Question about Insignia Digital-to-Analog Converter for Analog TVs
Promblem installing converter box
Only two mexican channels came on
  • cbmoosie Mar 16, 2009
    has anyone come up a solution to fixing the sound after installing converter box? It sounds like a loud humming in the background.
    Problem Solver:
  • 16 Answers
Well, I guess you will be learning spanish to enjoy those two channels.
Actually you need a stronger antenna. Go to a home improvement store and get a outdoor antenna, that should solve your problem. Check Antennaweb.com to see were to aim the antenna at. The digital channels are mainly moving over to the UHF signal band thus make sure you get a antenna that picks up booth uhf and vhf. These run less then 100 dollars. There is no such thing as a digital antenna thus do not fall for that nonsense that large electronic retailer are pushing. You might as well burn some of your hard earned cash.
Posted on Jun 09, 2009
Hi, My Tv is a Sinotec Full Hd and I brought it from South Africa, however I cant seem to pick up any channels
The USA converted to all digital awhile back. There are still a few analog channels in my area, but I'm relatively close to the Mexican border. You might try an analog to digital converter.
Feb 03, 2016 | Televison & Video
I have 3 or 4 channels that I can't get off Mexican language. I went to settings and put in English , but these channels still speak in mexican
Changing the setting s to english only makes all the set up words in english. There is no way you can change the program audio to another language.
Oct 12, 2015 | Panasonic Viera TH-42PX80U Plasma TV
Connecting a sansui 13 inch to a converter box
1) Connect the converter box to a good digital TV antenna and position the antenna as high and as close to a window as possible.
2) Set the converter box 'output switch' to an unused channel for your area. (Usually 2, 3 or 4.)
3) Connect the output of the converter box to the 'antenna input' on the TV.
4) Turn on both units and set the TV channel to the same output channel selected above.
5) Now select TV channels using the converter box remote only. The TV should receive all converted channels on the preselected channel.
6) Adjust the TV antenna for the best reception for all channels.
May 04, 2014 | Sansui Televison & Video
Good Afternoon, I have no cable where i live now, but i have a analog converter box, how do i install it to my tv to get local channels?
you install the cable wire into the box or antena into the box then the cable or rca cables into the tv. set the tv input to the right input (usually channel 2 or 3 for a cable) or input one for the rca cables then you need to hit the scan option on your converter box to scan for the channels and the tv to scan for the channels. please let me know if this works
Mar 14, 2011 | Televison & Video
How to install digital TV via Free View Box
Put ur tv in channel 3,take the cable came with the converter box put it in tv antna hole in the tv ,the other to the converter box said tv.Take antena,portable or roof antena put it in the converter box said antena hole. Go to menu resacan channels u done.
Nov 15, 2009 | Televison & Video
Quazar Model VHQ520/VHQ540 cannot record after inst Digital Conv
You need to set the vcr to channel 3 or 4 (whatever channel the digital converter box is set to broadcast on) to record a program. The digital converter box has to be set to the channel you want to record the show from.
Apr 09, 2009 | Quasar VHQ400 VHS VCR
I installed the converter box on channel 3 instead of channel 4
No reason to delete converter box from channel 3. Most converter boxes have a selection switch on the back for channel 3 or channel 4. Slide switch to 4 and set tv to 4.
Jan 13, 2009 | Televison & Video
After installing the DTV converter box, reception was dropped for most of the stations i received pre-box. now i have added a new antenna. and, i can't get anything through the converter box. connections...
If you have the box connected to the TV using an RF cable to the TV's antenna input, make sure the TV is on channel 3. You should at least see the boxes menu display when the power is on. Try channel 4 if you see nothing on 3. Every box I've hooked up has been on channel 3 by default, but who knows?
If you can, hook the box to the TV using direct video and audio connections, and make sure the TV is set to the correct input.
Unless the box you bought has "RF pass-through" (and if you got your box using a government coupon, it's a sure bet it doesn't) you will notice a marked drop in quality if you try to watch regular broadcasting with the box connected. I've been installing these with a bypass arrangement so people can still watch their analog broadcasts until they go off the air in February.
If the box does in fact have no display when you turn it on and your TV is on the correct channel, your box is defective and should be returned and replaced.
Dec 06, 2008 | Televison & Video
No antenna reception with digital converter box.
Hello Faznmc,
I have found that with an ordinary antenna connected to the converter box it can receive nearly all channels, however I have run into cases where I had to use an amplified TV antenna to pick up signals. I have started telling folks that when they install their converter boxes to try to use the plain old rabbit ears antenna, but if that does not work, use an amplified antenna, and that usually does the trick.
I hope this helps
Thank you,
Shuttle83
Nov 02, 2008 | Televison & Video
Dvd player/recorder DRW 500 does not pick up channels after installing DTV converter box. it will record directly but can't be set for timed recording because it did not find channels
You want to set the recorder timer to record the out put channel of the converter box (either 3 or 4 ) then tune your converter box to the channel you want to record, and leave the converter box turned on until you are done with the timed recording.
Jun 30, 2008 | Televison & Video
Insignia Digital-to-Analog Converter for Analog TVs Logo
97 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
