything..radio etc) and disconnect the negative terminal to the battery. Now put the meter in ammeter mode and measure the current between the negative terminal and the cable that is now disconnected. It should be really very low current (milliamps at most), switch on the lights to show ourself what that current drain looks like. If the residual current looks significant take out each fuse in turn and return it noting on pen and paper any drop in current when the fuse is out. This process will identify the circuit that is draining the battery. Check the wires and junctions in this circuit for shorts etc. If its lights try removing bulbs until the current drain stops If possible leave the fuse out over night on this circuit and see if this effects the battery's ability to charge and stay charged.
Aug 30, 2010 | 1991 Volvo 940
When the car is jumped it runs with the cables on all gauge everything works fine once you take the cables off the car idles fine untill you press the gas, then dies out<<
The alternator is not generating enough current to the coil to maintain the spark. This could be a bad coil or a bad alternator or BOTH. When you are connected with cables the extra voltage required as you accellerate the gas pedal is pulled from the DONOR car battery and motor. When running at idle your car DISCONNECTED there is not much demand for power. As you press on the gas the RPM increases requiring more spark than you car can produce and it cant recover... trying to keep up drains what charge there is from being jumped off and the car dies. The fact that it dies leads me to believe the alternator should be your first troubleshooting area... You can test this with a multimeter. You should get 14+ volts coming out of the back of the alternator. The car requires 12 volts to run the engine and the extra volts are put back into the battery as a charge...less than 12 volts is a sign of a bad alternator and can cause your problem.
Jun 05, 2010 | 1994 Mazda MX-3
Replaced battery and alternator on ford ranger battery still wont charge and truck dies
check to see if 12v at alt power terminal then unplug three wire connector with key on should have 12v at green wire with red stripe 12v at black with orange (could also be grey with yellow)may be a white with black wire with 6v when running plugged in
Oct 05, 2009 | 2000 Ford Ranger SuperCab
No accessories working, but engine turns on and drives
Have the alternator tested if it dies when positive cable removed, the car is running from battery only
Jul 20, 2009 | 1992 Nissan Sentra 4 Door
How does the minn kota 65 all terrain run on 24
You should only run the motor with a 24v battery or two 12v batters 'jumped' out. To jump the two batteries, connect the positive on one batter to the negative on the other battery and hook the trolling motor battery cables up to positive and negative terminals that are NOT jumped out as you would normally. Don't run this with 12v as you will have serious problems if you do. They do not make a 65lb thrust in 12v - too much pound thrust to run off of 12v.
Feb 22, 2009 | Minn Kota Endura 30 Freshwater Transom...
Start truck up and a/t oil temp lt. blinking along with winter mode and power mode lt. blinks check transmision lgt stays on and brake and battery lt on and my volt meter shows no volts truck work fine...
I'm having the same problem. I have a 1992 Rodeo V-6 4x4. I replaced the alternator, battery, and even took out a killer stereo system in case of shorts (didn't have the patience to check). Except mine does start with a little boost. I'm thinking of replacing the battery for a bigger one, but not sure if that will take care of the problem. Help anyone?
Jul 31, 2008 | 1992 Isuzu Rodeo
Wiring diagram for radio
if your truck still has the wire connectors for the radio harness then your best bet would be to purchase the plug in adapters from wal-mart or local stereo shop,it should only cost about 10-15 bucks and would clarify your connectivity issues.or get a test light and at least determine power & ground wires then run new speaker wire
Jun 28, 2008 | 1988 Ford Ranger
Car won't start
as soon you remove the cable the cae dies alternator not charging you drove untill battery empty and it dies if you put a new battery without changing the alternator it gonna work untill there no more power in the newbattery cheers pierre
Jun 25, 2008 | 2002 Ford Escort
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
327 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
