Question about HP JBL Platinum Computer Speakers
I cant adjust bass
When i go to the options and then the advanced options, it has where i should be able to change the tone but its greyed out and i cant use it. i have the JBL platinum series and so im guessing that i should be able to have more bass then minimum, theres basically no bass coming out as of now.
  • 265 Answers
You proberly have to download some drivers or them mate, google it :)
please rate
thanks
Posted on Feb 21, 2009
How to adjust bass and treble and surround sound
On the Remote Control
Press
1 TONE
ToneControl•OFF-
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
NOTE
The tone cannot be adjusted in the direct
mode.
3 Press
to select an item to be set, and use
TONE
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
"ON
Oct 24, 2014 | Denon Avr 391 5.1 Channel 110 Watt...
How can I change tone setting
You could try volume control > advance > Tone Controls. This will only work if you have decent sound card. Grey-ed out with lower end hardware. The other option is to use a media player with an EQ. Like VLC or Winamp.
Aug 27, 2012 | Logitech Z313
I just bought a UN46D6000SF and, while the pix is gorgeous, I don't like the flesh tones (they appear light/washed out). Are there any settings that I should adjust to make them more agreeable? Thank...
Adjust the picture temperature to a warmer setting.
Try this...
Advanced Settings Press MENU ? Picture ? Advanced Settings ? ENTER
There you will find a lot of options, one of which should include an option for Flesh Tone. Your TV might not have that option. If that is the case you would look around the menu's for color options or color temp and make some adjustments in those area's to make the pictures warmer.
Apr 08, 2011 | Samsung Televison & Video
When i go to advance volume control i cannot adjust bass and tremle setting both appear in grey colour
Hi, In this case please do try updating the latest audio drivers for the computer and that would help you get the features enables for adjusting the same. Thank you for your time and best wishes for your effort.
Jan 12, 2011 | Compaq Audio card Sound Card
How to adjust tone on sony tv without obvious tone controls
If this TV has a working remote, and unless it is older than dirt, you should be able to access the audio adjustments by punching the menu or set-up button and selection audio - from which you should see a graphic equalizer of some description. Then adjust your bass there and return to viewing by again hitting the menu button. It's doubtful you can do any of that, or even that you should have to, from the set front.
Nov 09, 2017 | Sony Televison & Video
How do you adjust the bass levels on a Yamaha HTR6130 receiver? I can get the display to show Bass 0db, but what button changes the settings?
When you touch tone button on your front panel repeatedly, you will get two option for setting bass and trebble, when you select Bass immediatly press your updown Sound field Program Button.
Please note:for better sound if your using Small front speaker keep bass to 0db and select the low frequency through sub woofer and program manually LFE from only Sub woofer and addjust CUT off frequency of Subwoofer to 160 and incase if your bass is not clear put it into rev mode.
Oct 05, 2009 | Yamaha HTR-6130 Receiver
How do I adjust the trebble on my Denon Receiver?
go to sound parameter in your parameter menu under the setup. There should be a tone control option, when there you can adjust the bass and treble by a variable decibel range. the range is -14db to 14db.
Jul 07, 2009 | Denon AVR588 Receiver
How do I use the remote to cont bass & treble for rxv-657 reeiver
No, Tone controls are on the front of the unit only. If your passing video thru the unit you can go into the setup menu from the harmony and adjust all the sound parameters that way "on screen" The only "EQ" capabilities are for the Center channel only. You can adjust "speaker size". "Large" setting will give you a little lower response. "Small" will crossover the speaker at "100hz" That's about as far as tone adjustment goes on this unit. Hope this helps
Jun 30, 2009 | Yamaha RX-V657 Receiver
'Keypad tones' option unavailable
change profile mode to custom sttings may be u are using the factory defalult profile setting
Dec 04, 2007 | Samsung SGH-D900 Cellular Phone
Prints dark black instead of grey tones
your drum is going bad. or your light or dark adjustment is set too dark ( it should be in the somewhat in the middle).
change drum
Nov 06, 2007 | Sharp AR-5316 Advanced Digital Imager...
HP JBL Platinum Computer Speakers Logo
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
rfredey
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
