Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool washer wtw5200sq0 fills with water and stops. no agitation - no sound -- replaced timer but nothing
  • matthewpaper May 07, 2009
    The washer fills up and then stops working
    President:
  • Whirlpool Master
  • 2,651 Answers
Instead of timer soinds like a faulty lid switch, the unit not recognizing the door is closed so will only fill with water
Posted on Feb 23, 2009
My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Whirlpool Washer model # LSN1000KQ0 overfilling
    did you plug the hose back into the water level switch, double check to see if it is plugged, if it is your water level switch might be defective. trouble shoot by taking the front panel off... turn on the washer by using the timer, set water level to small...on the bottom of the tub housing there should be a nipple where the clear hose connects onto.....follow the clear hose from the switch down to the bottom of the tub.........disconnect the clear hose on the bottom of the tub.....plugg the nipple with your finger.........gently blow into the hose with your mouth.......but make sure the water level in the tub is at least at half way full...and the washer is on and filling up with water ...after you blow into the hose the washer should agitate.......if it does agitate your water level switch is defective...connect hose back........get your model number and source for the switch.........
    Apr 10, 2010 | Whirlpool Washing Machines
    Washing machine fills, but will not agitate, drain or spin
    Coupling broken which joins the motor to the gear box. Look and see or listen if the motor is running then if nothing else is working coupling is broke, easy to replace.
    Dec 05, 2009 | Whirlpool LSR5132PQ Top Load Washer
    Stops in the middle of wash cycle
    Hi!
    If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool washer stoped after the agitate cycle
    If it fills with water, agitates then stops still full of water (even if you manually advance the timer), you have a bad lid switch. This is an inexpensive repair, or even a do it yourself project.
    May 19, 2009 | Whirlpool Washing Machines
    My top load whirlpool washer fills with water, pumps out the water, but will not agitate or spin
    Check your timer if nothing else happens it sounds like a timer problem.
    Apr 18, 2009 | Washing Machines
    Not sure if manifold is leaking
    Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
    1. Agitation problems and agitator dog repair aid info
    2. Automatic dispenser information
    3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
    4. Diagnostic Direct Drive washer chart from American appliance
    5. How a washer works, good to read this first
    6. Help for storing an appliance
    7. How does the agitator come off my washer ??
    8. How to prevent socks from getting into your pump
    9. Ohm test a common direct drive motor
    10. How to by-pass a lid switch for testing the washer
    11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
    12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
    13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
    14. Important disclaimer
    15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
    16. My clothes have a whiting on them that looks like lint.
    17. My washer has a funky odor
    18. Noises
    19. Ohm meter testing a motor capacitor
    20. Slow water fills
    21. The wash tubs on my direct drive washer are leaning to the right...why?
    22. Timer stalls or missing cycles
    23. Timer will not advance
    24. Tips on changing a common washer fill valve
    25. To learn more about washing machines, click here
    26. Washer Basics: Filling with water
    27. Washer leaks water
    28. Washer moves around to much
    29. Washer will not spin
    30. Washer sample wiring diagrams
    31. Washer spins and agitates at the same time
    32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
    33. Washer runs but wont agitate or spin
    34. Washer won't run, agitate or spin
    35. What is that black power powder or filings under my washer??
    Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Washer will not progress to the rince cycle.
    that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
    I quote from : The cycle doesn't advance
    The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Whirlpool AWO3761 stuck mid-cycle
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
    605 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
