Question about Xantrex Technology Heart Freedom 25 Inverter/Charger 12v, 2500w 130a, 81-2511-12
The tech replaced the main board of our Freedom 25.
I got the dead one. I see a couple blown FETs but it looks repairable. People used to rebuild these routinely. Save $500. Free to a good technical home. You pay shipping.
John Kessler
Ft. Lauderdale
Is the DEAD board still available or am I too late??? I'll gladly pay shipping. Amateur N4SVD, A.C.
Posted on Oct 22, 2009
John--
Don't know how old your post was regarding "a free technical home" for your Heart 25. If it is still available, I will pay for shipping and handling.
Thanks
Joe
foggysail@comcast.net
Posted on Aug 02, 2009
I have faulty pcb and found 2 small blown fets or transistors on the underside oi the board .pcb wa13u7 .would you know what these components parts nos are .pcb assignent are ic9 and ic10.
match the ratings on the components at radio shack and solder the new ones on... or send the board for rebuild at corecentric or fixyourboard
Apr 25, 2016 | Washing Machines
Freedom 20 Inverter/Converter Charger installed on Alpenlite RV. When remote switch for solar use (2000 watt) is turned on, all 110 system is energized. Turn solar switch off and voltage check at...
Second Freedom 25 inverter/charger...first one repaired, this one went to fault...started microwave on fire, fried the satillite receiver and possibly other components....installing a Mangnum....."do not let anyone rebuild the Freedom 25" First time about $900.00 to rebuild...this time about $9000.00 with components it fried. Fleetwood LLC Corporate knows of problems and only offer to sell you the conversion kit for about $4200.00....bankruptcy sanctifies previous problems "they" left with us.
Oct 27, 2010 | Xantrex Technology Heart Freedom 20 12...
Pmp3000 problem power supply.ic circuit problem.number series ic circiut..
I have a PMP5000 that I had to resurect. I had to trace out the power supply to repair it.
I can give you hint: First, a small supply runs directely from the line and generates some of the small voltages. While this starts, the main power caps are charged through limiting resistors. The main switcher is brought online and if the power amps acheive balance, then a relay connects the speakers and shorts the limiting resistors.
This is what is in the 5000 and I suspect the 3000 is similar.
In my 5000, there was arcing at one side of the power amps. The board was burned and three power fets fried. Cancer of burned board had to be carved out and traces replaced by hardwiring.
In addition, the limiting resistors were blown open, both main switching transistors were blown and 4 small driver transistors (surface mounted) and several diodes AND a switching regulator chip (surface mounted).all fried/
Hint: When restarting the unit, put a 150 watt light in series with one of side of the power input to limit the current in case you did not get all the dead bodies out.
This is a class "D" amp which drives PCM waves into a filter which is then the audio output. It is much more efficient thaan a linear amp.
Dec 24, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
I have an old Heart Freedom 20 charger/ inverter. It was in charge mode when lightening struck nearby and now doesn't do anything. Fuses???
Unlikely. Most likely it is dead. These are typically not very robust units and are riddled with issues without the help of lightning. If you can comfirm that there is voltage making it to the main input terminals and it is not doing anything, then it is time for a replacement or a rebuild. If you are on the East Coast, there is a great place where I send all of my Freedom units for repair. It is calle Tekris Power Electronics and they are in NJ. Good Luck
Aug 21, 2009 | Xantrex Technology RS3000 Sine Wave...
X-sus board replaced year later same pop of death
test the main board next to it- the are usually replaced together sometimes called the scan board-you can check for blown fuses on the x sus and put the back of your hand to the heat sinks- see if they warm up or not (be careful) if they stay cold with set on for several minutes then its dead
Aug 19, 2009 | Televison & Video
Replace main board on LG 42LC7D-UB
Try this place, http://www.shopjimmy.com/catalogsearch/result/index/?q=42lc7d-ub&p=2
I the best place I know of to get parts at a good price.
There are a couple of boards that have different part numbers. You'll have to match the part# with yours. It maybe out of stock, but click on it. Then click on "find other products with this part number". Then all the main boards show up with that part number. A couple of them should be should be in stock.
Apr 16, 2009 | LG RU-30LZ50C 30 in. HDTV-Ready LCD...
Sound Problems with Hitachi 42HDS69
Probably the main board, audio processer blown. about 300.00 to repair. A service tech told me this and the repair worked.
Feb 17, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Infocus projector power supply dead
the caps dry out. look for bulging caps. you won't find a schematic for the ps boards. infocus had someone else make them. the problem seems more like a overheating issue. as for the other one with the "just the fans", check the colorwheel.
Oct 03, 2008 | InFocus POWER SUPPLY CORD Multimedia...
My amp is blown!! Dont know what part to replace.
those are likely "chips" or "integrated circuits". can you read any words, letters, numbers off it? if it's a common off-the-shelf chip you can buy from mouser.com or digitek.com, AND if you know how to de-solder and solder delicate electronic components using a hot soldering iron WITHOUT destroying them or the adjacent components. if no identifying codes on the chip, maybe google up a schematic of the board (unlikely) and figure out what it is. if it's a proprietary chip made Rockford Fosgate, it will be harder to find. Also, there could be damage to OTHER components that may not be visible, so if you go to all this trouble it might still not work and then you'd have wasted money. hopefully you are under warranty and RF can repair it. otherwise, chunk it in the nearest trash can.
Mar 06, 2007 | Rockford Fosgate P10002 Car Audio...
Xantrex Technology Heart Freedom 25 Inverter/Charger 12v, 2500w 130a, 81-2511-12 Logo
357 people viewed this question
Top Xantrex Technology Boating Experts
Tre Elkins
Steve
Steve
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
