Question about Motorola Radio Communications
Talkabout t6530 walkies can't get them to charge
Just plugeed in my t6530 to charge (it's been over two years since I've used them) and the charging light won't come on. The batteries are dead, but we don't know if its the batteries that need to be replaced or the charge. Thoughts?
  • Motorola Master
  • 13,433 Answers
Hey,
You could use a multimeter to test whats coming from the charger, but I suspect the batteries might need to be replaced, or leave them on the charger overnight or for a few hours and see if theres any improvement.
Posted on Feb 22, 2009
I have k7gfv700 Motorola walkie talkies w/ charger. The charge seems to work, but the lighs one the charge are red and the talkie do not charge. Do I need new batteries and where can I purchase the
You might try http://wirelesspro.com, we have found them to carry most TalkAbout accessories and batteries. Before ordering battery packs, you might try switching your existing good battery to the other radio and see if it solves the problem. This would assure you that it is indeed a battery problem.
Sep 28, 2014 | Motorola Walkie Talkies 2-Way Radio
Where and how can i get a charging station for a Motorola Talkabout T5530 Walkie Talkie?
Hi Ken,
Take your radio in to your nearest Radioshack or similar store, and they'll help you to get the Charging dock for your radio.
I hope this helps.
Cheers,
Peter
Aug 07, 2012 | Motorola TalkAbout T5530 2-Way Radio
Talkabout t6530 walkies. Can't get them working. Both are on the same frequency and have all menu options the same. Took out the niclad batteries and replaced with AAs. They worked fine, put the niclad...
Your NiCd batteries are likely no good, or you could have a bad charger, considering your radio works with AAs and not the NiCD. This type of battery lasts about 14-18 months before needing to be replaced.
Best regards.
Jan 18, 2011 | Motorola Radio Communications
I have the cobra micro talk with rechargeable batteries my workers plug them up every night and get them in the morning but some arestill saying low battery, does the walkie talkie need to be turned off...
they charge better if they are turned off. since they do not have a paid dedicated channel, signals can
still be received by any walkie talkie using the same channel, and can deplete the charging process
to the radio. good luck!
Dec 07, 2010 | Cobra Microtalk 100 FRS Walkie Talkie...
Walkie talkie batteries don't last
The Batteries that Motorola uses will die after a while mainly because people leave them on the charger all of the time. But there is a way to refresh them. You let the battery die completely, then you charge it up for about 12 hours. Then you let the battery die completely. Do this a couple of times and the batteries will last long.
Also, Motorola use to make a battery refresher (or did when I worked there.) It will charge and drain the battery automatically. It will even give you a fault if the battery is completely dead. For the HT1000 (for example) it would be the WPPN4065BR.
For future reference, don't constantly charge a battery. Only have it on the charger when the battery is actually dead or very low. This will increase battery life.
Mar 25, 2010 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
The power button on the talkabout is jammed into the on position so the walkie will not charge or turn on. How can we fix this or where can we get it fixed?
Please open the set with the help of screw driver , & check for functionality of switch , & remove any particle that is jamming PTT button . You can check the functionality of walkie talkie by pushing the PTT inner switch with the help of a screw driver.
Sep 02, 2009 | Motorola Walkie Talkie 2-Way Radio
Motorola talkabout t5700
No, the charger is only usable to charge the rechargeable NiMH or Li-Ion battery which comes with the radio. Attempting to charge Alkaline rechargeable batteries with this charger could cause the to expode. If your charger is not charging the batteries which came with the units, it could be you do not have the charger cord end plugged in all the way, or the batteries dropped below the initial charge level by setting on a store shelf too long. Most TalkAbouts come with a cradle style charger to hold the radio, and a possible plug to plug into the charge hole. Check all connections, and clean any battery/charger contacts with a pencil eraser. To re-initialize the batteries you would need to attempt 3-5 charge cycles by charging for 8-10 hours, then letting the battery rest for 8-10 hours, repeating 3-5 times as needed. If this does not bring the battery back to life, you need to replace the batteries.
Jun 07, 2009 | Motorola Talkabout T5700 AA (22 Channels)...
Motorola talkabout t 6530
I just spoke with Motorola and they advised output for that particular charging base is 9 Volts 200 Ma output hope this helps, good luck!:)
Nov 11, 2007 | Motorola Walkie Talkie 2-Way Radio
Radio Communications Logo
156 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
