Question about Dell Latitude C610 Notebook
When i press the on power the computer is not coming onn
When switch is turned on the lights comes on and then goes off, the computer shuts down.
  • bigdogdew Feb 26, 2009
    I have the same problem. I turn the computer on the lights come on momentarily and then the computer shuts down. There is no indication that the computer have started to POST. This happens with both battery and AC.
  • Barry Parks May 11, 2010
    Are you using the power supply or running the laptop on battery power?
  • 72 Answers
Hi there, It sounds to me like your Power supply. Try replacing it and see if it makes a differance, If not please let me know. Good luck
Posted on Mar 18, 2009
My computer says its restarting but it hasn't and it wont shut off
Hello, if the Windows operating system, then wait as the operating system upgrades.
Nov 11, 2016 | Computers & Internet
Gateway DX4822-01 power switch problems
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
Main wires such as Power On LED, Power On switch, HarDDrive activity LED, and Reset switch; IF used.
Suggest KEEP track of where those wires go!
Make a drawing, and notes. I even use a magic marker, (Sharpee?), and make a notation of the Front Panel header pinout, on the floor of the computer case.
In this particular case it isn't known if the Power On switch is the problem, or the Power Supply.
Power On switch;
Power UNPLUGGED to computer, Anti-Static Precautions FOLLOWED; (Don't know? Post back in a Comment),
Remove the twisted pair of W/B and W/G wires, to the Power On switch pins, in the Front Panel header.
Plug power back into computer.
Use a small flat tipped screwdriver, and touch the two Power On switch pins. (Jewelers screwdriver works well for this application)
Power Supply comes on? Bad Power On switch.
Allow Windows to fully load, run for a few minutes; then turn the computer off normally.
Jump the two Power On switch pins again.
Power Supply comes on? You DEFINITELY have a bad Power On switch.
Power Supply does NOT come on?
We will go to a further diagnostic test then.
Awaiting results for first test, then we will go on.
Post back in a Comment.
Regards,
joecoolvette
[Also; is the computer dirty inside? ]
Feb 19, 2013 | Acer Computers & Internet
Dell Inspiron 545 wont come out of power save mode - when switch it on it tries to start up but then goes into power save mode this then continues switching between power save and starting up until i
Do a full reset. Press power button down until computer shuts down, this will take more than 5 seconds. After that you can perform clean boot.
Aug 18, 2012 | Dell Computers & Internet
Can not get the power button to shut down the computer no matter how long I hold it down and the computer appears to stay in hibernation. Will not reboot or do anything when power is applied and power...
Remove the battery and leave off for about 1 minute. Put the battery back in place and press the power button to turn the unit on. immediately after you see system light come on, press and hold the power button and see if it shuts off after a few seconds. If not, then its likely your motherboard is defective.
Sep 07, 2010 | Toshiba Satellite M100 Notebook
My tower has power but won't come on
first guess is the motherboard is bad
a few things you can try:
unhook the monitor from the computer and test it on another computer. If the monitor works then its most likely the motherboard.
leave the computer unplugged for a few hours then plug it back up and give it another try just in case it overheated.
have the computers power supply tested as a bad power supply can cause all sorts of issues.
other than that you are down to a new motherboard and or a new computer.
Sep 09, 2009 | Compaq Computers & Internet
Power light goes out but power remains thru the m-board fan runs
you need to replace the power supply. The fan sound is the fan for the power supply and not the computer. for cheap parts or used goto headgap's. They know what you need and probably even help you replace it yourself.
Jul 03, 2009 | Computers & Internet
Tower problems
You may need to replace the cmos battery, its a cr2032 3v button cell
Make sure all your expansion cards and memory are reseated.
Make sure all cables are reseated.
your power supply could be bad
If that doesn't work try this
Here is my fix for the dell dimension 4400 amber light problem. It works!
replace cmos battery.
then unplug power cord form wall about 5-10 secs.
then plug it back in, wait 5 secs.
If amber light comes on, press and hold power button until it goes out.
(with light out, press and hold power button while amber light comes on and goes off again holding power button 2-3 secs after light goes out.) repeat whats in parenthesis until computer turns on
it should only take about 6, 7 tries.
After the computer boots, you may want to setup cmos or boot into windows.
After you shutdown, unplug power cord for 5-10 secs then plug it back in.
Press and hold the power button, computer should come on.
I found that's the only way to turn on the computer.
If you shutdown and don't unplug power cord the computer may not boot, mine didn't.
Strange I'd say
A+ Technician
Apr 01, 2009 | HP Computers & Internet
Dell inspiron 530s is giving me major trouble. When ever I turn it on, the power button lights up and the fan turns on but then thats it. There is no activity on the monitor, just the loud noise of the...
my inspiron 530 giving me trouble. Blue light is on, but the computer goes no where. Try to start by shutting down and restarting but the start sound keeps coming fora long time and nothing happens. So to say having trouble starting and sometimes it shuts down but the blue light stays on. Sometimes I cann't even turn off the computer by pressing blue light - trouble trouble trouble
Feb 22, 2009 | Dell Inspiron 530s Desktop Computer...
Emachine not turning off.
you can checkit by unhooking it on the inside from the mobo panal just remember where it ogoes back take a small flat head and cross the two prongs it comes of off then shut it down if it works look on ebay for a complete front panel with switch or order from emachines.
Oct 29, 2008 | E-Machines eMachines Desktop PC
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
Dell Latitude C610 Notebook Logo
81 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
Computer Links
