Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater won't stay running
Model R150A fires but won't stay running, shuts down after about 1 minute. Air pressure is set at 5lbs, new spark plug, end cover and all filters. What should be checked next?
  • 350 Answers
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Posted on Feb 21, 2009
My heater runs great for about 15-20 minutes and then raw diesel comes out and it shuts down. I thought maybe the tank vent might not be working right so I tried running it with the tank cap off and it...
The transformer gets hot and stops making spark... then fire goes out....transformer cools down and it works till transformer gets hot...
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 02, 2011 | Reddy R155D Utility Heater
Reddy heater model r100a runs approxamitly 15 to 20 minutes then kicks out.fan seems to run fine and already replaced the spark plug.
generally if a heater with a spark plug will run for 10 minutes or longer then that’s an indication that the electronics are functioning properly, so for now, eliminate "any fuel delivery problems" before trouble shooting the electronics. The spark plug should spark for the duration of the run time. If the flame goes out the heater shuts down (just like its designed to do). Imagine the fumes & danger involved if the heater continued to pump raw fuel into a hot combustion chamber!
Some possibilities:
  1. the plastic end cover is cracked. When the room heats up the crack expands allowing the air pressure to fluctuate.
  2. the air pump pressure is not correct. (instructions at www.reddyparts.com )
  3. the fuel filter is restricted.
  4. the nozzle is restricted or worn.
  5. there is an air leak between the pump & the nozzle.
  6. water in the fuel. When a droplet passes through there is a momentary flameout condition which will cause the photocell to shut the unit down.
  7. The photocell is defective
Some more troubleshooting tips
Mar 10, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heater shuts down prematurly
If the heater runs fine for the 15 or so minutes without smoke/odor- do this
  1. check for water droplets on bottom of tank
  2. check for restricted fuel filter
  3. test photocell
  4. test safety control (reset)
You don't state whether this is a spark plug heater *or* Hot Surface Ignitor type. I made the assumption you were inquirung about a Spark Plug Heater. Disregard the list if the heater is an HSI type---- troubleshooting is different.
More troubleshooting tips for a Spark Plug Type heater
Dec 25, 2008 | Reddy R70ET Utility Heater
Reddy heater will not fire.
Your problem is most likely the lack of pressure from the air pump. Your pressure is extremely low. Pressure on a 100k heater should run 5psi. At 3psi there is not enough fuel and not enough air to atomize whats there. Bump the pressure up. If it won't come up, then you have an air leak. Test w/ soapy water. Keep your fingers clear of the fan!
Dec 04, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Won't stay on , not very consistent
You don't state whether this heater has the old style spark plug technology or the newer Hot Surface Ignitor technology. Troubleshooting will be different, depending on the style of heater, because the electronics are different.
You ask "what are the two adjustments screw heads on the back of heater". As stated by tros1 these are A. an air pump adjustment screw, and B. a pressure relief valve.
Both technologies require correct pump pressure in order to deliver the fuel at the proper rate. For a pressure setting video
http://youtube.com/watch?v=NeM3Yi9Y1oE
Reply with the model number and/or the specific ignition technology and maybe we can help.
Mar 06, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Wont stay running
Reddy suggests: 1. Propane supply may be inadequate 2. High surrounding air temperature causing thermal limit device to shut down heater 3. Restricted air flow 4. Damaged fan 5. Excessive dust or debris in surrounding area solutions are: 1. A) Refill tank B) Provide additional and/or larger tanks. 2. This can happen when running heater in temperatures above 85° F (29° C). Run heater in cooler temperatures 3. Check heater inlet and outlet. Remove any obstructions 4. Replace fan. 5. Clean heater. could not get manual for your exact model but if you want manual for RLP 125 then; http://12.153.20.74/manuals/113893-01C.PDF appears to be the same beast. Hope helps :)
Feb 27, 2007 | Reddy Heater RLP100 Portable Forced Air...
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
1,245 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
