Fujitsu 18R1 Air Conditioner
Problem for Fujitsu 18R1 Air Conditioner
How to remove cover on fujitsu split system head
By chone697 on Feb 21, 2009
Need to access behind face of indoor unit to remove rats nest. Can the front cover be removed independantly or does the head need to be removed as a unit ?
Solution #1
posted on Aug 29, 2009
Not Rated)
matyt94
Rank: Guru
Rating: 89%, 35 votes
The front cover can be dismantled (taken off as one Piece) by unscrewing the screws at the bottom of the air outlet (they are covered by screw cvers which will need to be taken off. Then just pull off the cover. PLEASE NOTE that the front panel (liftable to take out filters) will need to be removed lift up until 90 degrees and then pull off gentley and also take out filters before removing front cover
I take the time to answer you questions so please rate me
Thankyou
Mat
Was this helpful?
Yes
No
Popular Solutions for Fujitsu 18R1 Air Conditioner
Questions and Unsolved Problems for Fujitsu 18R1 Air Conditioner
Do you recommend Fujitsu 18R1 Air Conditioner?
Answer
Answer
all the display function lights are on all the time power is switch on.
Answer
hey kan u mij de handleiding geven van een midea airco type R11HQ/E dank u grt marcel
Answer
My psp won't turn on!!!
Answer
were can i get a remote control for a v-lec air con
Answer
fan is LOADED with mold and mildew. Can the fan be removed for cleaning??
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
in , NY
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
