Question about Garmin Nuvi 255 GPS Receiver
Garmin Nuvi 255 won't charge with the car charger.
When I remove the device from the charger in my car, the screen goes blank. I can't get it to turn on. Why won't the battery charge?
  • 1 more comment
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    I can guarantee that if you follow this video, you will permanently damge your Nuvi 255. A Nuvi 255 is not a Nuvi 760. They are physically different inside. I've replaced batteries and screens in both units.
    - Jim
    SHARCNET-USA
  • SHARCNET-USA
    Please look at this link:
    http://www.sharc.net/gps_charger_repair....
    - Jim
  • Anonymous Mar 29, 2014
    will not charge
  • 19,396 Answers
You may need to replace the battery.
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Posted on Apr 10, 2009
I cannot get my Garmin nuvi 255w to turn on even when plugged into it's power source - the car charger or the indoor plug in charger. There is no display, just a black screen.
Try a master reset. Hold the power switch to the left and hold for 10 seconds and release. You may also have a bad USB charging port. A common problem with units with USB only connectors.
http://www.sharc.net/gps_charger_repair.htm
Aug 20, 2013 | Garmin Nuvi 255 GPS Receiver
No battery status in the screen of Garmin 255. I just bought a new Garmin 255, before charging, it can not on, meaning, the battrey is empty, that is fine. Pluging the car charger, the unit can turn...
The battery status only shows up when the satnav is disconnected from the charger. Your first charge should be a continuous charge until the battery is full. This can be done by connecting it to your computer for 8 hours approximately or 4 hours to your car cigarette lighter socket or 4 hours to an, optional extra, mains charger.
May 20, 2011 | Garmin Nuvi 255 GPS Receiver
I've had two Garmin Nuvi 255 and have had problems with the car charger after a short period with both. I cannot charge my garmin while in a vehicle. Is this a common problem?.
you probably have a blown fuse in the charger plug..... Unscrew the silver tip end of plug CAREFULLY its spring loaded check fuse and replace with 3A fuse
Nov 22, 2010 | Garmin nuvi 255W GPS Receiver
Garmin Nuvi is plugged into the electrical outlet in my car. It appears that it is not having a good electrical connection because nothing comes up on the screen like it is charging. Unsure if it is dead,...
If the lighter socket is working ok then it may be the fuse in the charger plug that's gone. It can be replaced by unscrewing the silver ring at the end of the plug and removing the fuse. A replacement fuse should be available from garmin dealers.
Jul 29, 2010 | Garmin Nuvi 255 GPS Receiver
Nuvi 255 stopped working
Same thing here. Does anybody have any answers?????
Mar 25, 2010 | Garmin nuvi 255W GPS Receiver
Garmin nuvi 255 won't turn anymore
i had same prob about a month ago it sorted it's self out after left on charge for a week
Jan 20, 2010 | Garmin Nuvi 255 GPS Receiver
Nuvi 255w Turns off (screen goes to black) after a few seconds to a few minutes. No consistency on amount of time. "Turn Off" may be incorrect - screen goes blank/black Sometimes i can immediately turn it...
I have a Garmin 255 myself. And what I have found is, MOST of the time, the problem is that the CHARGER CABLE has an intermittent connection in it! So, when the cable moves, flexes, or stretches, the battery charge STOPS, and the (mostly discharged) battery cannot support the load, so the unit blacks out and turns off. Try S-L-O-W-L-Y moving the cable while connected with the unit on, and watch for evidence of a bad cable! Sometimes a DIRTY (trapezoid- shaped) connector will do the same thing!
May 11, 2017 | Garmin nuvi 255W GPS Receiver
Charging a garmin nuvi 255w
From dead flat it takes about 9-10 hours
do not leave on charger for more than that otherwise you will overheat and burn it out.
After each use recharge for about 3-4 hours depending on whether the unit has been used for that lengthyof time
Jun 30, 2009 | Garmin nuvi 255W GPS Receiver
Frozen screen and it says loader loading
Press the reset button - you'll find it on the lower right of the Nüvi 255, but it doesn't look like a button. It's basically the sticker with all the information on it. It's just enough to push the sticker carefully with something small, not too sharp so it doesn' get destroyed. The Nüvi reboots, the loader loads and proceeds with the software load. Once this is over, shut down the Nüvi and reconnect to the PC. Then, everything works fine (it did at least for me).
Feb 02, 2009 | Garmin NUVI 255 PERSONAL GPS Device
Garmin Nuvi 255 GPS Receiver Logo
4,831 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
