Question about Canon PIXMA MP530 All-In-One InkJet Printer
I have a paper jam.
The last piece of paper folded on itself and is stuck or rather thoroughly jammed.
  • 4 Answers
On all printes small pieces of plastic comes loose new ones are bad about it That is the cause of the problem. To remove the paper you need to open it and be careful to pry it loose, It might have to come out in pieces so don't get upset with it it is only time. after you get it out turn it up side down and shake it. There will be a small piece of plastick in there that is messing it up. then try to do a dry run with it. to make sure it is clear and if it spins you are ready to go with it Please don't use WD 40 on it I have one here in the shop that a farmer brought in 2 days ago that he tried to make it unjam. Please don't do that
Posted on Feb 22, 2009
A paper jammed, but I removed all of it. Every bit... The jammed paper is not missing any bity. But the jammed light will not go away. What can I do?
you have to check thoroughly, maybe some tiny paper pieces jammed , still stuck in between the roller or stuck at the sensor
Sep 04, 2013 | Ricoh Aficio 2018D All-In-One Laser...
Paper jam. paper pulls towards the right hand side and jams
Sound like you have something stuck in the paper feed path, check for a paperclip or similar, it may be that you have had a jam and torn off a piece of paper inside the printer which is now stuck, when removing jams from any nmachine allways pull paper in direction of feed never back on itself as it can cause this very problem
Dec 03, 2009 | Dell 810 All-In-One InkJet Printer
Major Paper Jam on Dell 5110
When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
1. Turn off the printer.
2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again.
If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and we suggest contacting the printer manufacturer for additional assistance and/or repair. *
To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer. Preventing a printer paper jam As mentioned earlier it is inevitable that you will encounter at least one paper jam during the life of your printer.
However, if you're encountering frequent paper jams following the below steps can help prevent paper jams from occurring. * If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled. * Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams. *
Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer. * Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper. * Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jul 17, 2009 | Dell 5110cn Laser Printer
Sharp 2300n gets paper jam. It fold paper like an
When you clear the paper from the machine at the fusing unit, you can see 8 pawls, it looks like a hook but in a flat design. They should be touching the heat roller ( each has a spring to make it flexible ). If one not touching the heat roll it will caused the paper stuck to it so you will have the accordion paper jam.
Jun 04, 2009 | Sharp Office Equipment & Supplies
Entire paper stack jammed at feed chute entrance.
check at the rear part of your printer there a backdoor latch there..
open it..and you can get the jammed paper easily..
if there is a pieces of paper left..you can get it by force..
rid the paper into pieces and clean the rollers of your printer..
and restart you printer..
hope it helps..
May 24, 2009 | Epson Stylus CX5400 All-In-One InkJet...
The machine says "paper jammed, open the front cover and remove jam papers" I have done this and turned it on and off, but couldn't find the jammed paper. what do i do? please help!!!!!!!!
there mat be a small scrap/piece of paper stuck in the bottom of your drum unit. pull out drum and look at the bottom right in the middle. if not there, open rear door and inspect thoroughly.
hth,
razors
Apr 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Printer jam upon exit
Check the paper output area ( around the output rollers) for a small piece of paper. You may need to disassemble the output paper assembly, and clean the rollers, or replace the paper output assembly.
In reality, what you have is one part of the printer trying to "push" the paper, while another part of the printer is trying to "pull", resulting in the wrinkle.. The problem may also be with a paper output sensor being stuck, which is why I suggest you check thoroughly for paper scraps in the output assembly.
Nov 14, 2008 | HP LaserJet 3030 All-In-One Printer
Brother 2040 paper light .. continuous red
If you removed a piece. But more remains it must also be removed. Look closely along the paper path for something that will release to provide access to the path.
May 03, 2017 | Brother HL-2040 Laser Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
76 people viewed this question
old marine
old marine
