Question about Casio EXILIM ZOOM EX-Z850 Digital Camera
Monitor screen lights up but no image or menu can be seen
I have had my camera for 6 months, i brought it as a reconditioned item, up until now i have had no problems at all. But not when i turn it on the monitor screen first just had grey lines and then it goes white, i can't view the menu or anything else. Although if i do take a picture without any visual on the screen i can download it onto my computer and view it no problem. Please help!! Thanks
  • 374 Answers
If the screen won't show anything then you are going to have to send it in and have Casio look at it. More than likely the LCD is going out but just hasn't "gone" completely. Give them a call at 800-706-2534 and then option 2 and tell them that your lcd is going out and they'll tell you the closest place to send it.
Posted on Aug 02, 2007
What does the blue light in the corner of the screen mean
Sorry could not find the exact manual. however you can find it from this one as they ought to be similar
http://www.vivitar.com/files_products/1033/ViviCam_F124_Camera_Manual.pdf
It is called the METERING MENU - three modes (Centre; multi and SPOT). you are set for that spot. you can change that. see page 23
The Metering setting will affect how your camera focuses when capturing an image. Depending on your selection, the camera will be more sensitive to focusing on particular areas in the display and adjust the image color and lighting accordingly.
Center - Averages the light metered from the entire frame, but giving greater weight to the subject in the center
Multi - Used in standard conditions the camera divides and adjusts the settings of the image into several zones for light metering such as complex light conditions, position of subject, brightness, background, direct light and scenes
Spot - Meters the area within the spot point frame at the center of the LCD to set the exposure on the subject in the center of the monitor.
1) Press the M (MENU)/SET button to open the menus for the current mode.
2) Press the LEFT or RIGHT direction control buttons to scroll and select the chosen menu.
3) Press the UP or DOWN direction control buttons to scroll through the menu options.
4) Press the M (MENU)/SET button to select the desired option.
5) A selected option icon will appear on the selected item.
6) Press the LEFT or RIGHT button to select the next menu item. 7) Press the MODE button to exit the menu and return to your previous mode. 23
8) An icon reflecting your selection will display on the LCD screen 9) Remember that this setting will be saved by your camera until you manually change the setting or restore the camera?s default factory settings.
Apr 12, 2016 | Vivitar ViviCam 3188 Digital Camera
No image can be seen in the monitor
hi,
try this trick:
take a torch light and put it at approximately 30 degrees from your screen when the camera is running... can you se a bit off images ? if yes, your LCD back light is dead or the control chip is dead, or the ribbon cable is broken or just mooved...
Apr 11, 2014 | JVC Video Cameras
IMAGE IS NOT SEEN ON SCREEN BUT MENU IS SEEN
The CCD censor or circuit is faulty. Needs camera shop.
Dec 19, 2012 | Kodak EasyShare C613 Digital Camera
Screen cuts off image
To see the button on the right hand side of this monitor you will need to shine a really bright light on it, but the buttons from top to bottom are: 1, up-arrrow, down-arrow, and 2.
  1. On the side of the monitor press the 1 button to activate the menu.
  2. A configuration menu for the monitor will appear; from that menu highlight the "Input Select" menu item using the up and down buttons on the monitor; when you have the item high-lighted, press the 2 key.
  3. A new menu will appear, and then you can select the menu item called HDMI on the left and PC waaay over on the right. Select this menu item with the up and down arrows and when it is selected,
  4. And press 2 like you did in the previous step.
Apparently there's some sort of a strange difference between using this monitor as a "video monitor" and using it with a computer.
Nov 02, 2009 | ViewSonic VX2433WM 23.6" Monitor
My i85 camera's lcd no longer displays what you are looking at. Just a black screen. All the menu items are there and working. The battery is charged. The power button is working as well as the lens open,...
My i85 camera's lcd no longer displays what you are looking at. Just a black screen. All the menu items are there and working. The battery is charged. The power button is working as well as the lens open, but no image is available just a black screen. When I I try to take pic is showed very low light but doen't show image of pic taken when I check. Please advise. This a brand new camera and was taken excellent pic as of this friday. Groove_us@yahoo.com Mr.Tracy Johnson
Apr 26, 2009 | Samsung i85 Digital Camera
Lock/unlock symbol appears in the middle of the screen
5-22-09 Same problem last month. I had the problem a year ago for a month, then it stopped, reappearing this last month. Last week, I finally called support...I was accidentally transferred to a Dell "internal" technical support department...happily a very diligent technician spent a bit of time with me for free...for same problem, even though he confirmed I was over a year past all warranties. He confirmed this was a monitor problem (not virus, malware, etc.). He also confirmed their standard "guidance"/solution for this monitor issue (if under warrantee) is to replace the monitor (i.e. not attempt to fix it). New monitor needed. But problem again gone for last 10 days. So, when fully irritated, buy new monitor.
Apr 03, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Moto v3i camera is not working
You should take the phone to a mobile shop and have them flash the firmware on the phone.
Dec 11, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorolla v3i camera is not working
you should take the phone back to the store and have them fix the phone..the firmware needs to be flash on the phone.
Image not visible on monitor screen
you need to install camera drivers and application software again.
Oct 22, 2008 | Casio QV-R41 Digital Camera
My viewing screen is black. I had successfully taken a picture, viewed it, and turned the camera off. When I turned it back on about 30 seconds later, the viewing sceen was black. I can 'take' a picure, but it comes out black. Help!
Nov 12, 2007 | Casio Exilim EX-V7 Digital Camera
Casio EXILIM ZOOM EX-Z850 Digital Camera Logo
65 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
